    2.3k Posts 37 Posters 8.4m Views
    • FollyF
      Folly @DTEAM
      @DTEAM
      I can only download folders containing files with my function.
      Theoretically it's possible to download only 1 file with the gdrivedl.py script however the fileurl is unknown.
      Therefor the best solution is to just put the file in a separate folder without any other files.
      Can you do that for me ? Not needed anymore, I placed the file in my repository.
      • FollyF
        Folly @duglor
        @duglor
        There is no tutorial for installing fmtowns using my script.
        You can find some older stuff, that might be useful, over here :
        https://retropie.org.uk/forum/topic/27806/tutorial-fujitsu-fm-towns-marty-with-lr-mess
        https://retropie.org.uk/forum/topic/27806/tutorial-fujitsu-fm-towns-marty-with-lr-mess/45
        We also discussed these systems in this thread, for example, over here :
        https://retropie.org.uk/forum/topic/28345/old-computer-appreciation-thread/1268
        Basically it's just like any other install.
        However some software does need more ram so I have added installer lines for fmtowns and fmtmarty in my section Systems: with extra options.
        My advice is install these ones.
        After that it's just a matter of adding the correct bios files.
        You can check the /dev/shm/runcommand.log for the missing bios files after a failed run.
        You should open a new thread reserving your fist post for a summarize on how to install things using my script.
        That would be a good addition to this thread.
        duglorD 1 Reply Last reply Reply Quote 0
        • duglorD
          duglor @Folly
          Your "Systems: with extra options thread?" meaning this thread here? starting from the top?
          • FollyF
            Folly @duglor
            @duglor
            You can find the section/menu item "Systems: with extra options" over here : 1663431603837-2022-09-17-181420_1600x900_scrot.png
            My advise is just to make a new thread, just like you did over here :
            https://retropie.org.uk/forum/topic/33956/fujitsu-fm-towns-marty
            ( or just use that thread )
            • FollyF
              Folly @DTEAM
              @DTEAM
              I changed the lr-gw install significantly as I wasn't happy about how it was earlier on.
              Now the install basically works just like the install lines for mame/lr-mess/lr-mame and so the binary install will now also possible.
              On top of the regular install I added the patches described in the commit.
              I don't expect huge issues as I tested it, partly, myself.
              However I want to ask you if you can test it too ?
              Btw. I have added the emulators.cfg to my repository, that way I can do the download in proper way.
              These are the commits :
              https://github.com/FollyMaddy/RetroPie-Share/commit/3e0609072780b0bf8a26a34f0f829110e5502298
              https://github.com/FollyMaddy/RetroPie-Share/commit/ddbcf189c9852c8ef5140a881eb376bd5787dbb3
              Fix emulators.cfg (correct clean_names) :
              https://github.com/FollyMaddy/RetroPie-Share/commit/ae78a1c57cc8e05ef9be4af15ec75e61d2ddc63d
              duglorD 1 Reply Last reply Reply Quote 1
              • duglorD
                duglor @Folly
                This post is deleted!
                • FollyF
                  Folly
                  Update :
                  The database and the add-mamedev-systems.sh are updated to match mame0252.
                  I also added a W.I.P. version called mamedev.sh.
                  This version differs from the add-mamedev-systems.sh.
                  Rather then generating and installing the generated module-scripts like add-mamedev-systems.sh does,
                  mamedev.sh will install systems directly without generating and installing module-scripts.
                  This script is also cleaned up a bit and installing a system works faster.
                  However, since this version doesn't generated module-scripts,
                  systems can't be removed by selecting the module-script from the experimental packages.
                  That's why it's a W.I.P. (Work In Progress) version.
                  So keep in mind, removing a system has to be done manually.
                  Without interfering each-other both versions can be added in :
                  /home/pi/RetroPie-Setup/ext/RetroPie-Share/scriptmodules/supplementary
                  For the mamedev.sh script you can use the same install procedure as mentioned in post 1.
                  Just used the name mamedev.sh instead.
                  • FollyF Folly referenced this topic on
                  • FollyF
                    Folly @DTEAM
                    Hi @DTEAM,
                    How is it going, everything ok ?
                    Today I installed channelf and noticed that there is no media when downloading the gamelist for channelf.
                    Is it gone or has it never been added ?
                    I also found that the games are not properly sorted in emulationstation.
                    I would like to change the range Videocart-1 - Videocart-9 to :
                    Videocart-01 - Videocart-09
                    Adding the zero makes sure that the games are properly sorted in the list of emulationstation.
                    • DTEAMD
                      DTEAM @Folly
                      I deleted it because it's now available on Screenscraper and the result is better with that site. Sorry, I forgot to mention it.
                      New Edit: Maybe I added some missing videos. If it's the case, I'll put those media on the drive
                      • FollyF
                        Folly @DTEAM
                        @DTEAM
                        I tested channelf with retroscraper and the result was very good.
                        So I agree, we don't need the predefined gamelist anymore.
                        I suggest removing the whole directory channelf so there is no misunderstanding about whether there is or isn't a full gamelist+media set.
                        Do you agree ?
                        DTEAMD 2 Replies Last reply Reply Quote 1
                        • DTEAMD
                          DTEAM @Folly
                          Do you agree ?
                          Yes
                          • DTEAMD
                            DTEAM @Folly
                            @Folly
                            MAME 0.253 is released
                            https://www.mamedev.org/?p=523
                            No tsimquest and tmegaman3
                            New classich = Bandai Race Time
                            text alternatif
                            • FollyF
                              Folly @DTEAM
                              Very strange that they are still not added.
                              I will update the database when https://www.progettosnaps.net/ is updated. Curious if "Bandai Race Time" is added when I do an update on the classich.ini.
                              Btw did you try the nabupc of 0.252.
                              I did, but you have to run a server program locally.
                              • DTEAMD
                                DTEAM @Folly
                                Not yet
                                • FollyF
                                  Folly @DTEAM
                                  @DTEAM
                                  Is it something for making a thread ?
                                  • DTEAMD
                                    DTEAM @Folly
                                    Yes or on Old Computer Appreciation Thread
                                    • AshpoolA Ashpool referenced this topic on
                                    • FollyF
                                      Folly
                                      Update to mame0253.00 :
                                      • racetime manually added in classic.ini and good.ini
                                      • database mame0253_systems_sorted_info added
                                      • update scripts add-mamedev-systems.sh and mamedev.sh
                                      • DTEAMD
                                        DTEAM @Folly
                                        @Folly
                                        Race Time is now on the gamelist.xml
                                        https://drive.google.com/drive/folders/1R01U_4xjpBLMYn1FjdhFWFCJnGxHCac6
                                        • FollyF
                                          Folly @DTEAM
                                          @DTEAM
                                          Did you also find some artwork ?
                                          • DTEAMD
                                            DTEAM @Folly
                                            @Folly
                                            I created a video and put a picture of the original box, Nothing fancy.
