    Rom transfer through USB-stick troubleshooting
    rom transferusb transfer
    22 Posts 3 Posters 6.8k Views
    • ChishiyaC
      Chishiya @YFZdude
      @yfzdude
      Thank you for your suggestion, I just tried it and unfortunately I got an error message, however, it is a different error code. Sorry about the Swedish.
      • ChishiyaC
        Chishiya
        SOLVED!
        I have now solved my issue and will try and explain what I did (In case someone else goes through the same problem)
        So what I was trying to do was to connect a Windows 7 computer or a Windows 10 computer to the Raspberry Pi over the network so I could easier send files between my Windows computers and the Raspberry pi.
        What you need to do is to activate protocols in regard to network on the computers: that they are allowed to send information , that they are visible etc. You also need to make sure you have enabled SMB on the windows computer.
        Then you need to follow this tutorial on this link, this link was the final puzzle piece that solved it for me. =)
        https://pimylifeup.com/raspberry-pi-samba/
        Ps. If I have time I will see if I can post a more in-depth tutorial.
        Thank you
        @mitu for you many replies and thank you
        @yfzdude for your input as well =)
