    No Games will load
    not loading
    57 Posts 4 Posters 13.2k Views
      Ken Tipton @Ken Tipton
      Here is another game. All of them do the same thing.
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fbneo/fbneo_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/1942.zip" --verbose --appendconfig /dev/shm/retroarch.cfg
      [INFO] RetroArch 1.8.8 (Git 9552f87)
      [INFO] Redirecting save file to "/home/pi/RetroPie/roms/arcade/1942.srm".
      [INFO] Redirecting save state to "/home/pi/RetroPie/roms/arcade/1942.state".
      [INFO] Capabilities: NEON VFPv3 VFPv4
      [INFO] Built: Mar 27 2021
      [INFO] Version: 1.8.8
      [INFO] Git: 9552f87
      [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-fbneo/fbneo_libretro.so"
      [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/FinalBurn Neo/FinalBurn Neo.cfg.
      [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/FinalBurn Neo/arcade.cfg.
      [INFO] [Overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/FinalBurn Neo/1942.cfg.
      [INFO] [Remaps]: remap directory: /home/pi/.config/retroarch/config/remaps
      [INFO] [Environ]: GET_LOG_INTERFACE.
      [INFO] [Environ]: UNSUPPORTED (#62).
      [INFO] Content loading skipped. Implementation will load it on its own.
      [libretro INFO] Setting save dir to /home/pi/RetroPie/roms/arcade/
      [INFO] [Environ]: SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS".
      [libretro INFO] Setting system dir to /home/pi/RetroPie/BIOS
      [INFO] [Environ]: SET_CONTROLLER_INFO.
      [libretro INFO] Initialize DIP switches.
      [INFO] [Environ]: RETRO_ENVIRONMENT_SET_CORE_OPTIONS_INTL.
      [libretro INFO] [FBNeo] Searching all possible locations for romset 1942
      [libretro INFO] [FBNeo] No patched romset found at /home/pi/RetroPie/BIOS/fbneo/patched/1942
      [libretro INFO] [FBNeo] Romset found at /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] No romset found at /home/pi/RetroPie/BIOS/fbneo/1942
      [libretro INFO] [FBNeo] No romset found at /home/pi/RetroPie/BIOS/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name srb-03.m3 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name srb-04.m4 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name srb-05.m5 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name srb-06.m6 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name srb-07.m7 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-01.c11 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-02.f2 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-08.a1 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-09.a2 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-10.a3 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-11.a4 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-12.a5 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-13.a6 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-14.l1 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-15.l2 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-16.n1 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sr-17.n2 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sb-5.e8 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sb-6.e9 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sb-7.e10 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sb-0.f1 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sb-4.d6 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sb-8.k3 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sb-2.d1 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sb-3.d2 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sb-1.k6 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] Using ROM with good CRC and name sb-9.m11 from archive /home/pi/RetroPie/roms/arcade/1942
      [libretro INFO] [FBNeo] No missing files, proceeding
      [libretro INFO] [FBNeo] Samplerate set to 48000
      [libretro INFO] [FBNeo] Applied dipswitches from core options
      [libretro INFO] [FBNeo] Initialized driver for 1942
      [libretro INFO] [FBNeo] Adjusted audio buffer to match driver's refresh rate (60.000000 Hz)
      [libretro INFO] [Cheevos] System RAM set to 0xf3dda8, size is 9344
      [INFO] [Environ]: SET_ROTATION: 1
      [INFO] [Environ]: SET_PIXEL_FORMAT: XRGB8888.
      [libretro INFO] [FBNeo] Driver 1942 was successfully started : game's full name is 1942 (Revision B)
      [INFO] Skipping SRAM load..
      [INFO] Version of libretro API: 1
      [INFO] Compiled against API: 1
      [INFO] [Cheats]: Load game-specific cheatfile: /home/pi/.config/retroarch/cheats/FinalBurn Neo/1942.cht
      [INFO] [Audio]: Set audio input rate to: 48000.00 Hz.
      [INFO] [Video]: Video @ 504x672
      [INFO] [Video]: Starting threaded video driver ...
      [INFO] [EGL] Falling back to eglGetDisplay
      [INFO] [EGL]: EGL version: 1.4
      [INFO] [EGL]: Current context: 0x1.
      [INFO] [GL]: Found GL context: videocore
      [INFO] [GL]: Detecting screen resolution 1920x1080.
      [INFO] [EGL]: eglSwapInterval(1)
      [INFO] [GL]: Vendor: Broadcom, Renderer: VideoCore IV HW.
      [INFO] [GL]: Version: OpenGL ES 2.0.
      [INFO] Querying EGL extension: KHR_image => exists
      [INFO] [GL]: Using resolution 1920x1080
      [INFO] [GL]: Default shader backend found: glsl.
