    2.2k Posts 36 Posters 6.4m Views
      bbilford83
      Btw the baseball one doesn't work in retroarch as an overlay for me without shrinking down the screen display in a way I can't figure out - same issue as with the microvision - but that is only necessary because the area outside the handheld's display says stuff that makes you understand the game (what inning it is, strikes and balls, etc.). I just tested out Pacman2 and that one actually can be played with a "cropped" retroarch overlay, even though it is uglier. Hopefully this will be clear...
      "Full" overlay image that doesn't align to gameplay at all:
      "Cropped" overlay image that works perfectly for gameplay but looks kind of ugly:
      Btw it is correct that the overlay is rotated 90 degrees like that. Because it was designed for all games to be two-player, controls were on the left and the right of the screen. I confirmed through gameplay that if you rotated the screen 90 degrees the buttons would not work right (up would be right, etc.), so this is the "view" you would've actually played with back then even when playing one-player (maybe why it was discontinued so quick!).
      This pac-man is pretty awful but still charming.
        bbilford83
        OK @Folly it is pretty ugly but I was actually able to create retroarch overlay images that "work" for all four of the games that I had overlays for to begin with, so even if you can't help out with MAME art this will be good enough (if not great) for me. Here is a folder with all four un-cropped and cropped so you can see how I did it. FYI, space invaders for some reason only lets you play as player 2, so not only did I have to flip the overlay 180 degrees I also had to save an override rotating the screen display in retroarch 180 degrees. I doubt that could be integrated in your script so that is kind of a bummer, but it wasn't too hard to figure out once I realized it was only letting me play as P2.
        I may have found a good enough photo of the basketball overlay that I can make a working one out of it too, will try that tomorrow.
        Edit: I was able to make one for basketball by editing a high-res photo I found online, though it is not great - I added it to the folder. I think the football one may be a lost cause. Calling it a night for now but at least I have a setup that makes most of them playable.
        • F
          Folly @bbilford83
          @bbilford83
          Good luck.
          Will have a look later at it all.
            bbilford83 @Folly
            @Folly and @DTEAM, just FYI I have added a gamelist and images for the Entex Select-a-Game along ("sag") with all the others I have shared in the google drive folder that is now integrated with @Folly's script. I only have five of the six games listed because the sixth - football - I still can't find an overlay for anywhere and it isn't really playable without it. But if I do find it I will update.
            The games play very similarly (some even have the same names) as the Entex handhelds already in the "classic handheld" list. So I think it would probably be nice to include but of course it's fine with me if it's just in my WIP linked stuff.
            • F
              Folly @bbilford83
              @bbilford83
              I just installed sag with the the roms from entex_sag.
              Seems to be a very simple and fun handheld.
              Strange that the score is flipped and the game is not.
              Can't access your overlays though as you have not opened it for sharing.
              You know the overlay *.cfg files are basically reduced retroarch.cfg files,
              so you could try to add the rotation override in there for the space invaders instead of in the other retroarch.cfg so it can be shared easily.
              Not 100% sure it will work but it's very likely.
              Btw. you should add a comments in the overlay *.cfg files for which resolution the overlays are made.
              So then people know if they can use them or they can be converted if they have the knowledge to do so.
              Perhaps an idea to directly share them with your gamelist adding the main overlay *.cfg files next to the gamelist.xml file and adding the overlays in, for example :
              media/retroarch/overlays
              Just to see if it is a nice solution and see if it is possible.
              Hope it's not going to be a mess ;-), but we can always revert.
                bbilford83 @Folly
                @bbilford83
                You know the *.cfg files are basically reduced retroarch.cfg files,
                Btw. you should add a comments in the *.cfg files for which resolution the overlays are made.
                Perhaps an idea to directly share them with your gamelist adding the main *.cfg files next to the gamelist.xml file and adding the overlays in, for example :
                Thanks @Folly. I think I just fixed the access to the overlays, sorry about that.
                I will think about how best to do the .cfg stuff you are mentioning, I agree it would be nicer if it could be automated. But I have an exciting task to do first - I think I just found a usable version of the Football overlay in an ebay listing. No idea why it wasn't coming up before, I tried a million searches. So I am going to try to make that overlay first and then fix the gamelist so it has all six games - I'll update the gdrive after :).
                • F
                  Folly @bbilford83
                  I liked you pictures and good to hear you have found football too ;-)
                  Noticed though that they seem to be very similar.
                  Just an idea.
