    problem with saving Retropie
    savesretro pie
    28 Posts 3 Posters 5.8k Views
      mitu Global Moderator @Siwobrody
      Nothing new in the logs, it looks like RetroArch tries to save the state, but there's no explicit error. You don't see the save state file - 1942.state5 - on disc ? Can you still copy ROMs on the disc, without any errors ?
      Try to run a disc check on your hard disc from your PC, just to make sure that the disc is ok and there's no filesystem corruption on it.
        Siwobrody
        I tried to copy roms and there were no problems. But maybe because of my traveling and taking PI with me maybe something 'broke' and I will have to do everything all over again ... it just hurts the whole library full of everything and hours spent waiting;)
          Siwobrody
          ifound also sth like that:
          https://www.reddit.com/r/RetroPie/comments/6asyif/permanent_0_saving_state_whenever_saving_states/
          it could work ? but how to change ?
            @siwobrody said in problem with saving Retropie:
            I think it's referring to set
            savestate_auto_index = true
            in the retroarch.cfg file.
              Siwobrody
              eh, still nothing :(
              i have no more ideas. It looks like retroarch have a problem to save on usb drv. Maybe i have something wrong inside, should i change something? Maybe retroarch try to save on sd card i dont know...how it works.
              saccublendaS 1 Reply Last reply Reply Quote 0
              • saccublendaS
                saccublenda @Siwobrody
                @siwobrody Try moving your old save states to a different directory
                  Siwobrody @saccublenda
                  @saccublenda i deleted all old save states and still same. I have no ideas..
                  • saccublendaS
                    @siwobrody Me neither. As a last check you can try setting the savestate_directory key in /opt/retropie/configs/all/retroarch.cfg to something else, for example savestate_directory = "/home/pi".
