    Box86 and Wine on RPi4
    box86wineqemux86windows
    475 Posts 40 Posters 278.8k Views
    • hooperreH
      hooperre
      Has the audio issue been sorted or any known fix? My audio isn't working on the pi outside of splash videos regardless of whether wine is opened.
      cat /proc/asound/cards only shows headphones.
      4B ~ RPi PSU 5.1V / 3.0A ~ 32GB SanDisk microSD ~ 128GB USB
      • dodonpachiD
        dodonpachi @hooperre
        @hooperre how did you install DirectX9? I wonder if that's what I'm missing for Vanguard Princess and Freedom Planet...
        hooperreH 1 Reply Last reply Reply Quote 0
        • hooperreH
          hooperre @dodonpachi
          @dodonpachi https://www.microsoft.com/en-us/download/details.aspx?id=8109
          Then installed inside wine. I tried doing it through Winetricks but it failed. Also using winetricks to install the core fonts (From memory) helped compatibility.
          dodonpachiD 1 Reply Last reply Reply Quote 0
          • dodonpachiD
            @hooperre .... That link just takes me to a page to shop for Surface laptops. Did you copy the wrong one?
            And when you say installed through Wine, what do you mean? You ran the .exe through a .conf or something like you would a game?
            • hooperreH
              @dodonpachi Sorry, updated the link. Correct. IIRC you install and then run another installation after the first one from the .exe files within wine. I would try running winetricks > install dll > directx first but it didn’t work for me. Wine’s website says it doesn’t support directx but it worked for me. You can also install directx if it comes with the install cd for the game.
              Adding snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_compat_alsa=1 to /boot/cmdline.txt does solve the audio issue I encountered as alluded to in a previous post where hdmi was missing.
              Removing pulseaudio solved a separate audio issue.
              • dodonpachiD
                dodonpachi
                So I've now gotten Vanguard Princess to run through Wine Explorer (and it runs very well), but I still cannot get it to run from a .conf or .sh file on the Emulationstation menu.
                Ugh, I'm so close. I must be missing something.
                EDIT: I've gotten the demo for Freedom Planet (from the official site) to run through Wine Explorer. Performance isn't stellar, but it worked with my arcade stick right out of the box! Still can't get it to load through .conf or .sh though...
                hooperreH G 2 Replies Last reply Reply Quote 1
                • hooperreH
                  @dodonpachi Thats about as far as I’ve gone. I can’t believe what’s running on this thing lol. The .sh and .conf files have eluded me so far. Glad directx worked!
                  • E
                    EvilCreamsicle
                    So as promised I went to try and get this set up, but I didn't even get far enough to try and launch the game.
                    I set it up using the emulator branch, updated to, I think 4.7.19, and installed the packages via the scripts in order as described in the ReadMe
                    EmulationStation launches, but when I try to select the new emulator to simply view the list (which would contain my one .conf file and the default Wine scripts that live in there) it crashes emulationstation.
                    Says something about making sure the CPU/GPU split is set right... I never changed it from default, but I think that's just a generic error message so I wanted to check if anyone else has seen this before I go messing with it. Doesn't do this when I select any other of the default emulators.
                    • E
                      EvilCreamsicle
                      Update, plugged this in in my office and... the crashing didn't happen.
                      Then it occurred to me that the default resolution is 'monitor preferred resolution'... and my Pi was connected to a 75-inch 4k Samsung TV. That is probably why it got angry.
                      So, I can confirm that RPG Maker VX games run using this solution!
                      Don't have audio yet but I think that's me misconfiguring something. I'll update when I know if thats an issue or not.
