    2.3k Posts 37 Posters 9.7m Views
    • FollyF
      Folly @DTEAM
      @DTEAM
      Just found something about pcecd I read that it's an addon.
      Will have a look if I can find the files and how to load it.
      This command gives information that -cdrm (.chd) file can be loaded with just using pce.
      pi@pi-2204:~$ /opt/retropie/emulators/mame/mame -listmedia pce
      SYSTEM           MEDIA NAME       (brief)    IMAGE FILE EXTENSIONS SUPPORTED
      pce              cdrom            (cdrm)     .chd  .cue  .toc  .nrg  .gdi  .iso  .cdr
      pce              cartridge        (cart)     .pce  .bin
      So, again, I think you have typo in the runcommand :
      pce pcecd
      Just use :
      pce
      Edit :
      Above did not work.
      It will ask for a cartridge.
      Tried gecd boots but Loom.chd did not work.
      (Haven't got your game yet.)
      Will try some more.
      • DTEAMD
        DTEAM @Folly
        @Folly
        Same problem on my side. It ask for a cartridge. I'll take a look on the notes in the pce_cd.cpp file
        http://adb.arcadeitalia.net/download_file.php?tipo=sourcefile&codice=pcecd&emulator=964&oper=view
        FollyF 3 Replies Last reply Reply Quote 1
        • FollyF
          Folly @DTEAM
          @DTEAM
          Everything is down now so I can't get any files.
          Will try to get bbros tomorrow so I can test with softlist loading and eventually without.
          • FollyF
            Folly @DTEAM
            @DTEAM
            Edit : A solution is in the next post. This post seems irrelevant.
            I think they need to add HuCard slots in pce_cd.cpp.
            (// TODO: correct name, split into incremental HuCard slot devices)
            Listslots will give :
            pi@pi-2204:~/RetroPie/roms/pcengine/cylums-turbo-grafx-cd-rom-collection$ /opt/retropie/emulators/mame/mame -listslots pce
            SYSTEM           SLOT NAME        SLOT OPTIONS     SLOT DEVICE NAME
            pce              ctrl             arcade_pad_6     NEC Arcade Pad 6
                                              avenue_pad_6     NEC Avenue Pad 6
                                              joypad2          NEC PC Engine Pad
                                              joypad2_turbo    NEC PC Engine/TurboGrafx-16 2 Button Joypad
                                              mouse            NEC PC Engine Mouse
                                              multitap         NEC PC Engine/TurboGrafx-16 Multi Tap
                                              pachinko         Coconuts Japan Pachinko Controller CJPC-101
                                              pcjoy            Micom Soft XHE-3 PC Joystick Adapter for PC Engine
                             cartslot         [none]           No options available
            You see that there are no cartslots available.
            Don't know if it is correct but it seems it's only possible to softload pcecd files.
            • FollyF
              Folly @DTEAM
              @DTEAM
              I have Loom.chd booting now ;-)
              I had a look at the PC-Engine docs and found that lr-beetle-XXXXX needs syscard or equivalent to boot cd's.
              So I had a search in the the software for pce.
              /opt/retropie/emulators/mame/mame -listsoftware pce|grep cdsys
              The cdsys.zip file contains all version of syscard (cdsys,cdsysa and cdsysb)
              I tried them all on my Loom.chd and It booted in the CD boot screen.
              After pressing "1" it will mention that Loom requires the Super CD-ROM System.
              After a good search the rom for mame is scdsys, obviously.
              So I did a test with that rom with this test cmd :
              pi@pi-2204:~/RetroPie/roms/pcengine/cylums-turbo-grafx-cd-rom-collection$ /opt/retropie/emulators/mame/mame -rompath . pce scdsys -cdrm Loom.chd
              Putting the scdsys.zip in the same directory as the game.
              Now after pressing "1" the game boots !
              So I don't have the bbuster.chd yet, as everything is still down.
              But this is something you can try.
              Just add these cdsys and scdsys files in BIOS/mame and add one of them instead of ~~pcecd~~.
              Let me know if it works.
              ps. scdsys is probably the best way to go as it looks like it is the latest version and will probably cover most games.
              • FollyF Folly referenced this topic on
              • DTEAMD
                DTEAM @Folly
                @Folly
                Wow, nice work! You are now a MAME expert!
                Glad to see you solved this puzzle!
                NEW EDIT: I can't find cdsys and scdsys. I'll continue to search them on google
                FollyF 4 Replies Last reply Reply Quote 1
                • FollyF
                  Folly @DTEAM
                  @DTEAM
                  Added to the normal versions (now 253.08) (commit has wrong version (mistake)) :
                  https://github.com/FollyMaddy/RetroPie-Share/commit/e6b9900cc28e4d6b673a28e4e19c71066db05e0f
                  Can you test !
