    Box86 and Wine on RPi4
    box86wineqemux86windows
    475 Posts 40 Posters 295.8k Views
      mth75 @mth75
      @George
      I'm still trying to use the Mesa/Vulkan combo to experiment with Directx11 games (Thimbleweed Park :-)), not successful at the moment.
      Do you have any idea's?
      I noticed these packages ...maybe they would enable an easy way to accomplish my goal
      libvkd3d1_1.2~bullseye-1_i386.deb
      ectoE 1 Reply Last reply Reply Quote 0
      • ectoE
        ecto @mth75
        @mth75 On the Box86 channel on discord, there is a whole thread about dxvk... but sadly it will probably never(?) work on rpi4. Here is some background information about the limitations..
        • ExarKunIvE ExarKunIv referenced this topic on
        • R retropi19 referenced this topic on
          retro-devil2
          @George
          Hello again so we just tried the one line installer we made with Supreme and you= method on newest rpi images . Install failed both time . Neither worked .
          • L
            LivenCorpse
            Hey, wanted to share my experience trying to install these scripts on a raspberry RPi3 (armv7l - OS version : 4.7.20). It seems most everyone was trying this on RPi4 but I hoped that on a RPi3 I could at least get Space Cadet - 3D Pinball working.
            Basically I did everything instructed on https://github.com/GeorgeMcMullen/rp-box86wine down to the wine installation but then I started experiencing issues. All 3 modules were listed as installed but running any of the wine scripts (like winecfg) did nothing but kick you back to the splash-screen. A quick investigation found it to be a "Permission Denied" issue in logs.
            Debugging eventually made me discover my box86 was corrupted.... how I discovered that is a bit winded but I want to share it in case anyone else experienced the same vague problems.
            I thought chmoding /opt/retropie/ports/wine/bin would solve the issue but no configurations I tried (even 7777) did anything. Eventually I reasoned something corrupted during the installation phase. After uninstalling wine and box86 to reinstall them I found that box86 actually failed even though it was listed as "installed" in pi setup packages. Some of the issues were because folder liks ...build/box86 or ...build/LICENSE did not exist. Making those folders got the installation further along but then when it reached a dynarec_arm_66.c.o file (around 31% built) it kept experiencing a "fatal error." At this point I decided to try and install box86 directly using instruction at https://github.com/ptitSeb/box86/blob/master/docs/COMPILE.md and it finally passed! The only difference between these instructions and the box86.sh retropie install script was that the "-DARM_DYNAREC=1" flag was not set. I am still not sure that flag is meant to do but it was only noticeable difference between the builds.
            Now that I fixed box86 (or so I think) I tried to install wine again. After removing the code snippet
                # On RPI systems, we need to make sure Box86 is installed.
                #if isPlatform "rpi"; then
                #    if ! rp_isInstalled "box86" ; then
                #        md_ret_errors+=("Sorry, you need to install the Box86 scriptmodule")
                #        return 1
                #    fi
                #fi
            it installed successfully with no "Permission Denied" issues! However now I am experiencing a new problem.. now when running winecfg I see
            Wine requires a 3G/1G user/kernel memory split to work properly.
            and that is basically where I am now. I believe based on some quick searches on this forum and online that this is a fundamental problem with RPi3. So for now I have shelved trying to make this work... perhaps if I ever upgrade to the latest Pi module I will try again.
            Though it didn't work I do support this project as I think running old school bullet hell's on Retropie would be amazing.
              George
              Hi all,
              It's been a while since my last post. Happy new year! I don't have any updates per se, but thought I should post a reply because a few folks have had questions and comments.
              @hooperre I'd like to hear more about the issue you're experiencing. Are you running from within an existing X session? Most of my scripts try to initialize a X session with xinit and Matchbox. So there could be some issues there. I've been thinking about modifying my scripts to test if X is running already. Otherwise, there are so many other issues that can cause a game to crash. The best bet is to enable all logging and then post the results here. Or even try TwisterOS and check out their Discord channel.
              @boolean yeah I used to have Timidity installed as a service. It could be a myriad of things causing the audio issues. Once I got things stable to my own needs I kind of dropped it as nobody else complained about any issues. There have been lots of updates though since my last test, so maybe I'll revisit it.
              @mth75 Thanks for testing up the updates to Mesa, Box86, and Wine. I'll have to do the same and update the scripts. I looked at https://dl.winehq.org/wine-builds/debian/dists/buster/main/binary-i386/ and it looks like that is still being updated for Buster. I agree with @ecto though in that DXVK may never work completely on the RPi4. I hope to be proven wrong on that though. I've played around with a lot of Vulkan demos on the RPi4 and they all seem to work really well.