                      EDIT: Doesn't launch every time... crashes sometimes. Logs show:
                      Box86 with Dynarec v0.2.3 8b887c7 built on Sep 23 2021 04:37:01
                      0058:err:ole:start_rpcss Failed to start RpcSs service
                      0060:fixme:mountmgr:harddisk_ioctl Unsupported ioctl 4d004 (device=4 access=3 func=401 method=0)
                      /home/pi/RetroPie/roms/wine/Wine Desktop.sh: line 86:  1165 Segmentation fault      setarch linux32 -L /opt/retropie/emulators/wine/bin/wine "${PROGRAM}" $OPTIONS
                      xinit: connection to X server lost
                      waiting for X server to shut down wm_set_cursor_visibility: visible using XCreateFontCursor
                      (II) Server terminated successfully (0). Closing log file.
                      code_text
                      EDIT 2:
                      This seems to have been all about resolution.
                      DMT mode 16 allows RPG Maker VX Ace games (well, mine anyway) to launch reliably in Wine via Config file, and be played with a standard gamepad.
                      • E
                        EvilCreamsicle @EvilCreamsicle
                        This post is deleted!
                          George @dodonpachi
                          @dodonpachi can you post the output of /dev/shm/runcommand.log? Maybe there is something in the output that could give us a hint.
                          Also, I wonder whether or not the game requires desktop mode. I don't think I've seen that actually happen, but maybe it's not good at setting its own resolution and is trying to depend on the resolution from the desktop.
                          - George
                          • E
                            EvilCreamsicle @George
                            @george I've got it running now, but have run into issues where performance is reeeeally bad even though CPU is at 50% and memory still has ~2GB free. I'm suspecting something to do with GPU.
                            I don't know if you've tried doing this on a display that is requesting a huge 4K image, but I suspect it was just too big of an ask for the hardware or EmulationStation. Is the Wine logo you use a vector image? Because it was so enormous that it just looked like my screen had a red gradient, and it looked like the WINE emulator had a blank image (and would crash if you selected it).
                              George @EvilCreamsicle
                              @evilcreamsicle in general, when running games via Box86 and Wine on the Pi 4, I reduce the resolution quite a bit. For me that's ok because I'm playing early games that weren't designed for more than 1024x768 with a screen that doesn't have much higher resolution screen either. (I enjoy making handheld games or playing on my arcade cabinet that has a CRT).
                              But it also sounds like you're experiencing an issue with an EmulationStation theme. Is that correct? A picture of what you're experiencing could help. Are you using my modified Pixel theme? If so, I'll have to take a look at it. I believe that my images are just plain PNGs, but I know from past experience that PNGs can be compressed in a variety of ways for space and performance. I didn't look at the original PNGs in the theme for that, so it's possible that something happened when I exported the images as PNG. Let me know.
                              Thanks!
                              - George
                              • E
                                @george when I manually set the resolution lower, it isn't an issue. I was only offering that as evidence that 4K could have been part of the problem. I'm not concerned about the theme weirdness right now though. I was using the default RetroPie theme.
                                The game I'm running is made in RPG Maker VX Ace, which was released in 2012 and really doesn't need a high resolution either. It's pixel art graphics, doesn't look like anything that wouldn't run on a super nintendo, so I'm struggling to figure out why some scenes seem to be so graphically demanding.
                                Not sure if this is a box/wine thing or if it is an RPG Maker thing.
                                R G 2 Replies Last reply Reply Quote 0
                                  retropi19 @EvilCreamsicle
                                  mth75
                                  Hi there can you try the games Gorky17 and dune2000 ???
                                  And is it possible to make scripts available for download for some games like age of empires 2
                                  Blitzkriek,sudden strike etc.
                                  I dont mean the scripts to download the games i mean to install, configure any nesessary things the games needs including the sh script in ports
                                  So all have left to do for a user is to put the game folder in a specific location.
                                  I'm asking coz i dont have a clue how to run this games once wine,mesa,box86 are installed
                                  If you cannot do the scripts at least to tell me how to run for example age of empires 2 or sudden strike?? Or to put a small guide/example how to run games
                                  And finally age of empires and other window games needs directx how do i install this with wine? Or its not necessary?
