    2.3k Posts 37 Posters 7.8m Views
    • FollyF
      Folly @DTEAM
      NEW EDIT: here: https://www.progettosnaps.net/renameset/
      you have a file category.ini (0.236) (always up to date) . Inside, you have a file named arcade.ini and one mess.ini. Everything is there to do the split.
      I have found a way to match these files with our data.
      And I think I can also match the files from http://adb.arcadeitalia.net/lista_mame.php .
      We could even add our handhelds/plug&play to it this way.
      After that I hope that I can implement it in the scripts so we can sort upon the "catagories".
      The file will look something like this :
      Driver 1292apvs (1292 Advanced Programmable Video System): *non-arcade
      Driver 1392apvs (1392 Advanced Programmable Video System): *non-arcade
      Driver 15lions (15 Lions (10166211, Queensland)): *arcade
      Driver 18w (18 Wheeler (set 1)): *arcade
      Driver 18w2 (18 Wheeler (set 2)): *arcade
      Driver 18wheelr (18 Wheeler (deluxe, Rev A)): *arcade
      Driver 18wheelro (18 Wheeler (deluxe)): *arcade
      Driver 18wheelrt (18 Wheeler (deluxe, Rev T)): *arcade
      Driver 18wheels (18 Wheeler (standard)): *arcade
      Driver 18wheelu (18 Wheeler (upright)): *arcade
      Driver 1942abl (1942 (Revision A, bootleg)): *arcade*bootlegs*cabinets
      The disadvantage is that "matching" takes some time to do.
      And I have to improve the category names.
      For instance, I want to convert "mess" into "non-arcade".
      So, for now, it's a slow development.
      Using grep we can sort on arcade , for example :
      • DTEAMD
        DTEAM @Folly
        This is really cool!!
        • FollyF
          Folly @DTEAM
          @dteam
          I am finished with the matching.
          After converting the files, so it would contain only the systems, I matched the files against our database.
          It takes about 3 hours to build.
          I uploaded the file to github :
          https://github.com/FollyMaddy/RetroPie-Share/blob/main/00-databases-00/mame/mame0236_systems_sorted_info
          For now something to check and experiment with.
          The categories that I added are :
          all_in1
          arcade
          ball-and-paddle
          board-game
          bootlegs
          cabinets
          calculator
          casino
          classich
          climbing
          clones-arcade
          computer-graphic-workstation
          computer
          digital-simulator
          driving
          fighter
          freeplay
          game-console
          gameandwatch
          handheld
          jakks
          konamih
          maze
          mechanical-arcade
          medal-game
          medical-equipment
          misc
          monochrome
          multi-game
          non-arcade
          screenless
          tigerh
          tigerrz
          • DTEAMD
            DTEAM @Folly
            @folly
            WOW !!! A lot of work ! Some of those are not playable. Will you keep them (like mechanical-arcade, medical-equipment, ball-and-paddle, board-game, etc.) ?
            • FollyF
              Folly @DTEAM
              @dteam
              I like the idea that we now can see what which system is and that the most data is included.
              I think it's not a problem that non-working systems are in there because we should be able to sort on it, if I add it from the ini files.
              If I am wrong, I can always remove some entry's.
              I did not yet add the info of these ini files :
              arcade_BIOS
              arcade_NOBIOS
              CHD (no BIOS)
              CHD Working
              Non Bootlegs
              Non Mechanical Arcade
              Not Working Arcade
              Originals Arcade
              Players
              resolution
              Working Arcade Clean
              Working Arcade
              This is the only bash code I used to add the information to the existing data file,
              using the simple .ini txt files containing the systems per category that are with or without windows line-endings :
              for file in $(ls -r *.ini);do echo busy with $file;cat $file |sed 's/\r//g'|while read line;do grep -i "Driver $line " mame0236_systems_sorted_info|sed -i "s/Driver $line .*\:/&*$(basename $file .ini)/" mame0236_systems_sorted_info ;done;done
              sed -i 's/)\:/)\: /g' mame0236_systems_sorted_info
              • FollyF
                Folly @DTEAM
                @dteam
                I have made the first working code to generate the sorted lists.
                Perhaps a bit premature as is not yet how I want it to be.
                It's just a peek in the future on how it will work.