      [INFO] [Shader driver]: Using GLSL shader backend.
      [WARN] [GL]: Stock GLSL shaders will be used.
      [INFO] [GLSL]: Found GLSL vertex shader.
      [INFO] Shader log: Compiled
      [INFO] [GLSL]: Found GLSL fragment shader.
      [INFO] [GLSL]: Linking GLSL program.
      [INFO] Setting up menu pipeline shaders for XMB ...
      [INFO] [GLSL]: Compiling ribbon shader..
      [INFO] [GLSL]: Compiling simple ribbon shader..
      [INFO] [GLSL]: Compiling snow shader..
      [INFO] [GLSL]: Compiling modern snow shader..
      [INFO] [GLSL]: Compiling bokeh shader..
      [INFO] [GLSL]: Compiling snowflake shader..
      [INFO] [GL]: Using 4 textures.
      [INFO] [GL]: Loaded 1 program(s).
      [INFO] [Font]: Using font rendering backend: freetype.
      [INFO] [Video]: Graphics driver did not initialize an input driver. Attempting to pick a suitable driver.
      /opt/retropie/supplementary/runcommand/runcommand.sh: line 1285: 1909 Segmentation fault /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fbneo/fbneo_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/1942.zip" --verbose --appendconfig /dev/shm/retroarch.cfg
        Ken Tipton
        so I removed the Arcade folder completely and replaced it with a know good folder and same thing. I think it may be the emulators. Where is the root directory for the emulators. The Arcade folder I added has emulators in it but these are not the ones that show up on the game so I assume the parent files are stored somewhere other then the Arcade folder.
        Thank you
        Ken
        IanDaemonI 1 Reply Last reply Reply Quote 0
        • IanDaemonI
          IanDaemon @Ken Tipton
          @ken-tipton Why did you put emulators in the ROM folder? How do you expect anyone to be able to help you when you "customize" the files and file locations?
          • Cocktail Cabinet Games
          • Check out the MAME RoW
            mitu Global Moderator @IanDaemon
            @iandaemon I don't think that's what they meant. The log shows the emulator is in the usual place.
            @Ken-Tipton the emulator is retroarch, in /opt/retropie/emulators. Do you have any remaps for the game ? Did you use the RetroArch's RGUI to reset/save the configuration file ?
            K IanDaemonI 2 Replies Last reply Reply Quote 0
              Ken Tipton @mitu
              @mitu said in No Games will load:
              I did not reset or save a config file. All games in the Arcade folder just stopped working I didn't do anything diffrent.
              1. I copied entire Arcade folder to my desktop PC
              2. I deleted Arcade folder from retropie via ssh
              3. I reloaded a known good Arcade file from another sd card. (I played games on this card and they loaded fine.) I copied the Entire Arcade folder from this SD to my Desktop PC then loaded it to Retropie using ssh
              4. Inside the Arcade folder are game roms and emulators along with art sets.
              5. I went to retropie setup and updated my most used emulator cores.
              • IanDaemonI
                IanDaemon @mitu
                @mitu They said "The Arcade folder I added has emulators in it", that's all.
                  Ken Tipton
                  this is the latest log after doing what listed above
                  Parameters:
                  Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/asteroid.zip" --verbose --appendconfig /dev/shm/retroarch.cfg
                  [INFO] Redirecting save file to "/home/pi/RetroPie/roms/arcade/asteroid.srm".
                  [INFO] Redirecting save state to "/home/pi/RetroPie/roms/arcade/asteroid.state".
                  [INFO] Git: 9552f87
                  [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so"
                  [INFO] [Overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/MAME 2003-Plus.cfg.
                  [INFO] [Overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/arcade.cfg.
                  [INFO] [Overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/MAME 2003-Plus/asteroid.cfg.
                  [INFO] [Environ]: PERFORMANCE_LEVEL: 10.
                  [libretro INFO] [MAME 2003+] Full content path /home/pi/RetroPie/roms/arcade/asteroid.zip
                  [libretro INFO] [MAME 2003+] Git Version fada64e
                  [libretro INFO] [MAME 2003+] Content lookup name: asteroid
                  [libretro INFO] [MAME 2003+] Driver index counter: 3300. Matched game driver: asteroid
                  [libretro INFO] [MAME 2003+] Content identified as using a vector video display.
                  [libretro INFO] [MAME 2003+] Content identified as having a service button.
                  [libretro INFO] [MAME 2003+] Content identified as having a tilt feature.
                  [libretro INFO] [MAME 2003+] Content identified as using 8-way joystick controls.
                  [libretro INFO] [MAME 2003+] Content identified by controls.c as having joysticks on axis with respect to the cabinet.
                  [libretro INFO] [MAME 2003+] Content identified as supporting 1 players with 1 distinct controls.
