Controls randomly locked for 1 or 2 secs
Hi everyone
I did started to notice that sometimes, controls have a "blind" short period. If you are pointing towards specific direction or pressing some button, it will automatically repeat that for 1 or 2 secs even if you released your stick or button ... same if you are not pressing anything nor pointing stick to any direction, it will not detect any new input for 1 or 2 secsThis does not happen very often, thankfully, but it is really noticeable when it happens. It means you can't play for that period of time.
I have my retropie fully updated running on PI4 2G, I've seeing this on games and emulators as diverse as Asteroids Deluxe in lr-mame2003 and Virtua Tennis 2 in lr-flyCast.
I'm using USB zero delay encoders for my 2 players controls, works like a charm leaving this...Somebody experienced something similar?
Thank you! -
@niktus81 Nope, sorry. I can't relate. I'm on a 3B and a 3B+.
@kounabi22 glad to hear I'm not the only one... not sure if this is a hardware thing or software configuration
@niktus81 Does it happen in non-Libretro emulators?
@iandaemon at the time, I think I'm not using any emulator that is not libretro, but if I find that it happens in that scenario too, I'll let you know
@niktus81 I had the same thing on every core I have, including redream, amiberry and all the libretro cores. It started after a system update on my pi 4, and I found that the control lock was only happening when my audio was set to use the 3.5 jack as audio source. I replaced my very old monitor to newer one and changed my audio settings to HDMI. I checked this issue long time and every time I return to audio through the 3.5 jack, the issue return. HDMI setting works fine.
@rott42 Thanks for the information, really useful.
I'm using 3.5 jack for audio connected to a power amplifier and speakers for the audio system, but I can try to change audio output and check what happens in that case. -
@niktus81 I feared running into problems with the 3.5mm jack so I have the HDMI cable running into a device that separates the audio and video signals. I send the video to a television and the audio to an amp.
I didn't see this post, but also just posted about what sounds like a very similar issue I'm having. It seems to be most common for me with analog sticks in N64, but may also be a general system issue like you're mentioning. Same timing where it started with the latest big retropi update.
https://retropie.org.uk/forum/topic/29519/controllers-cut-out-briefly-in-n64-emulators
I also use audio output to my 3.5 jack as well since I use a CRT and an amplifier hooked up to speakers. I can try to switch to HDMI audio tomorrow and see if that does anything.
Well this was it! I went into raspi-config and switched to HDMI audio and it COMPLETELY SOLVED THIS PROBLEM. Who would have thought that an audio setting would somehow make controllers stop working for a few seconds.
@toigo I found it by an accident. After last big system update, I've noticed that my audio was off. It seemed that the update changed my audio to HDMI settings. As soon as I switched the audio settings back to the 3.5 jack, the issue with the controller started. I switched again to HDMI and the problem was solved. I guess some firmware update causes this issue, but I am not an expert. Glad it was solved, but it seems that the 3.5 jack on the pi is unusable for me now.
I did not have the time to do some tests like you people did, but it is good to know what it seems the root cause for this problem.
Amazing that a simple thing as an electric audio signal can have this kind of impact.
As I´m using an old 19 LCD square monitor and a power amplifier for the sound, HDMI is not in my universe right now, so I´m stuck here.Really hope for some kind of firmware update to solve this issue.
Thank you all for your replies! -
Solution confirmed, found a way to extract audio signal from HDMI cable, never again a freeze with controllers ... hope that the problem with 3.5 is solved anyway at some point
well i buy from ebay a converter but i have no audio output....try some sound option but no luck.
converter works with other hdmi like tv -
ok found a solution only in one hdmi(the one near the power plug) the audio work
I also do have this problem with an up-to-date Retropie 4.7 on my Pi 4. Since I had a similar hdmi converter lying around, it became my provisional solution for now.
Let's hope that future updates of Raspberry Pi OS will fix this issue someday.
@kounabi22 said in Controls randomly locked for 1 or 2 secs:
Strangely, on my system only the other hdmi port away from the power plug has video and sound. 😛
@clyde said in Controls randomly locked for 1 or 2 secs:
weird......
@rott42 said in Controls randomly locked for 1 or 2 secs:
been going crazy trying to fix this issue. got another microsd card and imaged it to see if that fixed it. Nothing would work. Switched from a monitor to TV and changed to HDMI for audio and it fixed the issue.
Just to confirm i got it right:
as soon as you use the 3,5" jack for audio you run into these problems with USB-Controllers?
So the Pi2Scart Device is also useless as it uses the 3,5"-Jack to get the audio-signal?
