    2.3k Posts 37 Posters 8.5m Views
    • AshpoolA
      Ashpool @Folly
      Let me know how it goes.
      Not sure if anyone can understand my scripted notes, but here is the log of my nowadayseveningtryouts and I am somewhat frustrated, maybe all that lr-mame RA-core-options stuff would make more sense under a pure retroarch install environment where lr-mame hasn't to compete with upstream mame.
      Regardless of my frustration, for the purpose of that what I wanted to try, I can only conclude, that I need to install both lr-mame and mame and have to keep away from lr-mame/core options: write config, as that enabled is just messing things up [and without (upstream) mame installed, i have no idea where to place artwork/ini/samples that will be read/utilized by lr-mame].
      @Folly, sorry for the longer post(s) involved and maybe it would have been better if I should have opened a separate Topic for it :/
      • FollyF
        Folly @Ashpool
        @Ashpool
        No problem posting it here.
        This is stuff we can about over here so we can discover new things we didn't know before.
        Sometimes it can be useful for improving the module-script.
        Seems that you are more a standalone mame user.
        RA has some advantages but that's indeed not always the case ;-)
        AshpoolA 1 Reply Last reply Reply Quote 0
        • AshpoolA
          Ashpool @Folly
          Well, yeah - a minor reason for my tryouts included the possibility to (as AFAIK libretro overlays are just overlays) use lr-mame with asteroids to get the (classic atari) backdrop from Mr.Do's mame artwork file and use lr-mame to cover it with a bezel (in the hope that a) it may allow me to use a bezel not included in the mame artwork file and b) maybe it (double finger crossed) will turn out to be faster in this chain, compared to (upstream) mame + artwork is applying backdrop and bezel - but I am still a few microns away from the time to spend on that experiment ;), but apart from that - you are right, as using an I-PAC2 Keyboard Encoder (set to keyboard), non libretro cores (at least for the arcade case) are easier to handle (IMHO), but are missing the vitals of libretro overlays and shaders :smirk: (and for those games upstream mame cannot handle, I am a big fanboy of both FBNeo and lr-m2k3+ (also because of the incorrect handling of vertical games being rotated within the core and reported/handed over as horizontal to the retroarch api and shaders))
          • FollyF
            Folly @Ashpool
            @Ashpool
            I understand what you want to accomplish.
            Use a bezel overlay of astroids with RA/lr-mame, correct ?
            There are 2 ways to accomplish that.
            We can discuss that later is you want, let me know.
            Btw.
            Speed will not make a huge difference between using standalone mame + artwork and lr-mame + bezel overlay.
            • AshpoolA
              Ashpool @Folly
              @Folly It was just one of the things on my maybe/checkout/couldbe list... but yes, for asteroids I thought, that as libretro/retroarch overlays can't act as backdrops, i use lr-mame to utilize a mame artwork file with a backdrop and let libretro(-mame) overlay it with a bezel.
              Thinking about of using lr-mame to show asteroids_acc_backrop.png from the mr.do file as a real backdrop and then overlay it with the bezel from the artwork file that progetto-SNAPPS is hosting. ...->... as my running system has a 1600x1200 4:3 Display, it will obviously include for me the tasks of preparing/editing the lr-bezel and creating needed configs, but thats a no-brainer once I know that this chain of backdrop/overlay can be done (and then we/I may see whether the emulations speed is still ok (throttle enabled, so not going faster then original hardware, but also not dropping below it is what i hope for [edit: and at least on my pi4's asteroid with current mame and artwork is fine, whereas asteroid deluxe is a choppy nogo with artwork]).
              • FollyF
                Folly @Ashpool
                @Ashpool
                I looked at the file asteroids_acc_backdrop.png.
                You can use it as an background overlay but you need to use some transparency in the config file just like I use for the handhelds (konamih, tigerh, etc) using lr-mess.
                The config roms/arcade/asteroids.zip.cfg would look like this :
                input_overlay =  /opt/retropie/configs/all/retroarch/overlay/asteroids.cfg
                input_overlay_enable = true
                input_overlay_opacity = 0.500000
                input_overlay_scale = 1.000000
                The config /opt/retropie/configs/all/retroarch/overlay/asteroids.cfg would look like this (placing the .png in the same directory):
                overlays = 1
                overlay0_full_screen = false
                overlay0_descs = 0
                That is one solution that should work.
                • AshpoolA
                  Ashpool @Folly
                  @Folly Right, and for lr-mame that maybe should perform faster then using mame-artwork together/instead of lr-overlays. But the reason I wanted to try with backdrop -> quick comparison: mame artwork (Mr.Do's old mame artwork) backdrop vs. lr-overlay in lr-mame2003Plus (nowadays default vector settings) and using asteroid deluxe (as that backdrop is more obstrusive compared to my mentioned asteroid one and therefor better suited for the comparison) ... And IMHO by having a real backdrop (where the vectors are drawn on) it ain't competing/messing with the vector setup(s) as it is IMHO with an overlay (drawn over the vectors) ;)
                  So, here we go -> left is mame_artwork/backdrop, right is libretro-overlay with 0.5 opacity.
