    2.3k Posts 37 Posters 9.7m Views
    • DTEAMD
      DTEAM @Folly
      @DTEAM
      MAME 0.255 is out.
      Yes! Many good systems for us in their list
      FROM MAME 0.255:
      New working systems
      TMBASKB Basketball (Tomy) [hap, Sean Riddle]
      KTMNT3 Konami Teenage Mutant Ninja Turtles 3: Shredder's Last Stand (handheld) [algestam, Sean Riddle, Mr. Do]
      KTMNTBB Konami Teenage Mutant Ninja Turtles: Basketball [algestam, Sean Riddle, Mr. Do]
      TRSGKEEP Tronica Super Goal Keeper [algestam]
      TMVOLLEYB Volleyball (Tomy) [hap, Sean Riddle]
      • FollyF
        Folly @DTEAM
        @DTEAM
        Yes indeed, quite some nice stuff ;-)
        If I can then I will update the database next month.
        For the libretro cores :
        I don't expect the libretro syncing for lr-mess/lr-mame with mame come any soon.
        And more problems are arising with lr-mess/lr-mame ;-(
        • duglorD
          duglor
          Does the lr-mess-apple2 or lr-mame-apple2 --- need specific bios(es) and in a certain location for that to work? Currently not launching games for me. Be well! Thanks for everything! KudoS!
          • FollyF
            Folly @duglor
            @duglor
            If you run apple2 with mame in the command prompt and not having any bios files installed it will show this :
            pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame apple2 -ui_active
            a2.chr NOT FOUND (tried in apple2)
            OPTIONAL 341-0016-00.d0 NOT FOUND (tried in apple2)
            341-0001-00.e0 NOT FOUND (tried in apple2)
            341-0002-00.e8 NOT FOUND (tried in apple2)
            341-0003-00.f0 NOT FOUND (tried in apple2)
            341-0004-00.f8 NOT FOUND (tried in apple2)
            sc01a.bin NOT FOUND (tried in votrax apple2)
            341-0027-a.p5 NOT FOUND (tried in a2diskiing apple2)
            341-0028-a.rom NOT FOUND (tried in d2fdc apple2)
            So you need to find all bios roms from above, which means :
            • apple2.zip
            • votrax.zip
            • a2diskiing.zip
            • d2fdc.zip
            My runcommands will force the rompath into using BIOS/mame so the bios files need to go there when using this project and it's runcommands.
            Otherwise, with above command, it will depend on what rompaths there are in your /opt/retropie/configs/mame/mame.ini.
            After adding the files the apple2 should be able to run.
            P.s.
            Be aware that I am not talking about lr-mess here but if it works for mame it will ultimately work with my lr-mess runcommands.
            duglorD 1 Reply Last reply Reply Quote 1
            • duglorD
              duglor @Folly
              @Folly thank you
              • AshpoolA
                Ashpool @Folly
                @Folly Even if it took me somewhat longer, maybe it is time to open a separated topic for vm(ware) and retropie ... [even if it is just being used once in some while].?.
                As I never tried pure Debian (always used Distros based on Debian) for now, this questions of mine could/should(?) belong in such a new thread, but just to mentioning 'em (here 1st, as examples of eventually Q's to be A'd):
                • what debian iso/version to be used for retropie? (currently I've started with 11.7.0, but maybe the 10.# branche would be better suited? [as of June 23])
                • what desktop environment? (I've choosen LXDE, as the Raspion OS Desktop is based/derived from that (afair/?))
                • I was totally flabberghasted when the installer asked me about a domainname/url ending thereof... so what is common practice, or best choice: <.yourchoice>/<.locale>/[empty] ?
                • haven't tried it, but is leaving the admin pw blank an option to auto-add the created user to group sudoers?
                (a basic retropie install went fine on that (11.7), but I wanted to raise those concerns/questions before I going on ;]
                • FollyF
                  Folly @Ashpool
                  @Ashpool
                  Good idea.
                  Though I am not having much time right now but in time we can start a topic (in general discussions i presume).
