    Box86 and Wine on RPi4
    box86wineqemux86windows
    475 Posts 40 Posters 278.8k Views
      George @Folly
      Thanks for the encouragement and support @folly!
      I narrowed down the issues I was seeing with wineserver not terminating after a program completed. I brought it up on the Box86 Discord channel and got a reply back from ptitSeb saying that the shutdown sequence in Box86 is still problematic. At least he's aware of it and I'm sure if he'll be able to find a solution eventually.
      My current workaround for the issue is to use a slightly older version of Box86. On March 25, there was a commit (https://github.com/ptitSeb/box86/commit/bc198c37d7460c95cd0047f0cc1fd1234b898dc7), labelled "Improve shutdown sequence". At this commit, the issues with wineserver not terminating start. Prior commits to this I don't seem to have any issue with wineserver terminating after any app that I'm running ends.
      I should note that my solution may not work for everyone seeing the issue and that everyone may not actually see the issue. Some apps seem to work fine, but I saw the issue with Winetricks, Space Cadet 3D Pinball, and even just running the Wine Desktop.
      - George
      • FollyF
        Folly
        @george
        Perhaps you are interested.
        A while back we talked about external repositories.
        I have made a gui module-script that can add some external repositories.
        Goal is to make it easier to get module-script that are not yet in the original RP-Setup.
        It will download the scripts if not in the original RetroPie-Setup and add them into ext path into appropriate directories.
        After that it also refreshes, so you can go back to the normal setup and install.
        This will help to use the the module-scripts from forks and other repositories.
        Can you take a look at it ?
        What do you think, would it be useful ?
        So basically if you select your repository it will only get the box86wine things and place them in an ext path. (if the module-scripts are not in the original RP-Setup)
        This pushes add-ext-repos.sh directly in the ext directory :
        mkdir -p /home/pi/RetroPie-Setup/ext/RetroPie-Share/scriptmodules/supplementary
        curl https://raw.githubusercontent.com/FollyMaddy/RetroPie-Share/main/00-scriptmodules-00/supplementary/add-ext-repos.sh > /home/pi/RetroPie-Setup/ext/RetroPie-Share/scriptmodules/supplementary/add-ext-repos.sh
        Select -> Configuration / tools -> Add-ext-repos (at the bottom)
        G 1 Reply Last reply Reply Quote 2
        • shavecatS
          shavecat @George
          @george
          Can u Try
          Hunter Hunted ?
          use to love this game so much ! :)
          Still not really works well on my side :'((
          And i Got and Error from Jazz 2
          that my Resolution is not 640x480 or 800x600.
          In the WineExploere
          Can i change the resolution in there ???? the Display ????
          maybe that will fix my problem ( of the black screen go in and back to the wine)
          THANKS !!! <3
            George @Folly
            @folly that's a cool script. Seems like something RetroPie should have if it's considering making external repositories a fully supported feature. They could list out popular repositories and let the user add their own.
            It might be useful if you pointed to my repo at:
            https://github.com/GeorgeMcMullen/rp-box86wine
            That has just the scripts that are required for Box86/Wine. That way, users won't get messages saying that there are duplicate scripts.
            Other than that, you should make a post in the "Ideas and Development" forum to suggest a script like yours, or that your script be added to RetroPie.
            Nice work!
            - George
            • FollyF
              Folly @George
              @george
              Nice to hear that you find it very cool !
              I will change your repository in the script,
              and after my holiday I should make a separate thread for it.
              Edit : your repository is updated in the script.(had to do a second fix)
              roslofR 1 Reply Last reply Reply Quote 1
              • roslofR
                roslof @Folly
                I'm loving this. Incredible efforts here @George, @Folly and anybody I missed. I was able to use the latest alt scripts and get things running without much trouble.
                Was able to install/play a Windows game I helped publish in 1997 called "Emperor of the Fading Suns". GOG recently re-released it with the CD-audio converted to .ogg's and I had to try this. Worked perfectly!
                Thanks guys, for allowing me to run/play games that I was unable to play on my modern gaming machine. Cheers!
                FollyF G 2 Replies Last reply Reply Quote 2
                • FollyF
                  Folly @roslof
                  @roslof said in Box86 and Wine on RPi4:
                  Nice pictures, looks very good !
