    2.2k Posts 36 Posters 6.5m Views
    • F
      Folly @DTEAM
      @dteam
      There is another reason why this is not working.
      Haha, I think I tested too much, keep getting => 403 : Forbidden.
      Read the output of one file that I was trying.
      Sorry...Sorry... We're sorry... ... but your computer or network may be sending automated queries. To protect our users, we can't process your request right now.
      Can you get all the files with the code ?
      • DTEAMD
        DTEAM @Folly
        @folly
        #gets the cheat.7z and places it in the correct path
        #works perfect
        wget -N -P /tmp http://cheat.retrogames.com/download/cheat0221.zip
        unzip -o /tmp/cheat0221.zip cheat.7z -d $HOME/RetroPie/BIOS/mame/cheat
        rm /tmp/cheat0221.zip
        Like you said, It works perfect. It's great
        wget -nv -O /tmp/gdrivedl.py https://raw.githubusercontent.com/matthuisman/gdrivedl/master/gdrivedl.py
        curl https://drive.google.com/embeddedfolderview?id=1sm6gdOcaaQaNUtQ9tZ5Q5WQ6m1OD2QY3#list | egrep -o '(\w|-){26,}' | grep entry | sed 's/entry-//g' | while read fileid ; do python /tmp/gdrivedl.py https://drive.google.com/file/d/$fileid -P $HOME/RetroPie/roms/mame/artwork ; done
        rm /tmp/gdrivedl.pyrm /tmp/gdrivedl.py
        I got only 38 files ( 271 Mb). I'm gonna try another run (same thing)
        Example of Errors I had:
        • F
          Folly @DTEAM
          @dteam
          Thanks for trying.
          Basically it also says : HTTP Error 403: Forbidden.
          It looks like google detects it and then will blocks you for a time.
          I will search again for a solution on the internet.
          • DTEAMD
            DTEAM @Folly
            @folly
            If I zip all those files in one file to download, and after that, you manage It on the Pi. Could It be a solution?
            F 2 Replies Last reply Reply Quote 0
            • F
              Folly @DTEAM
              @folly
              If everything else fails, then we can try that ^^, but large files have other problems too solve..
              Whoow, I just had a full test run and all files are downloaded :-)
              I Basically used the sample script on this page just using 2 curl lines :
              https://gist.github.com/tanaikech/f0f2d122e05bf5f971611258c22c110f
              I injected the filenames and the file-id's from a handmade comma seperate file (.csv) into this sample script.
              I have to rewrite this a bit.
              Now I am hopefull !!!
              • F
                Folly @DTEAM
                @dteam
                Done rewriting.
                Can you test this for me ? :
                fileids=(); filenames=()
                weblist=$(curl https://drive.google.com/embeddedfolderview?id=1sm6gdOcaaQaNUtQ9tZ5Q5WQ6m1OD2QY3#list)
                IFS=$'\n' GLOBIGNORE='*' command eval  'fileids=($(echo $weblist | egrep -o "(\w|-){26,}" | grep entry | sed "s/entry-//g"))'
                IFS=$'\n' GLOBIGNORE='*' command eval  'filenames=($(echo $weblist | tr ">" "\n" | tr "<" "\n" | grep zip | grep -v application | grep -v : ))'
                mkdir -p $HOME/RetroPie/roms/mame/artwork
                cd $HOME/RetroPie/roms/mame/artwork
                for index in "${!filenames[@]}"; do
                echo downloading : ${filenames[$index]}
                curl -c ./.cookie -s -L "https://drive.google.com/uc?export=download&id=${fileids[$index]}" > /dev/null
                curl -Lb ./.cookie "https://drive.google.com/uc?export=download&confirm=`awk '/download/ {print $NF}' ./.cookie`&id=${fileids[$index]}" -o ${filenames[$index]}
                done
                cd $HOME
                How does it work :
                • create empty array's (see it as an excel column with more cell's with data)
                • get all data of the website and put it in the string : weblist
                  ( using embedded folder view : http://stackoverflow.com/questions/20681974/ddg#20681975 )
                • IFS is used to get all data it reads, when encountering a newline (\n), and puts it in the array
                • sed, tr and grep commands filter the website so IFS will read the data
                • all data, gathered in the array's, is injected in the curl commands by the for loop
                • DTEAMD
                  DTEAM @Folly
                  @folly
                  It running right now. It seems to be faster than the other script to get the files.
                  new edit
                  162 zip files + 1 cookie file ... It works !!