                  Help has been added, look at that too.
                  BIOS can be in BIOS/mame/pce
                  • FollyF
                    Folly @DTEAM
                    Read my help in the install line.
                    • FollyF
                      Folly @Ashpool
                      @Ashpool
                      I am probably moving back to my Debian 11 VM.
                      Ubuntu 22.04 already gives multiple things that need fixing.
                      If you are familiar with these problems we can add a separate thread for this and discuss it over there.
                      The issues are :
                      • emulationstation and emulators not centered in desktop display
                        • solution is to enable auto-removing the top-panel/top-bar so emulationstation will use the whole screen. (install the extension manager from ubuntu software and enable hide top-bar)
                        • https://fostips.com/auto-hide-top-panel-debian-ubuntu-fedora/
                      • OSX shortcut key combinations interfere with the Ubuntu VM
                        • solution is to change some shortcut key-combinations in OSX so they don't interfere with ctrl in combination with the cursor keys in the Ubuntu VM (^->,^<-, etc)
                      • apple keyboard keys aren't all correct and can't find a solution
                      • apple keyboard FN key not working for using F1 - F12 (solution was to set keyboard & mouse, in the VMware, on on mac profile)
                      • selecting multiple files with the ctrl-key in nautilus doesn't work, also no solution found
                        • tried caja and it doesn't work in caja either so the issue seems not file-explorer related
                      • Ubuntu key combo's (ctrl+alt) activate unwanted conflicts when playing games
                      • moving files from the host to the VM doesn't work
                        (VMware tools is noted as installed and copy/past of text works)
                        • reinstalling open-vm-tools + open-vm-tools-desktop did not work
                        • using caja instead of nautilus works but a drag file icon is displayed which cannot be removed without restart or logging out and logging in
                        • logging out and logging in and selecting the settings icon to open Ubuntu on xorg seemed to be a solution however the VM will freeze/lock (and is troublesome to shutdown or restart)
                      • It's a bit slower than Debian
                      I had hoped it was better but I expect much more issues.
                      AshpoolA 1 Reply Last reply Reply Quote 0
                      • FollyF
                        Folly @DTEAM
                        @DTEAM
                        Tested already many files from the chd_pcecd romset.
                        And Buster Bros. (USA) from the redump.pce.revival works too.
                        Up til now many work ;-)
                        I hope the speed is ok on the pi4, can't test right now.
                        • AshpoolA
                          Ashpool @Folly
                          @Folly
                          Sounds like a good idea (though I never used pure debain so far), i also encountered some trouble whence using shared folders now: seem to be working right after enabling 'em, but not anymore after a reboot/restart (need to be deactivated, all FS traces removed from the guest (media target folders) and then can be enabled again). Guess the OpenVMware-Tools need some overhaul in regards to nowadays Ubuntu. But for me setting up a new vm has has to wait 'till next week, as i am currently abroad.
                          • FollyF
                            Folly @Ashpool
                            @Ashpool
                            We can make threads of both in general discussion and discuss installation and issues we face.
                            Let's see next week or so.
                            • FollyF
                              Folly @DTEAM
                              @DTEAM
                              Any news ?
                              • DTEAMD
                                DTEAM @Folly
                                @Folly
                                It doesn't work with No-Intro Roms, i'll try with MAME roms
                                I got the good BIOS
                                • FollyF
                                  Folly @DTEAM
                                  Looks like No-intro roms (nointro-merged) are just regular pce files and no cd-rom files.
                                  • DTEAMD
                                    DTEAM @Folly
                                    @Folly
                                    It works with:
                                    mame-system-pcecd-cdrm-autoframeskip = "/opt/retropie/emulators/mame/mame -v -c -autoframeskip -ui_active pce scdsys -cdrm %ROM%"
                                    I added scdsys in my command line. It was my error.
                                    • FollyF
                                      Folly @DTEAM
                                      pcecd
                                      Should not be in there.
                                      You use the latest mame, right ?
                                      DTEAMD 2 Replies Last reply Reply Quote 0
                                      • DTEAMD
                                        DTEAM @Folly
                                        @Folly
                                        The speed is very good on a PI4 but without autoframeskip.
                                        I recommend:
                                        mame-system-pcecd-cdrm = "/opt/retropie/emulators/mame/mame -v -c  -ui_active pce cdsys -cdrm %ROM%"
                                        • FollyF
                                          Folly @DTEAM
                                          @Folly
                                          I recommend:
                                          Is the speed better with that bios ?
                                          Btw. I can add that line too if needed, What do you think ?
                                          • DTEAMD
                                            DTEAM @Folly
                                            pcecd
                                            My bad for pcecd, I did a cut and paste from my previous post , but it's not in my real command line. I modified my post.
