    Box86 and Wine on RPi4
    box86wineqemux86windows
    475 Posts 40 Posters 337.1k Views
      Troopaking @Troopaking
      Success with a different method.
      How to
      1.Install qjoypad
      Sudo apt-get install qjoypad
      2.Configure qjoypad in Linux desktop . Pretty self explanatory.
      3. Edit .sh script.
      Add this line before game script line
      qjoypad &
      Should work off rip that like did for me .
      But I still have same mugen error .
      I need to figure out why mugen doesn't work with .sh for me .
      When I run the commands in terminal on desktop I get root access error it seems .
        George @Troopaking
        @troopaking root access error? Could it possibly be an ownership or permissions error? Check to see what user owns the application, directories, and config files. They should be owned by pi.
        But I'm not sure this would explain why the .conf method is working and the .sh method is not.
        - George
          Troopaking
          So I discovered the issue .
          DO NOT EDIT .SH IN WINDOWS . This is was caused my issue .
          I changed .sh in Linux to this to autostart qjoypad works perfect .
          #!/bin/bash
          xset -dpms s off s noblank
          cd "/home/pi/RetroPie/roms/wine/Files/claw/"
          startx &
          qjoypad &
          WINEDEBUG=-all LD_LIBRARY_PATH="/opt/retropie/supplementary/mesa/lib/" setarch linux32 -L /opt/retropie/emulators/wine/bin/wine '/home/pi/RetroPie/roms/wine/Files/claw/CLAW.EXE'
          Opens and maps the keyboard to controller perfect.
          Go into pixel desktop first and setup per game or games .
          If you need different profile for game add "profile name " after qjoypad example.
          qjoypad "mugen" &
          G R 2 Replies Last reply Reply Quote 0
            George @Troopaking
            @troopaking Awesome! Glad you figured it out. Nice work!
            • DTEAMD
              DTEAM @George
              Now you have a logo for Comic Book Theme
              thanks to @MrSeven
              see here
              R G 2 Replies Last reply Reply Quote 1
                RussellB @Troopaking
                @troopaking I took it one step further. I modified "Wine Desktop.sh" so that it will try to load a qjoypad layout named the same as the folder the mugen executable is in.
                This only works for .conf files. I did this because I hated to have to have a different .sh for each game that basically does the same thing.
                So for example...
                /home/pi/RetroPie/roms/wine/Files/M.U.G.E.N/mugen.exe
                It now tries to load M.U.G.E.N.lyt after checking to see if it exists in /home/pi/.qjoypad3 folder.
                If it does not exist, it checks to see if WINE.lyt exists, and if it exists it will load that.
                If that doesn't exist, it loads the default layout that was setup in the XWindows desktop.
                This is generic now for any game, not just MUGEN.
                  RussellB @DTEAM
                  @dteam I actually changed the theme to "windows" because most themes have a "Windows" theme already setup.
                    George @DTEAM
                    @dteam That looks awesome! Thanks!
                      George @RussellB
                      @russellb This sounds pretty cool. I've never used QJoyPad before. Can either you or @Troopaking share how you installed it? The original project on SourceForge seems fairly old (http://qjoypad.sourceforge.net/), but there is a more recent fork on GitHub (https://github.com/panzi/qjoypad). I see there is a package for qjoypad, but that seems to be for v4.1 (the SourceForge version), while on GitHub it's up to 4.3.1.
                      @RussellB would you mind sharing your modifications?
                      There doesn't seem to be a script for QJoyPad in RetroPie (please correct me if I'm wrong). There seem to be additional alternatives as well (https://askubuntu.com/questions/239176/alternative-to-qjoypad). Perhaps it's worth starting a new topic with regards to creating some scripts that install these.
                      Thanks!
                      - George
                      R T 2 Replies Last reply Reply Quote 0
                        RussellB @George
                        @george sudo apt-get install qjoypad did the trick. Installed version 4.1.
                        Replace the test for .conf file in "Wine Desktop.sh" with this code. If ~/.qjoypad3 folder does not exist, it ignores the call to qjoypad all together.
                        elif [[ "${params[0]}" == *.conf ]]; then
                            configFile=$(cat "${params[@]}")
                            WINEPREFIX=$(configValueForKey WINEPREFIX "$configFile")
                            DIRECTORY=$(configValueForKey DIRECTORY "$configFile")
                            PROGRAM=$(configValueForKey PROGRAM "$configFile")
                            OPTIONS=$(configValueForKey OPTIONS "$configFile")
                            QJOYPADLAYOUT=$(echo $(basename $(dirname "${PROGRAM}")))
                            echo "Launching with config file"
                            echo "WINEPREFIX: $WINEPREFIX"
                            echo "DIRECTORY: $DIRECTORY"
                            echo "PROGRAM: $PROGRAM"
                            echo "OPTIONS: $OPTIONS"
                            echo "QJOYPADLAYOUT: $QJOYPADLAYOUT"
                            if [[ "$DIRECTORY" ]]; then
                                cd "$DIRECTORY"
                            fi
                            midi_synth start
                            matchbox-window-manager &
                            if [ -d "/home/pi/.qjoypad3" ]; then
                                if [ -f "/home/pi/.qjoypad3/${QJOYPADLAYOUT}.lyt" ]; then
                                    qjoypad "$QJOYPADLAYOUT" &
                                    echo "Starting qjoypad with $QJOYPADLAYOUT"
                                elif [ -f "/home/pi/.qjoypad3/WINE.lyt" ]; then
                                    qjoypad WINE &
                                    echo "Starting qjoypad with WINE"
                                else
                                    qjoypad &
                                    echo "Starting qjoypad with default layout"
                                fi
                            fi
                            setarch linux32 -L /opt/retropie/emulators/wine/bin/wine "${PROGRAM}" "${OPTIONS}"
                            midi_synth stop
                        fi
                        R 1 Reply Last reply Reply Quote 2
                          Troopaking @George
                          @george
                          Sudo apt-get install qjoypad worked for me as well on a few builds .
