    [ISSUE] Ultimarc Trackball Connected to Ultimarc Ultimate I/O Not Registering/Producing Results
    mameretroarchtrackballultimarcultimarc trackb
    25 Posts 3 Posters 3.2k Views
      mahoneyt944 @nreinhart
      @nreinhart hmm well golden tee is a trackball game. Try centiped.
      • N
        nreinhart @mahoneyt944
        @mahoneyt944 No dice. The manufacturer makes a USB conversion piece - I think I'm going in buy that and see if attaching it as a usb improves the situation.
        stoney66S 1 Reply Last reply Reply Quote 0
        • stoney66S
          stoney66 @nreinhart
          @nreinhart So is centipede loading but trackball not working but GT works fine? Earlier you said centipede wont load on advmame so just checking. If thats the case, make sure you are using 0.106 rom files as centiped is different than the 0.078 one.
          I have the ultimarc track and all trackball games in advmame work for me but I am using the mini-pac to connect it up.
          N 2 Replies Last reply Reply Quote 0
          • N
            nreinhart @stoney66
            @stoney66 This was a good call out. I had set it back to mame2003. Just did the switch back to advmame and it wouldn't load. Which indicates I need to find the .106 rom. This is admittedly one of my weak points - I'll do some googling and see where I can find a .106 of centipede. Thanks for the nudge in a different direction.
            • N
              nreinhart @stoney66
              @stoney66 well - switched the roms and now they work. Centipede, Missile Command, Golden Tee 2 are all working now under AdvMame. Marble Madness is still unhappy, but I would assume that's still just a rom issue. I think this issue is likely resolved now. Thank you everyone for your help! @mahoneyt944 and @stoney66
