      RussellB @Folly
      @russellb said in Development of module-script generator for lr-mess and mame standalone:
      @folly,
      Can I recommend moving the location of the run_mess file away from the home directory and into something like /opt/retropie/scripts? I moved it because I don't like having rom dependencies in the home folder.
      RussellB
      I understand what you mean, but there problems doing it that way.
      The problem is, the run_mess.sh script is within the fork of @valerino of the RetroPie-Setup.
      So when you clone the repository the run_mess.sh script is already there.
      In the github Repositories you don't have the directories /opt/retropie/...... .
      If you want it there you have to "install/copy" it.
      So that is why it's in that place.
      If we really want this, all the 30+ valerino scripts have to be changed by hand.
      And you have to make an installer part for the run_mess.sh.
      I don't think Valerino has time for that.
      I could change my script, but then it isn't compatible anymore with the Valerino fork.
      An other reason not put in /opt/retropie/...... is, you have to be "root" to copy it in that folder.
      My generator script, the one without the front-end gui, can be run without root user.
      I like to keep it that way.
      So overall, it is better to keep it this way to avoid problems.
      I hope you understand.
      Got it. Thanks.
      • FollyF
        Folly @DTEAM
        @dteam
        Here a small update on the progress on the front-end module script :
        I am working on the front-end module-script add-mamedev-systems-test5.sh.
        I have made some progress in rebuilding and building stuff into the front-end.
        I can now generate sub-menu's for #,A,B,C etc .
        But I can't show the systems already in there, this seems quite difficult at the moment.
        Progress is really slow at the moment.
        I have to leave it for a while and re-think my approach again.
        I hope I can find some better/easier ways.
        Another idea is to make this script in such a way that I can just copy and paste my generate-systems-lr-mess_mame-2v0-alpha.sh into the front-end module-script.
        That way I can just maintain the 2v0 script and paste it into the front-end each time when I update it.
        • DTEAMD
          DTEAM @Folly
          This is what I am doing at the moment with V1.8.
          • FollyF
            Folly @DTEAM
            @dteam
            Ok, yes indeed you can do that too.
            Btw. I have been keeping 2.0 and 1.8 both up to date.
            • DTEAMD
              DTEAM @Folly
              @folly
              I know. I updated my cdimono1 with v1.8 to see what RussellB did.
              I'm running adam for coleco_sgm with MAME. I created a separate folder for that (coleco_sgm). Everything goes well exepted the MAME UI menu. I'm not able to go in. Have you a solution for that. It's the first time I met this problem.
              mame-system-adam-cart1 = "/opt/retropie/emulators/mame/mame -v -c adam -cart1 %ROM%"
              • FollyF
                Folly @DTEAM
                @dteam
                You should use the scroll-lock key to toggle between FULL and PARTIAL emulation.
                With PARTIAL the UI should be enabled.
                If this doesn't work we have to look further.
                • FollyF
                  Folly
                  @RussellB
                  I added your edited code to my repository.
                  I also added it to my standalone scripts :
                  generate-systems-lr-mess_mame-1v8-alpha.sh
                  When running above script, the run_mess.sh script is always updated by the script.
                  https://github.com/FollyMaddy/RetroPie-Share/tree/main/00-scriptmodules-00
                  This shows the difference betweem the original and yours :
                  https://github.com/FollyMaddy/RetroPie-Share/commit/5f915ca6d2e05f3ff6f0dc7fe6b8ff21ca1d6677
                  • FollyF
                    Folly
                    @DTEAM @RussellB
                    I did one test.
                    Can you both do some tests too ?
                    I like to know if it still works ok.
                    • DTEAMD
                      DTEAM @Folly
                      @dteam
                      Fixed. It was a simple problem with my default.cfg file in /home/pi/RetroPie/roms/mame/cfg
                      Not a real issue
                      • FollyF
                        Folly @DTEAM
                        @dteam
                        Indeed, I was thinking you knew about the scroll-lock part ,so indeed it had to be something else.
                        Nice to have that one fixed !
                        • DTEAMD
                          DTEAM @Folly
                          I did one test.
                          Nothing happens for me. Is It supposed to generate a .cmd (per game) file in /home/pi/RetroPie/roms/cdimono1 when we load a game?
                          It works
                          • FollyF
                            Folly @DTEAM
                            @DTEAM
                            Nice to hear it works !
                            I think @RussellB will test it with some bezels, don't you think too ?
                            • FollyF
                              Folly
                              For those who are reading these posts and really don't know what the run_mess.sh does :
                              The run_mess.sh makes a temporary <game>.cmd file to start the game with lr-mess and adds all the necessary things in this .cmd file to start the game correctly .
                              The original version of run_mess.sh always made the same <game>.cmd named tmpmess.cmd .
                              After you have played the game, this tmpmess.cmd file is removed again.
                              The edited version of run_mess.sh now makes the <game>.cmd named after the game.
                              That way it's unique per rom/game.
                              This allows us to specify custom configs, including bezels and screen locations, etc. per rom/game that wasn't possible with the original run_mess.sh.
                              • DTEAMD
                                DTEAM @Folly
                                @folly
                                SOLVED : For Coleco_sgm, I'm trying set scroll-lock automaticly when we the system load.
                                Any idea you need -ui_active
                                mame-system-adam-cart1-autoframeskip = "/opt/retropie/emulators/mame/mame -v -c -autoframeskip adam -ui_active -cart1 %ROM%"
                                • FollyF
                                  Folly @DTEAM
                                  @dteam
                                  I tried this :
                                  mame-system-adam-cart1-ui = "/opt/retropie/emulators/mame/mame -v -c adam -uimodekey TAB -cart1 %ROM%"
                                  Now the TAB works as (SCRLOCK + UI) button at the same time.
                                  Seems quite nice, you preserve FULL keyboard emulation until TAB is pressed.
                                  Edit :
                                  I will try that -ui_active too.
                                  OK, that works too, nice finding !
                                  It looks like you boot in PARTIAL keyboard emulation.
                                  Don't know if that could be a problem.
                                  We should do some more tests.
                                  This would be nice function to add, it could make things much simpler..
                                  • DTEAMD
                                    DTEAM @Folly
                                    @folly
                                    It works also for Lr-Mess .
                                    lr-mess-system-adam-cart1 = "/home/pi/RetroPie-Setup/scriptmodules/run_mess.sh /opt/retropie/emulators/retroarch/bin/retroarch /opt/retropie/libretrocores/lr-mess/mess_libretro.so /opt/retropie/configs/coleco_sgm/retroarch.cfg \adam /home/pi/RetroPie/BIOS/mame -autoframeskip -ui_active -cart1 %ROM%"
                                    • DTEAMD
                                      DTEAM
                                      Could be nice to add one of these functions.
                                      Absolutely
                                      • FollyF
                                        Folly @DTEAM
                                        @dteam
                                        Great to hear that this also works on lr-mess !
                                        Did you try "-uimodekey TAB" too ?
                                        What do you think?
                                        • DTEAMD
                                          DTEAM @Folly
                                          What do you think?
                                          It changes Scroll lock for TAB. Same problem if you don't have a keyboard.
                                          -ui_active is the best option for me. I don't see problems. Most of the time, It's already activated.
                                            RussellB @Folly
                                            @folly I've tested this with mess running tic-80 games, Sega VMS, and CD-i and each game gets its own config file. I had config files already from the bezelproject for CD-i and they immediately came up as it was no longer reading tmpmess.cmd. Looks good from my testing.
                                            FollyF 2 Replies Last reply Reply Quote 1