              @retro-devil2 Were you able to resolve your issue? Can you provide more info on the RPi image that you were using? I'd like to dig in if possible.
              @LivenCorpse I'm glad to hear you resolved your issues with getting Box86 to compile. For the issue with running on an RPi3 though, I've not done it, and for the exact reasons you have also come across. You need to recompile the Kernel to configure it for a 3G/1G memory split. You may have already seen the following pages, but they may help:
              • https://retropie.org.uk/forum/topic/29388/guide-diy-wine-and-retropie-legacy-driver-raspberry-pi-3b/44
              • https://thepigamer.blogspot.com/2021/01/making-wine-and-box86-work-under.html
              • https://gist.github.com/MIvanchev/14de59fa2552d315ac74c30cf1c0b01e
              • https://github.com/alwint3r/crosscompile-raspberrypi-kernel-docker
              Personally, I'd be looking at how to cross compile from withing a Docker container. If you're really interested in Space Cadet on Raspberry Pi, you might be interested in the work someone has done to make it cross platform compatible. The source is on GitHub (not sure if I'd be able to post it here), you'd need the original assets from the game, but other folks have tried it and say it works excellently. I haven't tried it out yet, but looking forward to doing so.
              If you'd like to see how some open source Linux x86 games run with Box86 on RPi3, you can check out another repository of mine. https://github.com/GeorgeMcMullen/rp-box86-games
              Lastly, this is my own little task list of things to do.
              • Do some kind of detection to determine if X is already running before trying to launch X. I've done some research on different methods of doing this.
              • Test updates to Mesa/Box86/Wine
              • Push the emulator branch to main, as it seems that's really the way to go
              • Test and play more games!!!
              - George
              L 1 Reply Last reply Reply Quote 1
              • L
                LivenCorpse @George
                @george Hey thanks for the guidance and the links to those x86 games to try out! The scripts in that repo had the flag
                rp_module_flags="!all rpi4"
                Which I had to comment out to install but each one works!... sort of. Both "Pleet The Bear" and "Maldita Castilla" are unplayably slow. I was seeing the thermometer icon consistently when playing MC. "Defend GUIN" had no performance issues even if reaching a "game over" meant you have to restart the raspberry pi. I would say the flag check for rpi4 is unnecessary for all of these ports considering they do (though very slowly) work.
                This is after of course I checkout-ed the "emulator" branch for Box86 and Wine repo you have. Without it none of the box86 games ran because the rom folder (and emulationstation configs) didn't exist... Also that branch fixes a lot of the folder issues I had faced when trying to first run the main branch. For RPI3 I still had to customize the box86 installation following https://github.com/ptitSeb/box86/blob/master/docs/COMPILE.md Can isPlatform or some other helper commands be used to do this custom install for legacy raspberry pi modals?
                Considering how slow even "Pleet The Bear" was on my hardware I have doubts old bullet hells would fair better. Maybe its an optimization thing since PTB was pre-compiled but still... I have a steam link setup with a windows 10 machine so that honestly is the easiest route to get that working. Cross-plateform space cadet might be a future project haha.
                  George
                  @LivenCorpse Since RPI4 has a different GPU than RPI3, one possibility is that Mesa might perform differently on the two devices. You could try to change the following line in the script:
                  export LD_LIBRARY_PATH="/opt/retropie/supplementary/mesa/lib/:/opt/retropie/emulators/box86/"
                  to
                  export LD_LIBRARY_PATH="/opt/retropie/emulators/box86/"
                  That would keep the script from using MESA for OpenGL and then just use whatever was installed on the device. I haven't tested it of course. It might not work at all.
                  isPlatform can be used to customize different installation paths during installation, but not when running the game (I think). So if something is required on one platform vs. another, that would be the way to test what platform you are on.
                  - George
                    retropi19 @George
                    Hello im trying to create a shell script to launch a wine game my setup in the script is that:
                    #!/bin/bash
                    xset no blank
                    cd "/home/pi/RetroPie/roms/wine/games/aoe2"
                    qjoypad "empires2" &
                    wine /home/pi/RetroPie/roms/wine/games/aoe2/empires2.exe
                    i tried to run the script from emulation station from the ports section and from cli but i get this errors in the photo:
                    any help?
