    2.3k Posts 37 Posters 8.7m Views
    • DTEAMD
      DTEAM @Folly
      @folly @valerino
      So now, the next step is to try to put it on the official Retropie (like we already said above) and I think we should come up with something for this outdated link: https://retropie.org.uk/docs/MESS/
      • FollyF
        Folly @DTEAM
        @folly @valerino
        Yes, indeed pretty outdated.
        I think we first have to have the module-script ready. (with menu)
        If that works, we should focus on the doc.
        @valerino ,
        Did you have some time to make some module-script with a basic menu ?
        • FollyF
          Folly
          @DTEAM
          I read in the c64 hash tables, they use pretty much only .g64 format discs.
          Perhaps we have to try the .g64 formats for the c64.
          • DTEAMD
            DTEAM @Folly
            @folly
            Good to know. My files are .D64 or T64. I'll do more test. Did you try .zip from Mess romset?
            • FollyF
              Folly @DTEAM
              @dteam
              Didn't try the mess romset.
              I have to look for it.
              btw.
              What's the now at your place ?
              Here it's almost 15:00 (30-03-2021)
              • DTEAMD
                DTEAM @Folly
                @folly
                9:00 am (2021-03-30)
                • FollyF
                  Folly
                  @DTEAM
                  I tried a .T64 in the menu, because it would not start.
                  I got this :
                  • FollyF
                    Folly @DTEAM
                    @folly
                    Aha, 6 hour earlier.
                    So, you have a whole day ahead of you !
                    I had a look in the mame output :
                    pi@raspberrypi:~ $ /opt/retropie/emulators/mame/mame -listmedia c64
                    SYSTEM           MEDIA NAME       (brief)    IMAGE FILE EXTENSIONS SUPPORTED
                    c64              cassette         (cass)     .wav  .tap
                                     floppydisk       (flop)     .d64  .g64  .g41  .g71  .d77  .d88  .1dd  .dfi  .hfe  .imd  .ipf  .mfi  .mfm  .td0  .cqm  .cqi  .dsk
                                     cartridge        (cart)     .80   .a0   .e0   .crt
                                     quickload        (quik)     .p00  .prg  .t64
                    Seems we have to use (quik) for .t64. (edit: didn't work)
                    • DTEAMD
                      DTEAM @Folly
                      @folly
                      It will be easier with this output. Thanks
                      • FollyF
                        Folly @DTEAM
                        @dteam
                        This is a .tap file with the (cass) option :
                        2021-03-30-151133_800x600_scrot-resized.png 2021-03-30-151816_800x600_scrot-resized.png 2021-03-30-151820_800x600_scrot-resized.png
                        2021-03-30-151907_800x600_scrot-resized.png 2021-03-30-152014_800x600_scrot-resized.png 2021-03-30-152135_800x600_scrot-resized.png
                        The joystick doesn't work.
                        But I think I have to change this in "slot devices" before load.
                        • DTEAMD
                          DTEAM @Folly
                          @folly
                          I'm fighting with Bios files. I'll be good to do something soon... I hope.
                          • FollyF
                            Folly @DTEAM
                            @folly
                            I am using old MESS-0.151.BIOS.ROMs .
                            For many systems they still work.
                            I think you know where to find it.
                            I loaded the .prg of boulder-dash with (quik).
                            Went to the menu, slot devices, turned off joy2, turned on joy1, reset, I think it will exit to basic.
                            Then I did run in basic, now I could play boulder-dash.
                            • DTEAMD
                              DTEAM @Folly
                              @folly
                              I'm using MAME 0.229. I'm gonna try 0.151
                              • DTEAMD
                                DTEAM @DTEAM
                                @dteam
                                Now It works hehe
                                Mess romset (.zip) works and BIOS 0.229 also. I did a bad file extraction from zip to FileZilla. Sometime the gameplay is a pain in the ass, but It works.
                                • FollyF
                                  Folly @DTEAM
                                  @dteam
                                  Seems most people do it that way.
                                  I use my pi as desktop computer + retropie.