                  P.S.: The Backdrop/Overlay may slightly differ in their AspectRatio, as for that test I've taken the backdrop from the mame artwork, resized it to 4:3 vertical res of my display and added black borders for the horizontal res and then using your configs with it (And for the mame artwork, i omitted the bezel from the artfile, so that it is just the backdrop used by it).
                  • FollyF
                    Folly @Ashpool
                    @Ashpool
                    Nice to see that you have got it working. (nice backdrop btw.)
                    Indeed, using RA-overlays has it limitations.
                    What about the speed ?
                    I tried the artwork file astdelux.zip (renaming it asteroid.zip) on both mame (in roms/mame/artwork) and lr-mame (in BIOS/mame/artwork) on my pi4.
                    The file seems a bit different than yours but for the test that doesn't matter.
                    Speed on mame is 100%
                    Speed on lr-mame is 78% (and more if frameskipping is used)
                    Altough the speed is lower on lr-mame it is still playable and it looks better than using an RA-overlay.
                    DTEAMD AshpoolA 2 Replies Last reply Reply Quote 0
                    • DTEAMD
                      DTEAM @Folly
                      @Folly
                      Hi Folly, for classich and Game&Watch games from Madrigal romset, I got an idea to autorun the games with the good emulator.
                      For all roms, by default it could be MAME or lr-Mess (doesn't matter). For madrigal, you could create a scritp with your list or the list on my tutorial thread to generate a execution path for each Madrigal roms in /opt/retropie/configs/all/emulators.cfg like classich_ExplorersofSpace = "lr-gw" . That way, the user doesn't have to know if it's a Madrigal rom or MAME rom.
                      What do you think about this approch.
                      • FollyF
                        Folly @DTEAM
                        @DTEAM
                        Could be a good approach.
                        Just tested a few and it works beautifully.
                        Looks like we still need the runcommand for "lr-gw" on "classich" though.
                        I think it could be as easy as making the emulators.cfg and add both gameandwatch games and classich games then you can just share it on google-drive and I add a command that will download that file and place it in /opt/retropie/configs/all.
                        Good idea ?
                        DTEAMD 2 Replies Last reply Reply Quote 1
                        • DTEAMD
                          DTEAM @Folly
                          No problem, I'll do that.
                          • AshpoolA
                            Ashpool @Folly
                            Well... using "F11" in both lr-mame and mame is somewhat ambiguous over my tests/tryouts and I am not sure what detail(s) is(/are) making the difference(s)... in all of my experiments, neither core got a constant 100%... in worse cases it droped down to don't mention it&please deactivate the audio, over midterms around 45 -20/+15% and then in good scenarious around 96-98|100%. On fresh installs (mame and lr-mame (in this order)) mame seems to be a bit faster, but from there onward (after meddling with ini files and artwork) lr-mame performed slightly better). Regardless of that, once I've got some more experience/data and configurations done, I am now inclined to open up a showcase/WIP/some ideas anyone? thread for that scenario of my ventures into this sub-project of my reasons to try current mame/lr-mame (mame backdrop/libretro bezel) in the near future ;]
                            • FollyF
                              Folly @Ashpool
                              @Ashpool
                              Good idea to bundle your experience in a new thread.
                              • DTEAMD
                                DTEAM @Folly
                                Good idea ?
                                It only works for games with no space in there names. I don't know whaat to do with games like : gameandwatch_Donkey Kong (Multi Screen)="lr-gw"
                                it only works for games with a single name like : gameandwatch_Egg="lr-gw"
                                Any idea @folly @mitu
                                See here on my drive
                                File name : emulators.cfg
                                To place in : /opt/retropie/configs/all/
                                FollyF mituM 4 Replies Last reply Reply Quote 0
                                • FollyF
                                  Folly @DTEAM
                                  @DTEAM
                                  The example you gave also had a space which was removed.
                                  Did you try this ? :
                                  gameandwatch_DonkeyKong(Multi Screen) = "lr-gw"
                                    mitu Global Moderator @DTEAM
                                    Easy - start the game and choose your emulator from the runcommand launch menu, then see how it's stored in the .cfg file. Or look-up the function that does the name substitution - it's here.
                                    • FollyF
                                      Folly @DTEAM
                                      The function clean_name gives :
                                      DonkeyKongMultiScreen
                                      So this should work :
                                      gameandwatch_DonkeyKongMultiScreen = "lr-gw"
                                      • DTEAMD
                                        DTEAM @Folly
                                        Yes, it works now. Thanks
                                        It's very usefull for classich and gameandwatch with MADrigal romset.
                                        FollyF 3 Replies Last reply Reply Quote 1
                                        • FollyF
                                          Folly @DTEAM
                                          @DTEAM
                                          If I have time tomorrow I will look at it.
                                          Also busy with changing the "lr-gw" install.
                                          Hopefully I can implement before Sunday because next 2 weeks I don't have any time.
                                          duglorD 1 Reply Last reply Reply Quote 1
                                          • duglorD
                                            duglor @Folly
                                            @Folly (interjection, pardon me, Folly is there a thread or something you can point me to to the most minutae step by step installation of the latest/newest/ folly-updated lr-mess/mame-fmtowns emulator and how to make it work?--please resume chat without me now..lol..)....
