    Box86 and Wine on RPi4
    box86wineqemux86windows
    475 Posts 40 Posters 285.9k Views
      Troopaking @ecto
      @ecto I don't understand question.
      Mame is in retropie already why not use it ?
      In theory it could run in wine/box86 .
      I am working on getting wine to launch with a desktop installed. Currently no desktop can be installed with this script.
      ectoE 1 Reply Last reply Reply Quote 0
      • ectoE
        ecto @Troopaking
        @troopaking Let me try to explain: It is true, that MAME can emulate some (not all by far) Model 2 games. But it only can so that in the latest releases, which are not feasible to run even on a Raspberry Pi 4.
        The Model 2 Emulator OTOH can emulate almost the whole Library of Model 2 games but is restricted to Windows and is not in active development since 2014.
        I was just asking myself (and hereby you guys) if it's possible to run the (Windows only) Model 2 Emulator using Box68 or Wine and if the RPi4 might be powerful enough to pull that off in any way? By that, a lot of previously unplayable games would become playable on a (ARM) Retropie.
          George @ecto
          @ecto It might be possible to run Model 2 Emulator, but since it's a relatively recent WIndows program, it might not run fast enough to be playable.
          With regards to MAME, I found that the more recent versions of SDL show a major performance increase making some games that were not previously playable in the latest versions of MAME play quite nicely. Here's a post I did about that.
          https://retropie.org.uk/forum/topic/28362/enhanced-performance-of-mamedev-mame-in-x11
          Hope that helps.
          - George
          ectoE T 2 Replies Last reply Reply Quote 0
          • ectoE
            ecto @George
            @george Thanks for your input. That's a very interesting topic! I have Dosbox (and Dosbox-Staging) run with XINITand have definitely performance gain from that, but I don't know the cause.
            I will definitely look into Mame-dev at some point.
            What equivalent of an Intel or AMD processor would you think the RPi4 can run using Wine or Box86?
              Troopaking @George
              @george
              Ahoy again .
              So I am testing with a desktop environment pixel installed now.
              SUCCESS
              What I did in this order
              -install fresh retropie
              -install lightdm and pixel
              -followed my above "how to"
              Gonna try and install pixel on other card I have full of mugens and your scripts loaded up.
              Will be doing speeds before installing with same mugens and settings.
              That way we have no desktop vs desktop installed test as well .
              UpDATE
              I installed pixel on sd with mugens and script . It stops some from launching and slowed all way down .
              Same file on new sd card doesn't have that issue at all. I have pixel on new sd as well. Just installed before your scripts .
                George
                @ecto I can't really say what processor such as Intel or AMD would be equivalent of an RPI4. I think there are several variables. Whereby the ARM processor in the RPI4 might be as powerful as a processor from about 2005 (I get pretty good performance of some games from that time period), the GPU is probably more advanced than those of the era. I think that's part of the success of Box86 - emulate as little as possible, dynamically recompile what it can, push library calls to the native system, and use the power of the current GPU vs. trying to pipe things through software.
                @Troopaking , speaking of piping things through software, on the platform that is slow, am I correct in understanding that Pixel was installed AFTER everything else. In a command line can you do:
                dpkg -l | grep -i fbturbo
                My suspicion is that the LLVM Pipe software renderer got installed again and it slows everything down.
                - George
                  Troopaking @George
                  @george correct very slow when pixel installed after everything else . Thanks for possible solution .
                  I am testing on a few builds with desktops on em now . We will see what happens.
                  UPDATE
                  Worked on a full build with pixel installed.
                  Issues happened
                  skifree exited but didn't return to retropie menu . Just black screen o death
                  Didnt workon some displays .
                  Anyway to change the wine resolution to match the TV? In a arcade cabinet for example .
                    George @Troopaking
                    @troopaking I believe you may want to try changing the resolution of the desktop session before launching Wine, so that it matches the resolution that the game expects to be in. I don't think Wine / Box86 handles resolution changes very well just yet. In your script that launches the game, you could add a line for xrandr to set the resolution before launching wine, and then use it again to reset it back to the proper resolution.
                    - George
                    T 1 Reply Last reply Reply Quote 1
                      Troopaking @George
                      @george
                      Ahoy .
                      So I have had great success on many builds with mugen.
                      Only issue ive come across
                      -box86 error retropie has to be 4.7.1(or 4.7.something don't remeber exactly)
                      -if gpu memory is too low will not work.
                      -i can't get .sh to work at all . Testing now by copying winedesktop.sh and changing directories .
                      I am now working on launching joy2key on wine boot/same time as mugen/before mugen.
                      I have successfully installed it on wine installer and desktop mapped xbox controller great . Just need to start with wine now :)
                        George @Troopaking
                        @troopaking that GPU memory tip is good. I will have to try that if I ever have an issue with a game not running.