                          Me and RusselB (mainly Russels knowledge) have been working on qjoyoad instead of joy2key in wine . Qjoyoad performs a lot better and can scripted like Russel has done for each game to launch different settings.
                          All of us have done a good combined effort to make something really cool . Hopefully they will use in retropie offical soon .
                          Thanks to russel, you and others for the work.
                          I greatly appreciate the teamwork and community effort .
                            RussellB @RussellB
                            @russellb said in Box86 and Wine on RPi4:
                                QJOYPADLAYOUT=$(echo $(basename "$(dirname "${PROGRAM}")"))
                                    cd "$DIRECTORY"
                                fi
                                midi_synth start
                                        qjoypad WINE &
                                    else
                                        qjoypad &
                                    fi
                                fi
                                midi_synth stop
                            fi
                            Found a bug in the assignment of QJOYPADLAYOUT. Missing quotes around the parameter to basename.
                              RussellB @RussellB
                              @russellb So to make like easy on the game add-on developer I have created a default WINE.lyt that has the default joypad values for MUGEN. Then, in mugen.cfg I have the following changes:
                              GameWidth=640
                              GameHeight=480
                              FullScreen=1
                              P1.Joystick.type = 0
                              P2.Joystick.type = 0
                              ; P1 Key config (configurable from M.U.G.E.N)
                              [P1 Keys]
                              Jump   = 273
                              Crouch = 274
                              Left   = 276
                              Right  = 275
                              A      = 44
                              B      = 46
                              C      = 47
                              X      = 108
                              Y      = 59
                              Z      = 39
                              Start  = 13
                              ; P2 Key config (configurable from M.U.G.E.N)
                              [P2 Keys]
                              Jump   = 119
                              Crouch = 115
                              Left   = 97
                              Right  = 100
                              A      = 102
                              B      = 103
                              C      = 104
                              X      = 114
                              Y      = 116
                              Z      = 121
                              Start  = 117
                              That way all the games can have the same configuration. If you want to have game-specific settings leave the keys alone in mugen.cfg for that game and create a custom layout in qjoypad that maps to that game. Easy peasy.
                              It occurs to me that M.U.G.E.N. deserves its own system in themes, but I can't find any themes that have a M.U.G.E.N. system. Also need a "Loading..." screen.
                                RussellB @RussellB
                                @russellb Because not a lot of themes have a specific theme for MUGEN I made a subdirectory under roms/wine/M.U.G.E.N.. (need to periods so it shows up as M.U.G.E.N. in the ES menu) and put the MUGEN conf files in that folder. I'm using the "windows" theme for wine so this makes sense to me as they run under windows. I'm ok with that. :)
                                  Troopaking @George
                                  @george
                                  Hello again George so Russell's qjoypad code works great. Just awesome stuff .
                                  I'm having a issue with Baldurs Gate(bg). If I opened wine config then start bg works fine . But open through desktop or .conf fails. Has horrible black screen issue unless ran with wineconfig .
                                  Update Baldurs Gate worked perfect when ran through .sh with startx instead of matchbox .
                                    @troopaking said in Box86 and Wine on RPi4:
                                    @george
                                    I can't find a version of Baldur's Gate that runs properly even in Windows 10 to try it in WINE. :(
                                      RussellB @RussellB
                                      Can someone try this for me?
                                      Testing WINE with 3D Space Cadet Pinball originally for Windows 95. It runs fullscreen fine, however hitting "ESCAPE" key it switches back to a window and then hangs. Can't figure out why.
                                      If I hit ALT+F4 however, it exists back to ES.
                                      Looks like WINE is having a problem closing whatever application is running and it hangs.
                                      NEVERMIND! I see this was noted in a previous post.
                                      EDIT: Using xbindkeys and qjoypad I now have the ability to do a one-button exit back to ES:
                                      xbindkeys is configured to map the "END" key to the command "pkill -f /opt/retropie/emulators/wine/bin/wine".
                                      qjoypad is configured so the "BACK" button send the "END" key
                                      So "BACK Button"->qjoypad->xbindkeys->terminate wine process
                                      I'll test it with other programs but now at least you don't need a keyboard for Pinball anymore!! If this works with mugen (Need to map a different button because I use "BREAK" as "ESCAPE" to traverse back through the menus. Let me do some more testing.
                                      This even fixes the issue I had where on one RetroPie install it failed to exit when selecting the "EXIT" menu item or "ESCAPE". Now I programmed the "Logitech" button on the F710 to send the "END" key and it works great!
                                        RussellB @RussellB
                                        Had to change the kill command to "kill $( pgrep -f "wine/bin/wine\ /")". This command kills the executable that was started so Wine can shutdown cleanly.
                                        So I had to install xbindkeys and xbindkeys-config from apt-get. A custom configuration file to handle the END mapping to the script, and voila.
                                        EDIT: Even easier way to shutdown cleanly:
                                        /opt/retropie/emulators/wine/bin/wineserver -k
                                          George @RussellB
                                          @russellb That's awesome. The escape key problem on Space Cadet pinball always bothered me. I'm going to have to try this!
                                          - George
                                            RussellB @George
                                            @george said in Box86 and Wine on RPi4:
                                            - George
                                            Let me know if you want the files to try this out.
