    Need help with saving data.
    retropie 4.1 piplaystationconfigedit
    7 Posts 3 Posters 911 Views
    • W
      W1ck3rm4n
      Hello I have been changing my retroarch.cfg all files in CONFIGEDIT; I have to do this to get Retroarch to work and therefore all of my games which need the program. My question is, how do I keep the settings that I set in CONFIGEDTI, every time I turn off the retropie I have to set those settings again.
      Also, my PlayStation emulator doesn't work unless I install from source and that is annoying as well...
      Thanks, hopefully other people are having this problem...
        dankcushions Global Moderator @W1ck3rm4n
        @w1ck3rm4n please fill out https://retropie.org.uk/forum/topic/3/read-this-first
        • W
          W1ck3rm4n
          Pi3 model b+
          version 4.1
          controller, playstation 3
          Idk the rest, I brought it off ebay
          Looked through "read this first" and couldn't find a relation to this post...
            @w1ck3rm4n said in Need help with saving data.:
            Pi3 model b+
            version 4.1
            sorry, but we do not support third party images, as per point 5 in https://retropie.org.uk/forum/topic/3/read-this-first. additionally, preloaded systems break the license, as per here
            at a guess, your SD card is corrupt and in read-only mode, but with a third party image all bets are off. your best bet is to start from fresh via https://retropie.org.uk/docs/First-Installation/
            • W
              W1ck3rm4n @dankcushions
              @dankcushions
              Just wondering if I will lose emulationstation by first installation.
              DreamcastKidD 1 Reply Last reply Reply Quote 0
              • DreamcastKidD
                DreamcastKid Banned @W1ck3rm4n
                If you start again from scratch with a fresh installation of the Official Retropie Image .. you will lose everything.
                • W
                  W1ck3rm4n @DreamcastKid
                  @dreamcastkid Deleted what?