                                  Perhaps an idea to use a "raspberry pi os with desktop" and install retropie on top, then you don't have to struggle with ssh and filezilla.
                                  On the pi4 "emulationstation" can run in the desktop environment.
                                  Or you can just boot in cli or go back in cli and run "emulationstation" without going to the desktop. (works with pretty much all pi's)
                                  You can even run games from the file manager if you install my RetroRun script. (works with pretty much all pi's)
                                  Interesting ?
                                  • DTEAMD
                                    DTEAM @Folly
                                    @folly
                                    On my side, I'm running RetroPie on a handheld build. I did that for a Pi3 more than 2 years ago and I converted It for a Pi4 (It's really tight). I have used recycled materials (screws, old controller, LEGO parts, wooden tin for clementines, door screen, springs, old plank, old pencil basket) and materials from my children's DIY material basket (Popsicle sticks and toothpicks). Maybe It looks like hell but the gameplay is wonderfull , it's solid and the battery is huge (10000 mAh). For the controller, I have used a Teensy LC and for the touchscreen, It's a 5 inch (The touchscreen works well with Drastic for Nintendo DS). For USB and HDMI, I have used ribbon wiring. I have used a small amp for the speakers (stereo sound). SD card = 512 GB
                                    FollyF 1 Reply Last reply Reply Quote 2
                                    • FollyF
                                      Folly @DTEAM
                                      @dteam
                                      Oh I see, that's a different story.
                                      Now I see why you are doing ssh and filezilla !
                                      I must say, looks very cool.
                                      You must have enjoyed building it.
                                      Nice job !
                                      • DTEAMD
                                        DTEAM @Folly
                                        @dteam
                                        Nice job !
                                        Thanks. Yes, It was a really fun creative project to do. I recommend it to everyone. It took me a lot of time to do it. I had to use wooden clamps for each piece. I preferred this project more to the one I did with a 3d printer for a Pi Zero. The wooden project is original and It's not a copy from another project (even the electronic part of it !!)
                                        • FollyF
                                          Folly @DTEAM
                                          @dteam
                                          I can refer to it.
                                          It's always fun to do your own thing.
                                          If I have some time, I will make some photo's of my projects.
                                          • FollyF
                                            Folly
                                            @DTEAM @valerino
                                            Today I had a look a config module-scripts (docsview.sh) containing the dialog api.
                                            It took me quite some time but I changed it a bit to get the systems into the dialog menu.
                                            I was also able to generate some scripts.
                                            It's nowhere near how we want it.
                                            But it's a start of finding out how we can do this.
                                            I takes about 15 seconds to extract the systems from mame and display them in the menu.
                                            Basically I got this :
                                            With the RetroPie-Setup we are root user.
                                            So the generator-script, which contains the $HOME string wants to do all in the root directory.
                                            So we have to come up with something to fix this.
                                            This is the log selecting a system and generate some module-scripts :
                                            Running action 'gui' for 'add' : RetroPie-Setup Docs Viewer
                                              % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                              0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
                                              2 29333    2   863    0     0   1913      0  0:00:15 --:--:--  0:00:15  1909
                                            100 29333  100 29333    0     0  64326      0 --:--:-- --:--:-- --:--:-- 64185
                                            install @valerino run_mess.sh script
                                            /root/RetroPie-Setup/scriptmodules/run_mess.sh: No such file or directory
                                            read all available extensions per system
                                            read compatible extension(s) for the individual media
                                            read computer description(s)
                                            read and match RetroPie names with mamedev names
                                            cat: /root/RetroPie-Setup/platforms.cfg: No such file or directory
                                            generate and write the install-<RPname>-from-mamedev-system-<MESSname><-media>.sh script file(s)
                                            generate and write the install-<RPname>-cmd.sh command script file(s)
                                            grep: /root/RetroPie-Setup/platforms.cfg: No such file or directory
                                            Log ended at: Wed Mar 31 21:03:49 CEST 2021
                                            Total running time: 0 hours, 0 mins, 52 secs
                                            DTEAMD V 2 Replies Last reply Reply Quote 2