                    Rpi3B+ USB 2.0 Boot HDD Hitachi 40GB 5400rpm
                    Rpi4 4GB rev1.4 USB 3.0 Boot HDD Hitachi 160GB 7200rpm
                      MumboJumbo
                      Hi all, just installing on my Raspi4 via George's script on a new Retropie installation. Downloaded the script from Repo and try installation over Retropie-Setup
                      @George don't know if it concerns the script but when running box64 install i got the error that it couldn't build because it hasn't found the docs/Licence file after looking in the box64 repo i saw that they moved the file back to root. After copying the file into docs folder i could continue installation
                        MumboJumbo @MumboJumbo
                        Too happy too early^^ copying the file is not enough i had to change the script
                        I added the copy command in the box86.sh right after the cloning
                        function sources_box86() {
                            gitPullOrClone "$md_build" https://github.com/ptitSeb/box86.git "$(_latest_ver_box86)"
                            cp /home/pi/RetroPie-Setup/tmp/build/box86/LICENSE /home/pi/RetroPie-Setup/tmp/build/box86/docs/LICENSE
                        this worked
                          After try and error and repeated careful reading here i found my faults. I used the master Branch of the script and not the emulator branch. The master branch has a bug with the license file and doesn't add box86 and wine to systems in Retropie it also add wine as Port which makes it trickier to add roms. I noticed after copying the spacecadet.sh from the space cadet branch in retropie setup. After all that i deleted wine and box86 and reinstalled it from the emulator branch then i could finally start space cadet an it works :) at the beginning in a small screen and without sound but it worked.
                          Don't know when the sound dissappeared but i had to do
                          sudo apt -y purge "pulseaudio"
                          then it worked again after reboot the little window problem was even easier just added
                          -fullscreen
                          to the end of the sh file in roms/wine folder
                            Managed to get Starcraft(1.16.1) running by just copying the installed folder in wine/Files then adding starcraft.sh in wines folder. Now the Game start fails on first try but then it starts repeatable. So part success
                            R ectoE 2 Replies Last reply Reply Quote 0
                              retropi19 @MumboJumbo
                              @mumbojumbo said in Box86 and Wine on RPi4:
                              I installed wine box and mesa from george script after when i run a game eg "age of empires2"
                              Sometimes it has sound and some other times not
                              I checked if pulseaudio is installed to remove it and its not installed,any suggestions what i do to have always sound?
                              • ectoE
                                ecto @MumboJumbo
                                @mumbojumbo That's very interesting! I tried it, too, but it isn't working for me.
                                I downloaded Starcraft from battle.net (it's free and has a 32bit binary) transferred the folder to my pi and started it with starcraft/x86/starcraft.exe -launch.
                                I tried that on my windows pc and starcraft can be started that way without battle.net login.
                                So far I had no luck with wine 7.0, wine-staging 7.0 or wine-staging 5.15.
                                So I assume it must be the version (mine might be 1.18). Could you please post the contents of your starcraft.sh file?
                                Oh and also it's normal that you have to try to start wine games more than once. Idk why, but it's a common thing...
                                  MumboJumbo @ecto
                                  @ecto the content of the starcraft.sh is:
                                  #!/bin/bash
                                  xset -dpms s off s noblank
                                  cd "/home/pi/RetroPie/roms/wine/Files/SC/"
                                  matchbox-window-manager &
                                  WINEDEBUG=-all LD_LIBRARY_PATH="/opt/retropie/supplementary/mesa/lib/" setarch linux32 -L /opt/retropie/emulators/wine/bin/wine '/home/pi/RetroPie/roms/wine/Files/SC/StarCraft.exe' -fullscreen
                                  And for the failed start I set my Windows Version in winecfg to XP now it starts on first try
                                  • ectoE
                                    ecto @MumboJumbo
                                    @mumbojumbo Thanks for the script! I doesn't look much different from my script... maybe I could try the -fullscreen switch, but I think it might be my newer version that doesn't start.
                                    I'll try to look for a way to downgrade...
                                      MumboJumbo @ecto
                                      @ecto I now also tried the newer starcraft but i can't open too. It just crashes back to emulationstation.
                                      i used this sh
                                      #!/bin/bash
                                      cd "/home/pi/RetroPie/roms/wine/Files/StarCraft/"
                                      WINEDEBUG=+loaddll BOX86_LOG=1 LD_LIBRARY_PATH="/opt/retropie/supplementary/mesa/lib/" setarch linux32 -L /opt/retropie/emulators/wine/bin/wine '/home/pi/RetroPie/roms/wine/Files/StarCraft/x86/StarCraft.exe ' -launch -fullscreen
                                      ectoE 1 Reply Last reply Reply Quote 1
                                      • ectoE
                                        ecto @MumboJumbo
                                        @mumbojumbo Thanks for trying! I downgraded to v1.16 and it works out of the box.
                                          MumboJumbo @ecto
                                          hmm is there a possibility to pass winEviroment (xp,2000) to wine from sh?
                                            I tried wine"7.0.0.0" and mesa-21.3.6. The scripts were able to build by just replacing the version and Space Cadet and Starcraft(v1.16) are still working seems good so far