                  If you have a better understanding of gimp you could use the best picture and paste the cartridge and re-apply new text in there so all the pictures would be somewhat the same and of about the same "higher" quality.
                    bbilford83 @Folly
                    Even without doing that I was considering changing to photos of the cartridge, those I think I could find for all six even without gimp edits. I like the ones I used because they have more info and colors but I don't think I'm going to find it for football and I do like having them all similar.
                    • F
                      Folly @bbilford83
                      @bbilford83
                      I am experimenting with the ovelays.
                      I see that they are probably not bound to resolution changes.
                      Seems everything is loaded but the overlay is not displayed.
                      Mmmm... will have a second look later.
                      B 2 Replies Last reply Reply Quote 0
                        bbilford83 @Folly
                        @Folly OK. I think it would be much better-looking if it were the mame art rather than a retroarch overlay, but I'm not even going to try again since last time I got nowhere... sorry. It turns out at least only one of the overlays has info that matters and is cut off when you crop it (baseball). All the others you just lose the good looks, not function.
                          bbilford83 @Folly
                          @Folly I took your advice and did the gimp thing with the cartridges, replaced the art for the gamelist. I agree it looks much cleaner this way.
                          • F
                            Folly @bbilford83
                            @bbilford83
                            I have a pure retroarch overlay working now and could somehow use a semi absolute path, in the overlay config file :
                            ~/RetroPie/roms/sag/media/retroarch/overlays/sag-pacman2.cfg
                            The season it didn't work is that I forgot a folder in the path, haha.
                            See now why you cropped it as the overlay doesn't match up.
                            Will look at it if I can think of a solution.
                            Aha, playable now with a pure retroarch ovelay using a the cropped image:
                              bbilford83 @Folly
                              Yes that's how I'm playing it - certainly good enough but it would be nice to be able to see the whole overlay.
                              I am having an unexpected problem. If you have a moment, can you try to run footb4? It won't play for me! And I found a different source and it still won't work. The .zip has 3 files in it instead of 1, like all the others. I tried deleting the other two (and tried after deleting only one and then the other) and it still isn't running. I haven't seen anything to suggest it wasn't a good dump though...
                              • F
                                Folly @bbilford83
                                Seem to run.
                                It started odd and pressed "space" and then it seems to start ok.
                                  bbilford83 @Folly
                                  Seem to run.
                                  Thanks, made me keep trying and I discovered it works if I run it in the basename option but not in the cart option. I had the default set to cart and it worked with all the others. Weird.
                                  Also FYI I got the football overlay working well! It is added to the folder, both cropped and not cropped. It was trickier than some of the others because one row on each side of the LEDs is not used - the overlay is meant to cover them. The resolution is notably lower than the other ones I made but I think it is good enough. This one is like the baseball one that it has words indicating what some lights mean, but they're all on the inside of even the cropped overlay (on the inside of the scoreboard), so that's nice.
                                  I will update the gamelist in a bit and then that system is complete, very satisfying when there are only six games :). Edit: done.
                                  • F
                                    Folly @bbilford83
                                    @bbilford83
                                    Found a solution for scaling the game so it becomes tinier.
                                    Sadly the ovelay goes with it and can't be scaled bigger this way, so can't use this solution.
                                    Seems we are stuck right now with the cropped ones.
                                    If you like I can share the overlays + configs together with your gamelist.
                                      bbilford83 @Folly
                                      @bbilford83
                                      Of course, feel free. I'll add the overlay .cfg files to the same folder with the overlay pngs. I am leaving the full-size ones there too in case we figure out a better solution later.
                                      Btw, probably you already thought of this, but whatever you did to make the game tinier, did you try changing the setting for the overlay file to say this?
                                      overlay0_full_screen = true
                                      Default is usually false, I think.
                                      • F
                                        Folly @bbilford83
                                        Yes usually it's false.
                                        Though we can experiment scaling the video smaller and making the overlay fullscreen.
                                        Perhaps it can work.
                                        Btw,
                                        I am almost ready, no need to do the same.
                                        Edit :
                                        Took me while but I have added it now.
                                        ( make sure you backup if you have the same files in the same place ;-) )
                                          bbilford83 @Folly
                                          @Folly forgive me I'm confused, do you mean you figured out how to use the full overlay with the game shrunk in it?
                                          • F
                                            Folly @bbilford83
                                            @bbilford83
                                            No not ready it was an idea I got when you asked me about this :
                                            I have added false in the overlay configs and uploaded it all to my gamelists so you can download it with my script (or manual if you want).
                                            Let me know if it works for you.