                  I would suggest to preserve the fist 5 posts for summarizing stuff.
                  Sadly I have an issue again with the newest versions of "lr-mame/lr-mess" in Debian 11 now :
                  https://github.com/libretro/mame/issues/371
                  Seems Ubuntu 22.04 isn't affected.
                  Edit : Issue seems to be solved now
                  Other news for "lr-mame/lr-mess" is that we are waiting for 0.255.
                  Hopefully it will come soon, this seems promising :
                  https://github.com/libretro/mame/issues/373
                  AshpoolA 1 Reply Last reply Reply Quote 1
                  • FollyF
                    Folly @DTEAM
                    @DTEAM @Ashpool
                    Seems I broke all my scripts with my previous updates.
                    Something to do with skipping things when we install a predefined systems or categories.
                    Seems I was skipping a bit too much, so it did not install many stuff at all.
                    The problem was quite ugly.
                    I hope I have fixed it all with my updates to 253.15 ;-)
                    • AshpoolA
                      Ashpool @Folly
                      ACK, I think I can do that tomorrow (This evening i am going to relax with actually playing some game(s) ;)).
                      Wow, noticed that current mame was updated to .254 some time ago but last time i checked the libretro cores wasn't on par.
                      • FollyF
                        Folly @Ashpool
                        @Ashpool said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
                        Correct, the libretro is still on .251.
                        Hopefully it wil be synced to .255 soon ;-)
                        • FollyF
                          Folly
                          I updated all scripts to 255.00 using the latest data from mame 0.255 :
                          https://github.com/FollyMaddy/RetroPie-Share/commit/6f9d64de8e838950eedbb47cd588fbe2f70d5cf8
                          I also updated the test versions in the workdir :
                          https://github.com/FollyMaddy/RetroPie-Share/commit/8232367accf37e32d6202d7250d27f5b9efe4a28
                          Note :
                          Seems coco2 has been merged with coco so the installl-lines from systems with extras need updating.
                          • duglorD
                            duglor @Folly
                            @Folly Is there support via this method for the BBC Micro? Or is there another thread somewhere, Folly? I remember reading something about it sometime ago. I'm looking for a BBC Micro Emulator that works through the Emulation Station like most other games do (like the archimedes emulator) and with joystick support via remapping or what have you? Also any bios files if needed's names and where they go. And location for any roms or .ssd files? etc etc i recently downloading the electron versions you had and the electron bioses and tried to run them but it always kicked me back out. Seems like Mame was trying to run them, but no luck. Perhaps i needed exact roms or exact updated bioses. Anyway, I'm now trying to get a BBC Micro going since the Electron failed on me. Still enjoying Archimedes and FM Towns. - be well!
                            • FollyF
                              Folly @duglor
                              @duglor
                              Well, there is support for bbc micro on mame/lr-mess.
                              However there are many games that will not run on it.
                              In the past I made some module-scripts that use other emulators like you mentioned the one for electron.
                              Sadly everything in linux world is going quick and compiling older source code on newer linux/gcc will not work anymore.
                              That is probably the cause why my bbcmicro and electron scripts do not work correctly anymore.
                              Sadly I have too little knowledge to fix these problems for newer linux/gcc.
                              So in time these emulators can't be used anymore unless somebody has the knowledge to fix these older emulator sources.
                              Remember what I told you about fmtowns.
                              Try to do the same with bbc micro.
                              duglorD 2 Replies Last reply Reply Quote 1
                              • duglorD
                                duglor @Folly
                                @Folly Thanks for the tip. Yes, I remember about the fmtowns. Off hand , do you know if Boffin or Citadel will run on the lr-mess mame bbcmicro? Those are the main two I wanted to play on the pi, but i'll play it on windows if i must . Also to make those work , what is the bios i need for that if you know? Be well and :D Take care!
