    2.3k Posts 37 Posters 8.5m Views
    • FollyF
      Folly @DTEAM
      @dteam
      I have these running :
      • gamecom
      • gamepock
      • pockstat
      2021-07-12-161926_800x600_scrot-resized.png 2021-07-12-162040_800x600_scrot-resized.png 2021-07-12-162135_800x600_scrot-resized.png
      • DTEAMD
        DTEAM @Folly
        gamecom
        gamepock
        pockstat
        Great !!! On my end, what I have been able to get to work as portable or keyboard less systems is listed here.
        gamecom, gamepock and pockstat are in that list.
        BTW , the artwork for pockstat is from me. I created that one (-; I always thought the Sony Pocket Station looked like a baby radio monitor. Strange design
        • FollyF
          Folly @DTEAM
          @dteam
          Yes indeed I should have known it right away.
          But it was obvious as the artwork was already there :-)
          We could just add these and more in the front-end menu in the menu option :
          Handhelds / Plug & play
          What do you think ?
          Or is that too much ?
          • DTEAMD
            DTEAM @Folly
            @folly
            Yes, It would be great
            • FollyF
              Folly @DTEAM
              @dteam
              Ok, I will see what I can do.
              • FollyF
                Folly @DTEAM
                @dteam
                For now I added all the systems from your list, except nes_detach as this system can't be installed by the script.
                link_to_commit
                Perhaps we have to alter the name of the menu item and perhaps I have to take the same route as I now do with temporary mame database.
                Then we could just pick out the lines we want to add without rewriting them.
                Then we could also choose to install on systems or on descriptions.
                (I am not doing that now, but we can perhaps do this in the future.)
                • DTEAMD
                  DTEAM
                  Now you can install :
                  lr-mess/mame <-- make sure you do this first, otherwise you can't add systems !
                  lr-mess/mame systems
                  the handhelds by @DTEAM
                  Hi Folly, in your first post, maybe you could add a link to my gamelist for handhelds. It's my second post here.
                  FollyF 4 Replies Last reply Reply Quote 0
                  • FollyF
                    Folly @DTEAM
                    Done
                    • FollyF
                      Folly
                      I cleaned up my repository by moving many old files to the backup directories.
                      Now about the updates.
                      To prevent breaking things I left these files untouched :
                      • generate-systems-lr-mess_mame-2v1.sh (basic script)
                      • generate-systems-lr-mess_mame-2v1-ext.sh (basic script to generate in the ext directory)
                      • add-mamedev-systems-test6_temp.sh (front-end)
                      • add-mamedev-systems-test6-ext_temp.sh (front-end to generate in the ext directory)
                      As I was thinking it's better to move to newer versions.
                      So I made new versions based on 2v1 with adding the new stuff to it :
                      • generate-systems-lr-mess_mame-2v2.sh
                      • generate-systems-lr-mess_mame-2v2-ext.sh
                      I added the updates thoroughly and expect no issues ,at least I hope so.
                      I still have to do the front-end though, as I want to move to version 7 with the front-end, so be patient.
                      Here is the commit of the basic scripts :
                      link_to_commit
                      Multiple improvements to the basic scripts :
                      • add translation "ai" lines to retroarch.cfg when installing a module-script
                        • Using hotkey "t" will translate the picture and pause the screen and translate
                        • Press "t" again to resume the game
                        • You might want to make a save-state before translating, if you experience a crash while translating
                      • add cheats to the correct mame.ini when installing a module-script
                        • version 2v1 added this in the wrong mame.ini
                        • version 2v2 should be ok now
                      • add game-specific-config runcommand lines in the emulators.cfg when installing a module-script
                        • if you load a game with the line containing "game-specific" then game-unique sub-directories are made with mame/lr-mess config files
                        • now it's possible to change the input per game in the mame-UI or lr-mess-UI
                        • to prevent conflicts between mame and lr-mess don't use the same config files, they get their own sub-directory
                        • config files for mame are save in /opt/retropie/configs/<RETROPIE-SYSTEM>/mame/<GAME>/<MAME-SYSTEM>.cfg
                        • config files for lr-mess are save in /opt/retropie/configs/<RETROPIE-SYSTEM>/lr-mess/<GAME>/<MAME-SYSTEM>.cfg
                      • add sorting the emulators.cfg when installing a module-script
                        • implemented this because it can get a mess if there are more than 10 lines in the emulators.cfg file
                        • if a "default line" is present it always goes to the last line
                      I also added the first post as a readme file into the repository :
                      link_to_readme
                      This way we always have a backup and we can keep track of the changes done in the first post :
                      link_to_changes
                      • FollyF
                        Folly @DTEAM
                        @dteam @JimmyFromTheBay @dmmarti @RussellB @valerino
                        I added the new front-ends version 7 with the generator script 2v2 inside.
                        It should work OBB.
                        I only tested the front-end menu structure as ok.
                        I am confident the generator script will work ok as I tested that before seperately.
                        Here you can find what is new :
                        link_to_commit
                        • FollyF
                          Folly @DTEAM
                          @dteam
                          We can add a new "handheld".
                          I am trying out the Atari Portfolio.
                          (system = pofo)
                          This brings back some memories as I still have 2 originals in my storage boxes.
                          Never knew that mame could emulate this.