                I must say I am very satisfied with the first tests ;-)
                (edit : third update)
                https://github.com/FollyMaddy/RetroPie-Share/blob/94f47159441265d13869eeb72fb8640b6aadb9ee/00-workdir-00/add-mamedev-systems-2v4.sh
                • menu improved
                • overall improved sorting on --dictionary-order
                • (fast)create sorted lists (and equal to) on patterns up to 5 options ($2 -$6)
                • (slower)create sorting (not equal to) on patterns for one option ($2) adding an ! after the pattern
                  (in combination with 4 (and equal to) patterns up to 4 options ($3 -$6) is possible)
                • possible to make sorted lists with "system" names
                  ( with "system description" names it was already possible )
                • DTEAMD
                  DTEAM @Folly
                  @folly
                  l’ll try it monday👍🏻
                  • FollyF Folly referenced this topic on
                  • DTEAMD
                    DTEAM @DTEAM
                    @Folly
                    Your last add-mamedev-systems-2v4.sh works very well. Great job! I like your subfolders for gamelist.xml. Some options can be confusing for newbies. Maybe you could add a logigram or a tree diagram in your first post.
                    I like this version, it's easy and full access to MESS and MAME with Artworks, cheat codes and "games scraping" for unusual systems... it's huge.
                    FollyF 2 Replies Last reply Reply Quote 1
                    • FollyF
                      Folly @DTEAM
                      @dteam
                      Thanks for the feedback.
                      Indeed I have to work on it, structuring it better.
                      This is basically caused by the fact that I am working on it.
                      First I want to make sure things are working correctly.
                      When I am done adding/testing stuff I will try to reorganize.
                      Perhaps we can discuss this later on, to make it simpler.
                      Or indeed add a diagram in the first post.
                      Perhaps you have noticed, the forum lists are now in two sections. (old and new)
                      The list can now be build up from the new database we created.
                      Basically this means I can remove it from the old section, where it used it's own data.
                      Well, I have noticed now, working on it, that there is still much to be added and things that have to be changed.
                      Btw.
                      You can experiment with making some sorting lines, if you want.
                      That way we can build the new lists that are important to be in there.
                      You can add it between lines 86 and 107, and share them if you like.
                      • FollyF
                        Folly @DTEAM
                        @dteam
                        I did a huge update.
                        You can test some new stuff ;-)
                        https://github.com/FollyMaddy/RetroPie-Share/blob/432d2c9db4b1497ba2da938cef1968621c5c2570/00-workdir-00/add-mamedev-systems-2v4.sh
                        Front-end 2v4 improved
                        • cleaned up a bit
                          (removed tho old forum selection list, now there is a new one)
                          (removed some functions and added some functions)
                        • re-ordered the menu
                          (hopefully, in time, it will evolve into a better and simpler structure)
                        • add experimental help lines
                          (perhaps not a definitive solution !)
                        • add saving and removing database file locally (for offline usage)
                          (file is save in or deleted from : /opt/retropie/emulators/mame)
                        • add more sorted lists (remove test lines)
                        • add SEARCH form, to create a sorted list on the fly
                          (still an issue in the dialog form : "cancel" button doesn't work)
                        • add download option with form
                          (only available with the correct input !)
                          (still an issue in the dialog form : "cancel" button doen't work)
                        • DTEAMD
                          DTEAM @Folly
                          @folly
                          When I updated Retropie, something happened with my Retropie Setup. I can't run Retropie Setup anymore. I suspect the Valerino script. Any idea. Maybe it's helpers.sh.
                          • FollyF
                            Folly @DTEAM
                            @dteam
                            Don't know.
                            You can try and rename the directory and git clone the repository again.
                            That way you have the whole directory fresh and a backup of the old directory.
                            Then try if it works ! (edit)
                            Later you can copy the module-scripts, you had, back in.
                            Is it a solution ?
                            • DTEAMD
                              DTEAM @Folly
                              @folly
                              I already copy fresh files from here
                              I'll try to do some cherry picking from here
                              • FollyF
                                Folly @DTEAM
                                @dteam
                                I just did my trick here, using :
                                Renaming the old RetroPie-Setup to RetroPie-Setup.old
                                cloning :
                                cd
                                git clone --depth=1 https://github.com/RetroPie/RetroPie-Setup.git
                                running (4.7.19) :
                                cd RetroPie-Setup
                                sudo ./retropie_setup.sh
                                Looks fine here, so I suspect it's something else.