                                • duglorD
                                  duglor @Folly
                                  @Folly thank you
                                  FollyF 3 Replies Last reply Reply Quote 0
                                  • FollyF
                                    Folly @duglor
                                    @duglor
                                    These are the systems you can choose from :
                                    pi@Bullseye-VM:~$ cat '/opt/retropie/emulators/mame/mame0253_systems_sorted_info' |grep "BBC Micro"
                                    Driver bbca (BBC Micro Model A): @computer@good@home_system@non-arcade
                                    Driver bbcb (BBC Micro Model B): @computer@forum@good@home_system@non-arcade
                                    Driver bbcb_de (BBC Micro Model B (German)): @computer@good@home_system@non-arcade
                                    Driver bbcb_no (BBC Micro Model B (Norway)): @computer@good@home_system@non-arcade
                                    Driver bbcb_us (BBC Micro Model B (US)): @computer@good@home_system@non-arcade
                                    Driver bbcbp (BBC Micro Model B+ 64K): @computer@good@home_system@non-arcade
                                    Driver bbcbp128 (BBC Micro Model B+ 128K): @computer@good@home_system@non-arcade
                                    pi@Bullseye-VM:~$ cat '/opt/retropie/emulators/mame/mame0253_systems_sorted_info' |grep "BBC Master"
                                    Driver bbcm (BBC Master 128): @computer@good@home_system@non-arcade
                                    Driver bbcm512 (BBC Master 512): @computer@good@home_system@non-arcade
                                    Driver bbcmaiv (BBC Master AIV): @computer@home_system@non-arcade
                                    Driver bbcmarm (BBC Master (ARM Evaluation)): @computer@home_system@non-arcade
                                    Driver bbcmc (BBC Master Compact): @computer@good@home_system@non-arcade
                                    Driver bbcmc_ar (BBC Master Compact (Arabic)): @computer@good@home_system@non-arcade
                                    Driver bbcmet (BBC Master ET): @computer@good@home_system@non-arcade
                                    Driver bbcmt (BBC Master Turbo): @computer@good@home_system@non-arcade
                                    • FollyF
                                      Folly @duglor
                                      @duglor
                                      Both games are in the hash table.
                                      You can find in which they are by doing, for example :
                                      pi@Bullseye-VM:~$ cd '/opt/retropie/emulators/mame/hash'
                                      pi@Bullseye-VM:/opt/retropie/emulators/mame/hash$ grep -r Boffin
                                      bbc_cass.xml:		<description>Boffin</description>
                                      bbc_cass.xml:		<description>Boffin 2</description>
                                      electron_cass.xml:		<description>Boffin</description>
                                      Then look into the bbc_cass.xml file and you will see that it probably will run as there is not a mentioning of "not supported".
                                      For Citadel it is the same.
                                      The load command is also found in the hash table for Boffin :
                                      <info name="usage" value="Load with *RUN" />
                                      Otherwise look in the page of @dmmarti :
                                      https://docs.google.com/spreadsheets/d/1AQ28J9OUKg55R3d-TZkWO3GH50KjC2hHteCP1Bx59Ns/edit#gid=0
                                      • FollyF
                                        Folly @duglor
                                        @duglor said in Development of module-script generator for lr-mess, lr-mame and mame standalone:
                                        Decide what driver you want to use.
                                        Then use the same trick that I told you about fmtowns.
                                        Bios files are found in the mame-merged romset (arcade game bios files + non-arcade bios files)
                                        Cass files can be found in the bbc_cass.zip from mame-sl (sl = softlist = software list)
                                        • FollyF
                                          Folly @duglor
                                          @duglor
                                          I used bbcb and both games worked.
                                          load command for boffin is :
                                          *TAPE
                                          *RUN
                                          For citadel it is :
                                          *TAPE
                                          CHAIN ""
                                          Use "page-down" to speed up loading in mame. (or space in lr-mess)
                                          • duglorD
                                            duglor @Folly
                                            @Folly Yep. Both games worked here too! Thanks a ton for your help. If not for you, I probably would not have 4 systems on the pi, and so many games. THANKS!!!!!!!!!!!!!!!!!!!!!!
