    PS3 Controller Will Not Pair v4.7.7
    ps3 controllerbluetooth
    15 Posts 5 Posters 1.3k Views
      A Former User @mustangfanatic01
      @mustangfanatic01 Thanks for the info, I take your point on getting a PS4 controller and may well end up down that route but its for my brother.
      How did you go about loading the old ps3controller driver?
        mustangfanatic01 @A Former User
        @plangham
        I'm also making one of these for my brother, and that's why I'm just going to get him a PS4 controller. If it's difficult/frustrating for me, he's never going to figure it out when it starts acting flaky.
        I pretty much followed the guide:
        https://retropie.org.uk/docs/PS3-Controller/
        Since I had first gone the sixaxis route, I ended up removing all the installed packages under [Manage Packages] -> [Driver]. Then I installed the ps3controller driver, and tried configuring it through there as well. I think I did have to then back out to Emulation Station and go to Bluetooth and follow the pairing instructions there. (have it plugged in via usb, remove it, press PS button, then plug back in. Then it said it worked and when I unplugged it from usb it paired after a few seconds). It took a few tries, the whole process was very frustrating.
        My experience with the PS4 controller on a brand new RetroPie image was to go to Bluetooth, search for devices, put the PS4 controller in pair mode (hold Share + PS buttons), and it found it immediately. No extra drivers or fuss. If it was the first controller connected, it lights up blue (Player 1). If I had another controller connected already it lights up red for Player 2.
          mustangfanatic01
          I should mention that in the configuration I only saw options for Gasia and Shanwan (and clone variants). My faux ps3 controller showed up as Gasia (when you "Configure Input" in EmulationStation), so I tried both Gasia options I saw in there. I think Gasia (Clone) was what ended up working for me. Lot of trial and error
            pscotto1234
            I'm having same issue. The strange thing is that I have 2 raspberry pi 4 and I can easly pair my controller only with one of them. When I install the uSD in the other raspberry I cannot have the controller paired.
            Any suggestions?
              pscotto1234
              Hi all,
              after testing several raspberry it seems that problem is related to the hardware version.
              Calling cat /proc/cpuinfo I see that the working model has a Hardware Revision B03112 while all others non working models (6 different raspberry) have Hardware Revision B03112.
              Any suggestion? @mitu do you know if is there a bug on this revision?
                mitu Global Moderator @pscotto1234
                @pscotto1234 said in PS3 Controller Will Not Pair v4.7.7:
                I don't see a difference between the revisions you've posted.
                No, I don't think so.
                  pscotto1234 @mitu
                  @mitu sorry. I mean B03114 not working; B03112 working.
                  I tried with a clean 4.7.1, a 4.7.9 and a 4.7.11
                    @pscotto1234 Based on https://www.raspberrypi.org/documentation/hardware/raspberrypi/revision-codes/README.md,
                    • b03112 is Revision 1.2, 4Gb model.
                    • b03114 is Revision 1.4, 2GB model.
                    is that correct ?
                      pscotto1234 @mitu
                      @mitu no, I have only 2GB RAM model.
                        @pscotto1234 After moving the sdcard to the other system, you should remove any connected devices before attempting pairing - have you tried that ?
                          pscotto1234 @mitu
                          @mitu yes, I removed all device from the menu “Remove Bluetooth Device”.
                          I’m going crazy trying to solve!