                  [libretro INFO] [MAME 2003+] Content identified as supporting 3 button controls.
                  [libretro INFO] [MAME 2003+] Content identified by controls.c as having mirrored multiplayer control labels.
                  [libretro INFO] [MAME 2003+] Check for trailing slash in path: /home/pi/RetroPie/roms/arcade/
                  [libretro INFO] [MAME 2003+] Removed a trailing slash in path: /home/pi/RetroPie/roms/arcade
                  [libretro INFO] [MAME 2003+] Check for trailing slash in path: /home/pi/RetroPie/BIOS
                  [libretro INFO] [MAME 2003+] Trailing slash removal was not necessary for path given.
                  [libretro INFO] [MAME 2003+] content path: /home/pi/RetroPie/roms/arcade
                  [libretro INFO] [MAME 2003+] system path: /home/pi/RetroPie/BIOS
                  [libretro INFO] [MAME 2003+] save path: /home/pi/RetroPie/roms/arcade
                  [INFO] [Environ]: SET_VARIABLES.
                  [libretro INFO] [MAME 2003+] Opening ROM file: 035145.02
                  [libretro INFO] [MAME 2003+] Opening ROM file: 035144.02
                  [libretro INFO] [MAME 2003+] Opening ROM file: 035143.02
                  [libretro INFO] [MAME 2003+] Opening ROM file: 035127.02
                  [libretro INFO] [MAME 2003+] Succesfully loaded ROMs.
                  [libretro ERROR] cpunum_get_localtime() called for invalid cpu num!
                  [INFO] [Environ]: SET_ROTATION: 0
                  CONTROLS:
                  GAMEINFO: Asteroids (rev 2)
                  1979 Atari
                  CPU:
                  M6502 1.500000 MHz
                  Sound:
                  Discrete Components
                  Vector Game
                  [libretro INFO] [MAME 2003+] Sample rate set to 48000
                  [INFO] [Cheats]: Load game-specific cheatfile: /home/pi/.config/retroarch/cheats/MAME 2003-Plus/asteroid.cht
                  [INFO] [Video]: Video @ 3072x2304
                  /opt/retropie/supplementary/runcommand/runcommand.sh: line 1285: 2016 Segmentation fault /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-mame2003-plus/mame2003_plus_libretro.so --config /opt/retropie/configs/arcade/retroarch.cfg "/home/pi/RetroPie/roms/arcade/asteroid.zip" --verbose --appendconfig /dev/shm/retroarch.cfg
                    @ken-tipton said in No Games will load:
                    Can you post the above file's contents on pastebin.com ?
                      Ken Tipton @mitu
                      <script src="https://pastebin.com/embed_js/qfFR5D0x"></script>
                        mitu Global Moderator @Ken Tipton
                        @ken-tipton No, that's the log file. I mean to get the contents of the /opt/retropie/configs/arcade/retroarch.cfg file and post it on pastebin.com.
                          Ken Tipton @mitu
                          @mitu sorry here you go
                          <script src="https://pastebin.com/embed_js/NvTRQBXZ"></script>
                            @ken-tipton This looks like the file was saved from the RetroArch's menu or you enabled 'Save on Exit' and one of the settings is not correct (input_joypad_driver is set to null ?).
                            Rename the file and then install one of the arcade emulators (lr-mame2003 or lr-fbneo). This will re-generate the default configuration file that RetroPie sets and it should work.
                              Ken Tipton @mitu
                              @mitu what file is it that I need to rename? the config file?
                                That seemed to work I will try a few more ROMS.....thank you very much
                                  Ken Tipton
                                  now the games load but
                                  Asteroids is lagging and very slow
                                  Donkey Kong no longer has the audio for mario walking. When game loads it says audio files are missing. where would the audio files go?
                                  • Thorr69T
                                    Thorr69 @Ken Tipton
                                    @ken-tipton Donkey Kong requires samples. See the docs for more info on that.
                                    RPi 3b
                                    Official PSU
                                    Official RetroPie image
                                    Pandora's Box 5 controller
                                    K 1 Reply Last reply Reply Quote 1
                                      Ken Tipton @Thorr69
                                      @thorr69 I have the sample files loaded here
                                      /home/pi/RetroPie/BIOS/mame2003/samples
                                      and I am using mame2003 to play Donkey Kong
                                      When I open the zip file in the sample folder I can see 8 files in there.
                                      DKStomp and Run 1-3 are present but these are the sounds I am missing
                                        Donkey Kong fixed now just asteroids
                                        it is lagging big time never did before.
                                          Can you post again the runcommand.log when the game lags ? Use pastebin.com again, instead of the forum post, the log is quite large.
                                            Ken Tipton @mitu
                                            where is that file located
