    • FollyF
      Folly @DTEAM
      @dteam @mitu
      I compiled mame0233 succesfully in 6 hours on the rpi4 with 8Gb with 32bit buster.
      I increased the swap to rpSwap on 51200 in the mame module-script.
      I booted the RPI4 with a big USB3.0 harddrive :
      • to have enough room for the swap
      • to have no wear and tear on sd cards
      • for speed
      DTEAMD 2 Replies Last reply Reply Quote 0
      • DTEAMD
        DTEAM @Folly
        @folly
        No success for me. I have a rpi4 with 4Gb and I had 9.25 Gb (free space) on my SD Card. I'll wait for the pre-compiled binary option.
        • DTEAMD
          DTEAM @Folly
          @folly
          Other systems to try : benesse pocket challenge MAME name: POCKCHAL
          Tiger Gizmondo : MAME name GIZMONDO
          Zeebo (Brasil) : MAME name: ZEEBO
          FollyF DTEAMD 4 Replies Last reply Reply Quote 1
          • FollyF
            Folly @DTEAM
            @dteam
            Haha
            Yes great, we should do that !
            • FollyF
              Folly @DTEAM
              @dteam
              Perhaps I can upload the mame binary to zippyshare.
              Interested ?
              • DTEAMD
                DTEAM @Folly
                @folly
                Interested ?
                Yes
                • FollyF
                  Folly @DTEAM
                  @dteam
                  The whole directory /opt/retropie/emulators/mame :
                  mame0233_RPI4_Buster_32bit
                  (File Life: 30 days after no activity.)
                  Edit :
                  No need to download anymore.
                  Retropie has updated the mame binary to 0233.
                  • DTEAMD
                    DTEAM @Folly
                    @folly
                    Option (line 11) doesn't work for me. Is it the same for you.
                    • FollyF
                      Folly @DTEAM
                      @dteam
                      Do you use add-mamedev-systems-test6_temp.sh ?
                      • DTEAMD
                        DTEAM @DTEAM
                        @folly
                        Those systems doesn't work for me.
                        • DTEAMD
                          DTEAM @Folly
                          @folly
                          I got your last version from your link above : add-mamedev-systems.sh
                          I have used line 10 instead of line 11. Line 11 doesn't work for me when it's time to load systems by letters.
                          • FollyF
                            Folly @DTEAM
                            @dteam
                            Which link ?, be sure you use temp.
                            Did you remove other versions ?
                            No problem for me, I can select line 11.
                            Just installed those.
                            I picked it fresh from github, so it should work.
                            • DTEAMD
                              DTEAM @Folly
                              @folly
                              I’ll do another test
                              • FollyF
                                Folly @DTEAM
                                @dteam
                                I created an issue on github for mame.
                                https://github.com/mamedev/mame/issues/8274
                                Hopefully they can fix it.
                                • FollyF
                                  Folly @DTEAM
                                  @dteam
                                  Any luck yet ?
                                  • DTEAMD
                                    DTEAM @Folly
                                    @folly
                                    Retropie added a precompiled MAME 0.233. So now it’s fine from binary
                                    • FollyF
                                      Folly @DTEAM
                                      @dteam
                                      Ok, I will check.
                                      (edit: yes, indeed retropie updated it to 0233 !)
                                      But the temp front-end module-script doesn't depend on mame because of the drc issue.
                                      So this was an other issue I presume.
                                      • FollyF
                                        Folly @DTEAM
                                        @dteam
                                        I tried to run these :
                                        • benesse pocket challenge MAME name POCKCHAL
                                        • Tiger Gizmondo : MAME name GIZMONDO
                                        • Zeebo (Brasil) : MAME name: ZEEBO
                                        No luck so far.
                                        • DTEAMD
                                          DTEAM @Folly
                                          @folly
                                          Same thing for me
                                          • FollyF
                                            Folly @DTEAM
                                            @dteam
                                            While busy with these, I found roms for other handheld systems and those are working.
                                            I have to see on my other pi4 what these systems are.
                                            But I think you have them already working as they booted in Artwork.
                                            Btw. there is bad output from mame -softwarelist
                                            pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame -listsoftware pockchal
                                            gives on all games => supported="no">
                                            pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame -listsoftware zeebo
                                            No software lists found for this system
                                            pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame -listsoftware gizmondo
