    2.3k Posts 37 Posters 9.4m Views
    • FollyF
      Folly @DTEAM
      @dteam
      Thanks for the feedback.
      I will have a look at it If I can use or implement some things.
      category.ini (0.236) looks good !
      • jamrom2J
        jamrom2 @Folly
        @folly I'm happy to test this as well...
        Do I need to remove the other mess emulators installed with the previous script and where do I put this to run it? \scripts?
        I just finished the logos for Epoch and Bambino so I'll post them to the other logo thread.
        • FollyF
          Folly @jamrom2
          @jamrom2 said in Development of module-script generator for lr-mess and mame standalone:
          Yes, if you want to, that would be great.
          No need to de-install things.
          Just remove the old add-mamedev-systems.sh and replace it by the new one in :
          /home/pi/RetroPie-Setup/scriptmodules/supplementary
          I will give you a sign when I upload the next one !
          Perfect !
          • FollyF
            Folly @jamrom2
            @DTEAM @jamrom2
            I just uploaded the files.
            https://github.com/FollyMaddy/RetroPie-Share/tree/9c10b1288f264f8c9f36ba691df0b24c548f2494/00-workdir-00/add-mamedev-systems-2v4.sh
            (edit for those who don't know : right-click on raw and save as)
            Btw.
            No need to do the source install of mame.
            When you install the binary you are on mame0236.
            Here you can see what I updated :
            https://github.com/FollyMaddy/RetroPie-Share/commit/72cc916784d1bf0b57477c3f85209409dae695e9
            https://github.com/FollyMaddy/RetroPie-Share/commit/9c10b1288f264f8c9f36ba691df0b24c548f2494
            • FollyF
              Folly @DTEAM
              @dteam
              When you are busy with the gamelists.
              Can you check for me if they are added correctly when you add them to the google-drive ?
              The script should detect the new ones and add them in the list.
              • I
                isidoro80
                Hello what is name of bios file for arcade game sega model 1. I want play game arcade: arabian fight, f1 exaust, radrally. If i run this games with lr-mame i have error driver model1 not found.
                • jamrom2J
                  jamrom2 @Folly
                  Perfect !
                  OK, I'll test this tomorrow.
                  • DTEAMD
                    DTEAM @isidoro80
                    @isidoro80 said in Development of module-script generator for lr-mess and mame standalone:
                    For Model1 try this:
                    model1io
                    model1io2
                    But for those games, you can use lr-fbneo. You need Sega system 32 , not model 1
                    see: https://retropie.org.uk/forum/topic/19741/goodbye-fbalpha-welcome-fbneo/300
                    According to that link some games work better with lr-mame2016
                    I 1 Reply Last reply Reply Quote 1
                    • jamrom2J
                      jamrom2 @Folly
                      @folly
                      Just tried the script... I get this. I'm not surprised I have an issue. My build seems to have issues with everything... I ask it to make a ham and cheese sandwich and I get a reply "with what?". Lol.
                      Is it asking for something I don't have? Your test script worked without an issue.
                        mitu Global Moderator @jamrom2
                        @jamrom2 You downloaded the file wrong, you need to click the 'Raw' button on the Github interface first. You downloaded the HTML page, which is - obviously - not a valid .sh script file.
                        jamrom2J 1 Reply Last reply Reply Quote 1
                        • I
                          isidoro80 @DTEAM
                          @dteam hello I put the bios in the folder / bios / mame and roms / arcade but still lr-mame gives me the same error. i can try the other emulatoelri but i prefer to use mame.
                          • jamrom2J
                            jamrom2 @mitu
                            yep... that was it...
                            So it's ham, bread, cheese, bread, mustard to make a Ham and Cheese... man...I'm bad at this.
                            Thanks as always for your all-seeing eye.
                            • FollyF
                              Folly @isidoro80
                              You should always check your /dev/shm/runcommand.log after you tried to run a game.
                              If there isn't enough information then you have to press a key just before the game boots.
                              This will get you in the retropie-boot-dialog.
                              Choose the launch with verbose option.
                              Then check your /dev/shm/runcommand.log again after you tried.
                              I would advise you to make a new help thread for your problem.
                              Describe a bit better, what game, from what system, you want to run and, with which emulator.
                              It seems you mix a lot of things up.
                              Also describe if you want to do it the regular way or using this project.
                              Please also read the docs thoroughly :
                              https://retropie.org.uk/docs/Arcade/
                              • I
                                isidoro80 @Folly
                                maybe because I don't write well in English. I believe my problem is consistent with this post. I have installed lr-mame and would like to play the segamodel 1 games emulated by lr-mame. one of these is arabian fight and another is f1 exaust. I read the game log and despite having installed the bios in the correct directories I read as an error: model file not found. essentially the bios are missing. I have installed the bios Model1IO.zip, Model1IO2.zip, M1COMM.zip, HD44780_A00.zip but i can't play games. the question is this. can anyone play arcade model 1 games with le-mame?