                                  Thanks in advance
                                  Rpi3B+ USB 2.0 Boot HDD Hitachi 40GB 5400rpm
                                  Rpi4 4GB rev1.4 USB 3.0 Boot HDD Hitachi 160GB 7200rpm
                                    Thanks @evilcreamsicle,
                                    You may want to file an issue with the RetroPie team regarding 4k support, especially with EmulationStation. Then again, it might be an issue with kernel level support for 4k.
                                    Looks like the default carbon theme does use SVGs and it doesn't have any images for Wine or Box86. I don't know what the behavior of the theme is when that happens.
                                    Performance with regards to screen resolution seems to be a combination of many things. Beyond the limitations of the Pi 4 itself, the Mesa driver version, whether or not the emulator takes advantage of the GPU or is CPU bound, or in the case of Box86 if the program takes advantage of the GPU. I've had to experiment a lot with some games in order to get good performance. I don't know off-hand if there's a way to determine if a game is taking advantage of the GPU or is using the CPU to generate graphics.
                                    I appreciate all the work you're doing to get it working and posting about your findings. Thanks again,
                                    - George
                                      mmeoj @ecto
                                      @ecto said in Box86 and Wine on RPi4:
                                      I've also hit a wall with my latest game installs...
                                      • Resident Evil 1-3 and Dino Crisis: There are REbirth patches for those games which allow for higher resolutions and much more, but so far I've not seen any in-game graphics :(
                                      • Ultima 9 I thought taht such an old game would put up no fight, but I was wrong... :( I can't get any glide wrapper to work, and D3D mode is glitched (text overlays). :(
                                      • The Sims 1 or 2 was already hard to get running on my PC without a CD, but on my Retropie they simply refuded to work. :(
                                      • Diablo 2 with QoL patches are working phantastically on my PC, but I get a lot of rendering errors on Retropie. Vanilla D2 with widescreen patch was working well before (ddraw mode), so I would think this has to work, too. But I can't get either of the 3 (!)modes suggested in the QoL patch to work. Has cost me many hours so far ^_^;
                                      • Sid Meyers Alpha Centauri: Game starts, I can hear sound but there is ony a black screen. ;_; None of the suggested fixes have worked so far...
                                      So all in all I'm very frustrated right now. Lots of Time, and no further running games...
                                      EDIT
                                      • Diablo 2 with QoL patches works. I had to start over, probably some setting was wrong. After that it (almost) worked out of the box. Almost, because I had to change the renderer from its default (DX11, which works great on real Windows 10) to DirectDraw. I also tried glide, which looks cooler (as it has some quasi 3D rendering and working cinematics) but is much slower and has a lot of rendering errors (everyhing is in rainbow-colors until I change the resolution). I wish I could get Gl4ES to work as it seems to work for others without those rendering errors.
                                      Please note:
                                      That guy managed to launch The sims 1 on his ARM-based device in Wine using a special .EXE he mentioned about in his video.
                                      Take a look at it.
                                      • hooperreH
                                        hooperre
                                        Has anyone had increased success getting things to run from an xserver from the menu? I've had varying success depending on the game (Papers, Please and AM2R 1.1 run from EmulationStation soundly).
                                        Edit: I'd also be interested in reading more about xservers and launching them from the command line.
                                          boolean @George
                                          @george I'm not sure on what version of RetroPie you're on or which hardware you're using, but I've experienced no such thing on the RPi4. TiMidity never hangs and my Pi hasn't been restarted for over three months. TiMidity is pre-installed on RetroPie v4.7.1 but isn't configured as a service/daemon. You can execute "sudo apt-get -y install timidity-daemon" to accomplish that. By default it's configured to be started/stopped through script whenever you start an application (like DOSBox) that needs it. I've opted for installing the daemon instead and removed the start/stop commands from the scripts, but that's a personal choice.
                                            mth75
                                            @George
                                            I've tried mesa 21.3.2, Box0.2.5 and Wine 7.0~rc2 and 6.23-devel. The combo's seem to work and indeed, somewhat more performance.
                                            Regarding Wine, I installing the Bullseye bins, the Buster repro isn't updated anymore it seems.
                                            All FYI.