                        I wonder if perhaps you might need to do a chmod a+rx SCRIPTNAME.SH in order to make it work. You may have already done it, but worth checking.
                        - George
                          Troopaking @George
                          @george .
                          Hello so I can start the .sh fine but it won't open mugen.
                          Error "cant open mugen.cfg ". Seems .conf works better for me .
                          Also another person using scripts cant open .conf . Hes is sure he ran chmod+x on em.
                          Also for everyone reading this doesn't work on a 64 bit environment box86 is useless like that .
                          R G 2 Replies Last reply Reply Quote 0
                            RussellB @Troopaking
                            @troopaking
                            I got the conf file method working by removing the "OPTIONS=**" from the file. It was causing a malformed command line to be passed to wine.
                              Troopaking @RussellB
                              @russellb uh the .conf works fine for me with options in it.
                              Problem is .sh I can launch it bit it wont open mugen says error unable to open mugen.cfg.
                              Seems the .conf works better than .sh simpler I guess dont know for sure why
                                George @Troopaking
                                @troopaking said in Box86 and Wine on RPi4:
                                True. ptitSeb did just release Box64, but vice versa that won't work on a 32 bit system. Plus you would need to use a 64 bit Wine, and that won't work with 32 bit applications, etc.
                                I'm puzzled by the error you are seeing (can't open mugen.cfg). If you have the same directory listed in the conf file and sh file then it should work the same. I also presume that mugen.cfg is in the same directory where the exe is. You might be able to do some additional debugging by inserting a couple of lines like this and see the log output matches your expectations:
                                pwd
                                ls -al
                                @RussellB if you had a line that said OPTIONS=** then that would likely throw some kind of error because * is the file wildcard.
                                T R 2 Replies Last reply Reply Quote 0
                                  Troopaking @George
                                  @george
                                  Yeah I'm puzzled as well. .conf works fine but not .sh same files same directories etc
                                  .sh loads wine fine starts to open then says cant open mugen.cfg. with simpler games yo opens fine . Example skifree.sh plays fine.
                                  .conf takes a min to load but works great. I have started in wine desktop same load time .
                                  Maybe .conf is better than .sh ? I am unsure .
                                  So I modified a few things for better playing experience .
                                  Changes/modifications
                                  -changed wine default to windows 8
                                  -set pi gpu memory to 128. Tested vs 256, 128 gave me more frames per second.
                                  -installed joy2key to map keyboard to controller. Controller preferred by some. Installed through wine config. Seems hard to launch same time with .conf as you said . But cant get .sh to work . So been looking into wine programs at boot. Hard to transfer to pi wine
                                  -told wine that my pi has max video memory 1028 (I think), in winetricks .
                                    George @Troopaking
                                    @troopaking I guess other things you might be able to try are removing the cd command from the .sh file or setting it to the location of the Wine prefix (like /home/pi/.wine/drive_c/ or something).
                                    Really appreciate the times on the GPU and max video memory. Those are going to be interesting to test out.
                                    For joy2key, what you could try to do is edit the Wine Desktop.sh file and add the command you need. Maybe around line 80? I've never been able to get Wine to launch a Windows program when it starts up using any of the usual Windows methods, like Startup folder, etc. From my own investigation, it seems Wine doesn't utilize those standards.
                                    - George
                                      RussellB @George
                                      @george said in Box86 and Wine on RPi4:
                                      pwd
                                      ls -al
                                      Yeah what it was doing was including all the directories in the specified mugen folder into the command line to wine. So you ended up with something like mugen.exe char data ... in the wine command that was breaking it.
                                      Now I just need to code the escape key to a button in wine and I'll be a happy camper.
                                        @russellb escape key is why we are trying to autostart joy2key that escape is left bumper for example .
                                        George from my testing 128 gpu memory is best performance .
                                        I'm working with a guy to write a modified version of yourscriot that installs all mugens, changes gpu, install your script and makes mugen launch files .
                                          @troopaking Yeah as we have discussed I tried to get a joy2key windows-based program running and I succeeded but I can't find out a way to "autostart" WITHIN the wine environment. Looks like it will have to be setup before starting wine.
                                            @russellb
                                            If you install thru wine .
                                            Open wine desktop then joy2key then mugen works great.
                                            But thats not what we want lol
                                            Update
                                            Success kinda If you add
                                            WINEDEBUG=-all LD_LIBRARY_PATH="/opt/retropie/supplementary/mesa/lib/" setarch linux32 -L /opt/retropie/emulators/wine/bin/wine '/path/to/joykey' &
                                            To .sh above skifrees launch script. It opens both fine .
                                            Unfortunately thier were issues
                                            -exiting problem. Solved below
                                            -and I still get same mugen error
                                            -I have two windows one wine tray the other skifree . Works if ya click on joy2key make sure controller is registered then click skifree.
                                            Exiting problem solved joy2key has a option "minimize instead of close when x is pressed" disable this option returns to retropie fine .