                                jamrom2J FollyF 2 Replies Last reply Reply Quote 0
                                • jamrom2J
                                  jamrom2 @isidoro80
                                  @isidoro80
                                  Problem might not be the BIOS files... it might be that the ROMs you are using are not correct to the version of MAME you have loaded.
                                  What version are the ROMs from? They have to match the version of MAME correctly in order to work. They change/merge ROMs often between version of MAME so everything must match.
                                  • FollyF
                                    Folly @isidoro80
                                    @isidoro80
                                    I looked in the mame databases for you.
                                    The games you want to run are "system drivers" and not found in the software databases (softwarelist hash tables).
                                    mame0236_systems:Driver arabfgt (Arabian Fight (World)):
                                    mame0236_systems:Driver arabfgtj (Arabian Fight (Japan)):
                                    mame0236_systems:Driver arabfgtu (Arabian Fight (US)):
                                    mame0236_systems:Driver f1en (F1 Exhaust Note (World, Rev A)):
                                    mame0236_systems:Driver f1enj (F1 Exhaust Note (Japan, Rev A)):
                                    mame0236_systems:Driver f1enu (F1 Exhaust Note (US, Rev A)):
                                    This basically means that the game files are the bios files.
                                    Confusing perhaps, but we don't put game-bios-files in the BIOS or BIOS/mame directory normally. We put them in the normal roms/*** directory.
                                    According to this : https://www.progettosnaps.net/renameset/
                                    Here you have a file category.ini (0.236) (always up to date) .
                                    Inside, you have a file named arcade.ini and one mess.ini.
                                    Here we can see that they are arcade ones, so you should be able to run them with lr-mame or mame.
                                    You have to place the f1en.zip (.7z) and arabfgt.zip (.7z) in the regular rom directory :
                                    • /home/pi/RetroPie/roms/mame-libretro
                                      or
                                    • /home/pi/RetroPie/roms/arcade
                                    Technically speaking, then you are doing it just the normal/regular way.
                                    Let me know if this works.
                                    Here it works :
                                    2021-10-16-094542_800x600_scrot-resized.png 2021-10-16-094623_800x600_scrot-resized.png
                                    • jamrom2J
                                      jamrom2 @Folly
                                      Maybe I can help a little with this as well...
                                      The best way to see what you are missing when it comes to MAME is to run native MAME on a PC.
                                      Grab the ROMs from the correct MAME version number, run it in MAME and it will tell you what you need. Many of the missing files need to be added to the main MAME ROM folder (as Folly pointed out). They are no longer placed in the BIOS folder.
                                      Great example is Gorf. It needs very specific VOX files to properly emulate the voice sounds in the game as they don't use "samples" any more. Without those VOX files, Gorf will not work and will flag an error. You then add those files to the MAME roms folder, and all is happy.
                                      Having said that... Retropie did not run the most modern version of MAME, until this new script was added...so now you have to see what version of MAME this script pulls down and make sure that the games you are trying to run are supported by that version of MAME.
                                      MAME has never been a quick dump and go emulator. It has always been this way, and requires things to be the correct version, in the correct place...and named correctly.
                                      So try there before you go any further. You might be chasing this meanwhile, this version of MAME might not even support the game you are trying to run.
                                      • FollyF
                                        Folly @jamrom2
                                        @jamrom2
                                        Here you can learn/read everything about mame :
                                        https://docs.mamedev.org/
                                        Here you can read almost everything about the commandline options :
                                        https://docs.mamedev.org/commandline/commandline-all.html
                                          dankcushions Global Moderator
                                          standard retropie has supported current, standalone MAME for over a year now: https://github.com/RetroPie/RetroPie-Setup/blob/master/scriptmodules/emulators/mame.sh (experimental packages)
                                          • FollyF
                                            Folly
                                            @DTEAM
                                            All changes up until now :
                                            (18-10-2021)
                                            • all slotdevice parameters converted to "extra options"
                                            • added lr-mess overlay config creation for .7z files
                                              (because roms are often in .7z format now)
                                            • improvements in menu : Download > Download/update
                                            (14-10-2021)
                                            • fix : first line of the CSV was not displayed in some menus
                                            • now the front-end uses the mame0236 database
                                            • added the possibility to install the available gamelists and media per system
                                              • should be future proof when adding new system on the google-drive
                                            • added the older and newer missing mame databases (now we have 0228 - 0236 )
                                            • add systems in the generator part script for : classich and gameandwatch
                                            • updated the handheld databases
                                            https://github.com/FollyMaddy/RetroPie-Share/blob/0b3a8f2fa4588098411eda5b860cde8a9f00ac6c/00-workdir-00/add-mamedev-systems-2v4.sh
                                            (right-click on raw to download)
