    [Pi 4 8Go] Problem raspi-config
    pi 4 8gbraspi configretropie config
    3 Posts 2 Posters 489 Views
      Azev
      Hello all,
      I have flashed with Balena Etcher the Pi4 version 4.7.1 of Retropie. It launch and i can configure my XBox Pad but when i launch raspi-config or retropie config on the Retropie menu, i have an eternal black screen on screen, i can get out with "X" button of gamepad.
      Flash of retropie goes well, no errors , i let it doing verification.
      Anyone facing the same issue?
      Thanks in advance for your help
      Edit: I have not this problem with a Pi 3 B+ . Tested with Samsung Evo 128Gb card and HDD on both devices, no problems with 3B+ and problem with 4.
        This seems to a common problem when using a 4k display.
        Try setting up your video resolution to 1080p by adding to /boot/config.txt:
        hdmi_group=1
        hdmi_mode=16
          Azev @mitu
          @mitu Thanks for your answer, I will try it later
          Edit: It works, many thanks.