                                If you have it running I recommend you add our -ext script from now on in :
                                /home/pi/RetroPie-Setup.ok/ext/RetroPie-Share/scriptmodules/supplementary/add-mamedev-systems-2v4-ext.sh
                                This places all generated module-scripts in :
                                /home/pi/RetroPie-Setup.ok/ext/RetroPie-Share/scriptmodules/libretrocores
                                And in the RetroPie-Setup they will be arranged on external repository name .
                                • DTEAMD
                                  DTEAM @Folly
                                  cd RetroPie-Setup
                                  It's do this:
                                  pi@retropie:~ $ cd RetroPie-Setup
                                  pi@retropie:~/RetroPie-Setup $ sudo ./retropie_setup.sh
                                  sudo: ./retropie_setup.sh: command not found
                                  or this
                                  pi@retropie:~/RetroPie-Setup $ sudo /home/pi/RetroPie-Setup/retropie_packages.sh
                                  /home/pi/RetroPie-Setup/scriptmodules/packages.sh: line 903: source: /home/pi/RetroPie-Setup/scriptmodules/supplementary/add-mamedev-systems-2v4.sh: cannot execute binary file
                                  Module  is missing valid rp_module_id
                                  Module  is missing valid rp_module_desc
                                  FollyF 3 Replies Last reply Reply Quote 0
                                  • FollyF
                                    Folly @DTEAM
                                    @dteam
                                    remove our script
                                    and try to run the setup again without it.
                                    You should use this :
                                    Could you check the permission of the files again for me ? :
                                    I have :
                                    pi@raspberrypi:~/RetroPie-Setup $ ls -l
                                    total 76
                                    -rw-r--r-- 1 pi pi   146 Oct 28 21:16 AUTHORS
                                    -rw-r--r-- 1 pi pi   417 Oct 28 21:16 CONTRIBUTING.md
                                    -rw-r--r-- 1 pi pi   635 Oct 28 21:16 COPYRIGHT.md
                                    -rw-r--r-- 1 pi pi 32265 Oct 28 21:16 LICENSE.md
                                    -rw-r--r-- 1 pi pi  2033 Oct 28 21:16 README.md
                                    drwxr-xr-x 2 pi pi  4096 Oct 28 21:16 ext
                                    drwxr-xr-x 2 pi pi  4096 Oct 28 21:53 logs
                                    -rw-r--r-- 1 pi pi  6374 Oct 28 21:16 platforms.cfg
                                    -rwxr-xr-x 1 pi pi  2314 Oct 28 21:16 retropie_packages.sh
                                    -rwxr-xr-x 1 pi pi   520 Oct 28 21:16 retropie_setup.sh
                                    drwxr-xr-x 7 pi pi  4096 Oct 28 21:16 scriptmodules
                                    • FollyF
                                      Folly @DTEAM
                                      @dteam
                                      Do you have these permissions for the file ? :
                                      ls -l
                                      -rw-r--r-- 1 pi pi   520 Oct 28 21:16 retropie_setup.sh
                                      Then it's not executable, and you will get :
                                      pi@raspberrypi:~/RetroPie-Setup $ sudo ./retropie_setup.sh
                                      • DTEAMD
                                        DTEAM @Folly
                                        @folly
                                        The problems seems to be your script. I removed it and now it's fine.
                                        • FollyF
                                          Folly @DTEAM
                                          @dteam
                                          That sounds bad.
                                          I don't have any problems over here.
                                          I will pull it from github to see if I get any problems.
                                          I assume it was the latest.
                                          edit:
                                          I installed everything fresh on my x86 laptop too.
                                          I found some compatibility problems for the sorted lists, so I will look at that.
                                          But no problems in crashing or recognising whatsoever.
                                          Did you try to edit the script and perhaps made a mistake in doing so ?
                                          Can you open the script into a text editor to check if it's a good file ?
                                          • FollyF
                                            Folly @DTEAM
                                            @dteam
                                            I don't expect it, but be sure you don't saving it as a html file :
                                            (right-click on raw and download should download the correct file)
                                            https://retropie.org.uk/forum/topic/29682/development-of-module-script-generator-for-lr-mess-and-mame-standalone/789
