    2.3k Posts 37 Posters 9.1m Views
    • I
      isidoro80 @jamrom2
      @jamrom2 yes i add this bios and now apple2ee work but for play with alle2gsr1 are require another bios. You can see this in second photo i post yesterday
      [libretro INFO] MANUFACTURER: Apple Computer
      341-0232a.bin NOT FOUND (tried in apple2gsr1 apple2gs)
      341-0124a.bin NOT FOUND (tried in apple2gsr1 apple2gs)
      Fatal error: Required files are missing, the machine cannot be run.
      [libretro INFO] RES:1
      • jamrom2J
        jamrom2 @isidoro80
        @isidoro80 what apple BIOS files do you presently have loaded?
        • jamrom2J
          jamrom2 @Folly
          @folly just tossing it out there.. I don't know if you are but it's probably not worth doing Apple II version since you already have the Apple IIe working. I've been playing around with some games for testing... Battle Chess, Beach Head and Archon... and there is no difference between the two as far as game graphics go. The difference is mostly in the design of the internals and the ability to use lower case ASCII code additions.
          So how you have it now, is probably the best set up.
          • FollyF
            Folly @jamrom2
            @jamrom2
            I thinks so too, I will keep those in the "other systems section".
            Perhaps I should rename it to "thread systems section".
            Sometimes I still struggle on what keys from the keyboard I have to use. ;-)
            Also tried a few more apple2gs games, they are really nice and the sound is very good !
            Battle-Chess-apple2ee VS Battle-Chess-apple2gsr1
            ( What a difference )
            jamrom2J 1 Reply Last reply Reply Quote 3
            • jamrom2J
              jamrom2 @Folly
              @folly After doing more testing, you got this one locked-up. It's smooth, easy to setup and works great. I added in my overlays and shader settings... so everything is back to what is was but now using your script for the install.
              Works great. Nice job on this!
              • FollyF
                Folly @jamrom2
                @jamrom2
                Thanks for the compliment ;-)
                Nice to hear you worked it out.
                It isn't that difficult anymore when you know how it works.
                Btw. I did a discovery yesterday :
                The speedup key for mame is the "page down" key, that works the same like using the hotkey "space" with retroarch.
                I am also testing an "emulators.cfg runcommand line" for mame.
                This has something to do with the "mame-cmd/mame basename" line.
                These lines do not directly work with systems that load media.
                That is because, when only software is loaded, it tries to match it with a system which cannot be found.
                Summarized : Someone is loading software not a system, that is the issue.
                So adding the Driver and the -rompath /home/pi/RetroPie/roms/<system> makes this work when both BIOS files and SOFTWARE files are in the same /home/pi/RetroPie/roms/<system> directory.
                Then it will use the "software lists/hash tables" which will have the advantage that, if the game has more media,
                lets say disk 1 and disk 2, then many times both are loaded in one go.
                DTEAMD jamrom2J 3 Replies Last reply Reply Quote 0
                • DTEAMD
                  DTEAM @Folly
                  @folly
                  For AFP MP-1000 fans, I did a gamelist.xml file with videos, 2d boxes and logos for each official game.
                  I put that on the google drive ready for the script!
                  FollyF 1 Reply Last reply Reply Quote 2
                  • jamrom2J
                    jamrom2 @Folly
                    @folly
                    Sounds great.
                    The only issue I see with this is purely visual. You would have to name the bios files something other than the same extension as the game files...otherwise the BIOS files will display as games in the game list. I hope that makes sense.
                    Normally it's not good to have both the BIOS and Games in the same location just for that reason.
                    • FollyF
                      Folly @jamrom2
                      @jamrom2 said in Development of module-script generator for lr-mess and mame standalone:
                      @folly
                      Sounds great.
                      Yes, indeed that's a problem.
                      That's why I don't add it right away.
                      I would be nice if we could add 2 paths somehow, not sure if that is possible.
                      Perhaps we can find a solution on the way.
                      • FollyF
                        Folly @DTEAM
                        @dteam
                        Great work you have done for the apfm1000.
                        I will install it soon ;-)
                        Edit :
                        You have a typo in the system name, it should be :
                        apfm1000
                        (Looking at the logo, very strange name indeed)
                        Probably this filename is incorrect :
                        Baseball (MG1006) for the APF MP-1000 videogame system (1978)-DDhWqyq4-eg
                        • DTEAMD
                          DTEAM @Folly
                          @folly
                          I think apfm1000 is for M-1000 and MP-1000
                          and apfimag_cass is for computer extension APF Imagination Machine
                          On wiki we can read :
                          The console is often referred to M-1000 or MP-1000, which are the two model numbers of the console. The APF-MP1000 comes built-in with the game Rocket Patrol. The APF-MP1000 is a part of the APF Imagination Machine.
                          Cartridge list
                          Some APF-M1000 games
                          MG1008 Backgammon
                          MG1006 Baseball
                          MG1007 Blackjack
                          MG1004 Bowling/Micro Match
                          MG1012 Boxing
                          MG1005 Brickdown/Shooting Gallery
                          MG1009 Casino I: Roulette/Keno/Slots
                          MG1001 Catena
                          MG1003 Hangman/Tic Tac Toe/Doodle
                          MG1011 Pinball/Dungeon Hunt/Blockout
                          Built-In Rocket Patrol
                          MG1013 Space Destroyers
                          MG1010 UFO/Sea Monster/Break It Down/Rebuild/Shoot
                          FollyF X 2 Replies Last reply Reply Quote 0
                          • FollyF
                            Folly @DTEAM
                            @dteam
                            Ok, so I got the wrong system installed then ?
                            • DTEAMD
                              DTEAM @Folly
                              @folly
                              No , I think M-1000 and MP-1000 are the same machine.
                              • FollyF
                                Folly @DTEAM
                                @dteam
                                But your files are going to afpm1000.
                                That system doesn't exist.
                                • DTEAMD
                                  DTEAM @Folly
                                  @folly
                                  Sorry, you are right, typo error. Corrected. I thought you were talking about MP-1000 vs M-1000.
                                  • FollyF
                                    Folly @DTEAM
                                    @folly
                                    Haha, No problem.
                                    Perfect !
                                    After it has finished I will download again.
                                    I think it's going to look great.
                                    Btw. did you test all those games ?
                                    I have trouble with finding the right keys on how to play them.
                                    The one you posted worked though, just shooting with "enter".
                                    DTEAMD 2 Replies Last reply Reply Quote 0
                                    • DTEAMD
                                      DTEAM @Folly
                                      @folly
                                      No, I didn't tested yet. I'll do it today or tomorrow. I will also try with the basename option.
                                      • FollyF
                                        Folly @DTEAM
                                        @dteam
                                        Forgive me !
                                        I found that the path is incomplete in gamelist.xml so the pictures and mp4 isn't loaded.
                                        It's missing emulationstation.
                                        • DTEAMD
                                          DTEAM @Folly
                                          @folly
                                          It's missing for the other gamelist files also. I thought It was for your script and at the end you put the gamelist.xml and the media folder directly in your roms system folder without emulationstation folder.
                                          I'm downloading the game list folder from Google drive to see if all gamelist are like that. If yes, is it a good option to delete the emulationstation folder or you prefer the file path modification.
                                          • FollyF
                                            Folly @DTEAM
                                            @dteam
                                            Yes indeed, that is what we did, and we should keep it that way.
                                            I think you don't understand me.
                                            ./media/
                                            has to be
                                            ./media/emulationstation/
                                            in the gamelist.xml
                                            Agreed ?
                                            Just fixed it in my gamelist and it's looking great in ES !
