SEGA Model 2 works very well on MAME standalone. You need recent roms to do it. It's at full speed or almost and the sound is a little bit choppy (Daytona).
I have try this in the mame.ini file (no impact or little),:
video bgfx bgfx_path /opt/retropie/emulators/mame/bgfx bgfx_backend vulkan bgfx_screen_chains default
Did I make an error?
I read that you're supposed to enable
MESA_VK_WSI_PRESENT_MODE = relaxed
in a .sh file before loading MAME, but I have no idea how to do it. I don't know if it's necessary. Can you try it please?
I just tried in the terminal but it does not seem to have any impact.
pi@debian-13:~$ MESA_VK_WSI_PRESENT_MODE = relaxed bash: MESA_VK_WSI_PRESENT_MODE: command not found pi@debian-13:~$ MESA_VK_WSI_PRESENT_MODE=relaxed pi@debian-13:~$ /opt/retropie/emulators/mame/mame daytona Average speed: 82.30% (50 seconds) pi@debian-13:~$ echo $MESA_VK_WSI_PRESENT_MODE relaxed
First line does not work because of spaces.
Second line works and changes the environment variable.
Then I run daytona
In the last line you see that the variable is still contains relaxed.This is without :
pi@debian-13:~$ echo $MESA_VK_WSI_PRESENT_MODE pi@debian-13:~$ /opt/retropie/emulators/mame/mame daytona Average speed: 83.69% (47 seconds)
Empty line means that the variable is empty.
You see it makes no difference. -
video bgfx
bgfx_backend vulkanbgfx_screen_chains default
I honestly do not know.
I tried more games and indeed they work pretty well, however i am using a x86_64 laptop with 3.5Ghz cpu.
I like hotd, though you have to use the service button first to change the local settings.
And if you want to shoot with the mouse you have to enable that in the mame.ini (mouse = 1).
To refill your gun you need to aim to the edge of the screen and shoot (I think). -
To refill your gun you need to aim to the edge of the screen and shoot (I think).For Sega Model 2 with MAME, some games have sound issues (choppy) and slightly speed issues, but some games like Dynamite Cop, Manx TT, OverRev (better graphics with Vulkan), Sega Water Ski, Sky Target, The House of death, VirtuaCop 2, Wave Runner and more work perfectly on a Pi5 (64 bit) !!!! It's impressive.
New edit: I added this in my mame.ini file:
video bgfx bgfx_path /opt/retropie/emulators/mame/bgfx bgfx_backend vulkan bgfx_screen_chains default video accel syncrefresh 1 #samplerate 11025 #samplerate 22050 samplerate 44100 #samplerate 48000 mouse 1 multimouse 1
For some games, I reduced the sound quality a little bit. Some games run well at 48000 and you don't need to do that.
D DTEAM referenced this topic
Do you use frameskipping too?
No
Mame binary for Trixie aarch64 for rpi 3,4 and 5 has been added
@DTEAM @Folly How do you/ can you get Pc98 hdi disks to run under MAME standalone in the retropie? or Lr-Mame, etc? There is a pc98 game outside retropie that works with Mame but not NP2kai. On Retropie 4.X it also does not run under NP2Kai. I was wondering if I can/could test it with MAME in Retropie?
@duglor said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
@Folly @DTEAM How can I run Bubsy for Jaguar under lr-Mess? or Mame standalone? not virtual Jaguar.
Just tried bubsy on jaguar for you.
Sadly the game crashes at the beginning after the exclamation mark appears.
Seems this game doesn't work with mame. -
It could work in mame standalone.
For lr-mame it doesn't work as in retropie lr-mame is arcade only, you would need lr-mess then.There is a pc98 game outside retropie that works with Mame but not NP2kai. On Retropie 4.X it also does not run under NP2Kai. I was wondering if I can/could test it with MAME in Retropie?
You should be able to install pc9801 with harddisk support OOB from the menu item :
Choose and install systems with default settings
Then use the runcommand mame-pc9801-hard to load the harddrive directly.
It has support for these types of harddrive images :
pc9801 harddisk (hard) .chd .hd .hdv .2mg .hdiPS.
Not tested but it could work. -
Seems this game doesn't work with mame.Bubsy works well on my side at full speed. Iām using Vulkan with Mame and Lr-virtualjaguar
@DTEAM @duglor
Got it working too.
Pressed a button to start the game before the exclamation mark comes, then I can play. -
You should install jaguar from the menu item :
Choose and install systems with default settings and select or insertjaguar
The script will use the retropie install nameatarijaguar
Copy the jaguar.zip bios to the BIOS/mame folder.
Get the jaguar.zip soflist roms and unzip the roms to the atarijaguar rom folder.
That should do the trick.