                  • roslofR
                    roslof @George
                    @george said in Box86 and Wine on RPi4:
                    I rechecked the logs and found that DSound was being used for PCM audio. I used Winetricks to install the Windows DSound DLL and so far the audio issues no longer occur.
                    Had to dig to find this little nugget. Several of my games played audio, but some SFX were missing. This solved the problem. Folks who want to try this will have to be patient. Wintricks will show "Running..." as it downloads a 100MB file. Took about 20 minutes for me. Be patient.
                      George @roslof
                      @roslof wow that is really cool! Congrats on getting it to run! Looks like an interesting game, I'll have to check it out.
                      As you've found out, there's a lot of little nuggets that you need to get through in order to get a game working sometimes. The info on WineDB (https://appdb.winehq.org/objectManager.php?sClass=version&iId=7324) doesn't include any reference to DSound, but it's possible that it works just fine on an x86 machine with Wine.
                      I'm trying to document all the issues I've seen getting games to run with this thread, so at least they will reside somewhere. Hopefully they will be searchable with Google and help someone out.
                      Which reminds me... not sure if I mentioned the following:
                      • The issues I saw with Wine not terminating properly have been resolved by some recent commits in Box86. Sweet!
                      • Other folks have seen issues with Mesa 21 and there are a couple of tickets with some more information on it:
                        • https://gitlab.freedesktop.org/mesa/mesa/-/issues/3969
                        • https://bugs.winehq.org/show_bug.cgi?id=50859
                      • I have a branch on my external repository (https://github.com/GeorgeMcMullen/rp-box86wine/tree/emulator) called "emulator" which installed Wine as an emulator instead of a port. I'll have to add some documentation on how to add "roms", which can be either shell scripts or conf files. Works pretty well, except for the fact that there are no themes for Wine so it's a bit hard to navigate unless you make the changes yourself. My favorite theme is the Pixel theme, so I've forked it and made my own changes. (https://github.com/GeorgeMcMullen/es-theme-pixel/tree/rp-box86wine)
                      I'm glad folks are getting some use out of this!
                      - George
                        chado21 @George
                        @george so i have a casino slot game im trying to setup. been following along and am now stuck on the box86 install. its asking for ver 4.7.7... where do i find that? cant seem to locate it or find any resource on obtaining it....
                        love this idea!!
                          George @chado21
                          @chado21 That may mean that you need a more recent version of the RetroPie Setup scripts, but I can't be sure without more details. Can you share a screenshot?
                            chado21 @George
                            @george i will today when i get home. I have 4.7.2, and did the uprade like the forum said. i even went to retroipe website and looked for 4.7.7. I have the scripts in retropie setup...even did the first part. but when i get to box86 it just says need 4.7.7
                              George @chado21
                              @chado21 probably what you'll need to do is run RetroPie Setup and then hit S for Update RetroPie-Setup script.
                                chado21 @George
                                @george did that just now, it shows 4.7.2 . then says script up to date. just clicked the "update" now its running an update... not sure if its for 4.7.7 or just updating the OS...
                                C G 2 Replies Last reply Reply Quote 0
                                  chado21 @chado21
                                  @chado21 c77dc7f4-5456-4512-8f81-64b12994ebce-image.png same song and dance.... 4.7.2
                                    George @chado21
                                    @chado21 That's odd. Perhaps there's an error while it tries to perform the git update?
                                    If you SSH into the Pi, try the following:
                                    cd ~/Retropie-Setup
                                    git fetch origin
                                    git pull origin
                                    sudo ./retropie-setup.sh
                                    Also, can you send us the output of uname -a as well.
                                    - George
                                      George @chado21
                                      @chado21 The box86 script does check to make sure that RetroPie is on version 4.7.7 or later. This is because 4.7.7 introduced some new function calls for dependency checks, which is used by the Box86 script.
                                        chado21 @George
                                        still seems to be the same. i wish i knew what to fix....
                                          George @chado21
                                          @chado21 Ok, you're on the right kernel version, which is a good sign. But what about the output of the other commands I mentioned? Can you send that as well?
                                          - George
                                            TedMaul
                                            Hello, I've been persevering with trying to run through Wine explorer (still can't see how to make shortcuts for ES to run directly...). I've got Sonic SMS 1 Remake working (great fun btw!) and audio is fine but gameplay is very laggy. Are there any options for speeding up, if that isn't a silly question? Cheers.
                                            M G 2 Replies Last reply Reply Quote 0