                          So I found the correct bios files and it worked although there is no sound yet.
                          It seems, in a mame forum, that this computer has been improved upon in mame0233.
                          Now the trouble was how to add games, this was a difficult one !
                          Normally you had to connect a dos or an atari-st computer to the portfolio and connect them with a parallel port.
                          Well, trouble, haha, how on earth can we get games to this computer.
                          Looked for virtual parallel port things and looked into mame on how to use ports with the outside world.
                          No real solution here.
                          Edit: With the information gathered in this post I made a script for it :
                          https://github.com/FollyMaddy/create_atari-portfolio_roms
                          I found that you can add a ram card as a slot-device.
                          Now I could format this ram device and save a file to it.
                          But where is it saved ?
                          With mame it is saved here :
                          /home/pi/RetroPie/roms/mame/nvram/pofo/ccma_ram/ccma_ram
                          How to load it as a -memc ?
                          Well, I was thinking, perhaps the ram card file structure is the same as the rom file structure then I can make a .rom file of it.
                          That worked, and it's off-course read_only as it is loaded as a rom now.
                          Now I still had to find a way to add games to the .rom file.
                          After a long search and peeking into the ram/rom file with hexedit if found that it could be some sort of a disk or hd image.
                          Later I found that it seemed to be a FAT12 image, using this linux tool it will display that it's a FAT12 structure (this is how you install):
                          sudo apt install disktype
                          I just didn't believe it at first, but you can just mount the image in linux.
                          • mount the image in /mnt/ if you renamed your rom/ram file to fat12.img link_how_to_mount
                          sudo mount -o loop fat12.img /mnt/
                          • Open the filemanager as "root" to add files to /mnt/
                            (we can only do this, if we are in a desktop enviroment)
                          sudo pcmanfm
                          (If not using a desktop enviroment we can use the command cp or extract zip files to the mount )
                          • Add an autoexec.bat to /mnt/, so the rom will boot automatically from the drive "A:" , containing :
                          @echo off
                          <filename_to_run>
                          • Unmount the image link_how_to_unmount
                          sudo umount /mnt/
                          • Then rename fat12.img to folidash.rom for use with mame
                          This is the result with Folidash :
                          • FollyF
                            Folly @DTEAM
                            @dteam
                            Are you able to make artwork for the Atari Portfolio ?
                            For example only the screen.
                            DTEAMD 2 Replies Last reply Reply Quote 0
                            • DTEAMD
                              DTEAM @Folly
                              To do that, I must be able to run it first. I'll try it this week. I'll add a system to my theme first.
                              I saw you have used pofo, I also see this "portfolio_rom_card" . What is the connection between these two?
                              FollyF 3 Replies Last reply Reply Quote 0
                              • FollyF
                                Folly @DTEAM
                                You will find it in "mame-0.231-merged".
                                Just make a dummy.rom file and it wil run into DOS.
                                The media that can be loaded is a portfolio_rom_card.
                                Never had one, but they look like this ( although this is a ram card ) :
                                Btw.
                                lr-mess works but the rom images do not as lr-mess is still an older version of mame, I think that's the reason that it fails to load.
                                • FollyF
                                  Folly @DTEAM
                                  @dteam
                                  This is the game Phoenix :
                                  • DTEAMD
                                    DTEAM @Folly
                                    @folly
                                    • FollyF
                                      Folly @DTEAM
                                      @dteam
                                      Totally awesome !
                                      I will update immediately ;-)
                                      • DTEAMD
                                        DTEAM @Folly
                                        @folly
                                        Hi Folly. I need help to set games. Could you give me an example step by step with a game like tetris. My zip file is tetris.zip. Inside I have TETRIS.EXE and TETRIS.SCO .
                                        Do I have to cut and paste your lines above in "putty" and everything will work.
                                        • FollyF
                                          Folly @DTEAM
                                          @dteam
                                          Hi,
                                          I made a script for it.
                                          I have to improve some things as it is not perfect yet,
                                          but it should works for most games.
                                          I am going to make a repository for it, asap.
                                          I will let you know when it's online.
                                          Paste your .zip game files into the same directory as the script.
                                          Use the terminal.
                                          Go to that script directory.
                                          Be sure the script is executable with chmod u+x 123-pofo-roms.sh
                                          Run it with sudo ./123-pofo-roms.sh
                                          Now it will create .rom files from all .zip files.
                                          Copy these .rom to the roms/pofo directory.
                                          Edit :
                                          This is the repository :
                                          Fixed the issue of adding a .com or .exe to the autoexec.bat:
                                          • If 1 executable is found, then this file will be added to the autoexec.bat .
                                          • if more executable's are found, then you will be asked to type an executable which is added to the autoexec.bat .
                                          • DTEAMD
                                            DTEAM @Folly
                                            @folly
                                            Your script works !!!! great job. Now I have a loading issue :
                                            hd61830.bin NOT FOUND (tried in hd61830 pofo)
                                            Fatal error: Required files are missing, the machine cannot be run.
                                            sdl_kill: closing audio
                                            Enter sdlwindow_exit
                                            Leave sdlwindow_exit
                                            My Bios is pofo.7z from MAME 0.233
                                            NEW EDIT: It loads and it works . I added this Bios hd61830.7z