                  • F
                    Folly @DTEAM
                    @dteam
                    Yeahhh.. That is great !
                    I am now using a normal curl example and no scripts from others here,
                    perhaps faster that way.
                    Maybe I have to improve it a bit :
                    • remove cookie afterwards or place in /tmp directory.
                    • try to improve writing directly in the artwork directory, without going to the directory
                    But for now, it will do.
                    Are all files coming in the correct place or do some files have to be moved ?
                    • DTEAMD
                      DTEAM @Folly
                      Mame artwork go in /home/pi/RetroPie/roms/mame/artwork
                      .cfg files for overlays are generated in propers folders
                      like: /home/pi/RetroPie/overlays/konamih/kgradius.cfg
                      kgradius.cfg
                      overlays = 1
                      overlay0_full_screen = false
                      overlay0_descs = 0
                      kgradius.png is not automatically generated
                      In the MAME artworks kgradius.zip we found
                      4 .png files and only one is the backgroung.
                      Do you want to add the entire handheld overlay or just get the background? I,m saying that because I saw this picture for MAME in your previous post .
                      Personally, with the background only It's fine for me. I made some of the default.lay files that we find on google drive (svmu, pockstat, gp32, mc_tv200, sy889, etc.) and I don't know how to turn a default.lay file into a .cfg for retroarch overlay with position, size, etc.
                      gradius
                      • F
                        Folly @DTEAM
                        The code you used here is only for downloading the artwork files :
                        https://retropie.org.uk/forum/topic/29682/development-of-module-script-generator-for-lr-mess-and-mame-standalone/46
                        I still have to program the extraction of the .png files , but it seems it is doable / quite easy. ;-)
                        EDIT : I just added extraction of Background.png's (classich, gameandwatch, konamih, tigerh) in : generate-overlay-configs.sh / get-cheats-artwork-overlays.sh
                        I cloned it also to get-cheats-artwork-overlays.sh so we can add the download stuff later into that script.
                        For some artwork files there are no "Background.png" files. So we will have to find a solution for that.
                        I only want to do the background.
                        • DTEAMD
                          DTEAM @Folly
                          @folly
                          For cheat codes with MAME, I think you will have to add
                          cheatpath /home/pi/RetroPie/roms/mame/cheat
                          cheat 1
                          in mame.ini.
                          • F
                            Folly @DTEAM
                            @dteam
                            Added in the generate-systems-lr-mess_mame-1v8-alpha.sh script.
                            It will be added to the mame.ini config if installing/updating an install-<RPname>-cmd.sh module-script in the RetroPie-setup.
                            • F
                              Folly @DTEAM
                              @dteam
                              How is it going with the backgrounds ?
                              These games have bg.jpg and can work in lr-mess (but not in the script yet).
                              kdribble
                              kloneran
                              knfl
                              taddams
                              tddragon3
                              tgaiden
                              tinday
                              tmchammer
                              trobocop2
                              We have to find a solution for these games and probably more.
                              1 - So I can try to change the script so it will also detect bg.jpg and alter the config accordingly.
                              But this can conflict/be a problem in the long run if more games have to be added with also different background filenames.
                              An uniform approach would be better, I think.
                              Something like this :
                              2 - So it would be nicer,I think, if bg.jpg is converted to a Background.png and that both files are kept in the archive.
                              3 - Or the layout is altered for Background.pngand then keeping only Background.pngis also a posibility.
                              My intuition says option 2 .
                              Keeping original files and make it compatible for our project.
                              What do you think ?
                              • DTEAMD
                                DTEAM @Folly
                                @folly
                                I'm gonna do the conversion for files in Google Drive
                                • F
                                  Folly @DTEAM
                                  @folly
                                  Are you letting me know when it's ready ?
                                  • DTEAMD
                                    DTEAM @Folly
                                    done
                                    I tested It, and It Works. Background.png files are converted with the appropriate namings in**/home/pi/RetroPie/overlays/home/pi/RetroPie/overlays/** "system name"
                                    • F
                                      Folly @DTEAM
                                      @dteam
                                      Cool, isn't it ;-)
                                      Next thing to do is, checking the games that don't need an overlay.
                                      Then I will remove these games from the generating overlay script so no loose config files are generated.
                                      And there are games with 2 screens.
                                      With these the TOP/BOTTOM or LEFT/RIGHT backgrounds have to be joined I think.
                                      We will have to try on how this will look.
                                      • DTEAMD
                                        DTEAM @Folly
                                        Cool, isn't it ;-)
                                        When you load a game with Lr-Mess, do you have to select the overlay or it,s done automatically. On my side, I have to load It via retroarch UI
                                        • F
                                          Folly @DTEAM
                                          Cool, isn't it ;-)
                                          Strange, which games did you try ?
                                          The retroarch overlay loads automatically on my side.
                                          I am loading with lr-mess-cmd.
                                          The runcommand.sh will append the config if the loader name (in emulators.cfg) starts with lr-.
                                          So lr-mess-cmd = "...cmd...,". (should work), renamed to mess-cmd = "...cmd...," (doesn't work)
                                          /opt/retropie/emulators/retroarch/bin/retroarch --config /opt/retropie/configs/konamih/retroarch.cfg -v -L /opt/retropie/libretrocores/lr-mess/mess_libretro.so "/home/pi/RetroPie/roms/konamih/kgradius.zip" --appendconfig /dev/shm/retroarch.cfg'|'"/home/pi/RetroPie/roms/konamih/kgradius.zip.cfg"
                                          Above execution line from the log, shows that the config is loaded : '|'"/home/pi/RetroPie/roms/konamih/kgradius.zip.cfg" , which will load :
                                          ( not in log) /home/pi/RetroPie/overlays/konamih/kgradius.cfg ,which will load :
                                          ( not in log) /home/pi/RetroPie/overlays/konamih/kgradius.png
                                          Check your /dev/shm/runcommand.log if the custom config for the overlay is present.
                                          Check also if you have any overrides :
                                          [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/MAME/MAME.cfg.
                                          [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/MAME/konamih.cfg.
                                          [INFO] [Overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/MAME/kgradius.cfg.
                                          I have these config lines used by lr-mess (and lr-mame, I think) in /opt/retropie/configs/all/retroarch-core-options.cfg :
                                          mame_alternate_renderer = "disabled"
                                          mame_altres = "640x480"
                                          mame_auto_save = "disabled"
                                          mame_boot_from_cli = "enabled"
                                          mame_boot_to_bios = "disabled"
                                          mame_boot_to_osd = "disabled"
                                          mame_buttons_profiles = "enabled"
                                          mame_cheats_enable = "enabled"
                                          mame_cpu_overclock = "default"
                                          mame_lightgun_mode = "none"
                                          mame_mame_4way_enable = "disabled"
                                          mame_mame_paths_enable = "disabled"
                                          mame_media_type = "rom"
                                          mame_mouse_enable = "disabled"
                                          mame_read_config = "disabled"
                                          mame_saves = "game"
                                          mame_softlists_auto_media = "enabled"
                                          mame_softlists_enable = "enabled"
                                          mame_throttle = "disabled"
                                          mame_write_config = "disabled"
                                          You may also want to try a dummy overlay with lr-vecx to see if it is an lr-mess or a retroarch problem.
                                          • DTEAMD
                                            DTEAM @Folly
                                            @folly
                                            I have this in my runncommand.log
                                            in retroarch-core-options.cfg
                                            mame_cheats_enable = "disabled"
                                            The rest is the same than your.
                                            My emulators.cfg seems to be good.
