    Longterm Problem with my Arcade Tabletop Config
    arcade configipac 2retropieconfig input
    8 Posts 2 Posters 986 Views
    • Seannyboy08S
      Seannyboy08
      Hi All,
      Parts list on my home built arcade -
      Emulation Station Front end
      Retroarch
      Rasberry PI 3 Model B v1.2
      Old monitor screen approx 19-20
      ipac keyboard encoder
      HDMI to VGA Converter
      Basically ive inputted the buttons on the switches on winipac v2 to everything needed like this-
      p1 up - up p1 down - down p1 left - left p1 right - right
      p1 A - Y p1 B - W p1 RIGHT SHOULDER - U
      p1 LEFT SHOULDER - I p1 - X - R p1 Y - Q
      p1 - Coin / Select - E p1 Start - T
      Middle Button / Hotkey Button - G
      p2 up - C p1 down - Z p1 left - S p1 right - X
      p1 A - F p1 B - H p1 RIGHT SHOULDER - D
      p1 LEFT SHOULDER - L p1 - X - J p1 Y - K
      p1 - Coin / Select - O p1 Start - P
      Setting Enable Hotkeys - G
      Menu - R
      Quit Retroarch - T
      Now i've read through most of the config setups and don't know where I'm going wrong because i try to go through retroarch and go into controls but it doesn't show the buttons needed.
      If i play snes and a few other roms they work great but anything arcade like libretro won't work.
      Really appreciate some help with this because it comes out from time to time then just gets shelved for a few months because i get frustrated with it.
      Do i need another encoder maybe or any idea guys . Thanks
      Sean
        mitu Global Moderator @Seannyboy08
        Which RetroPie version are you using ? How did you install it ?
        Which emulators specifically ? Since your IPAC is emulating a keyboard, you may want to look at the keyboard controllers page for examples and pointers.
        If the IPAC already works with other systems, I don't see why.
        Seannyboy08S 2 Replies Last reply Reply Quote 0
        • Seannyboy08S
          Seannyboy08 @mitu
          Hi Mitu,
          It may sound like a very noob question but where do i find out what version i'm running.
          And the roms are from a pre-built sd card image, i tried doing my own but it lacked the videos and the images.
          Sean
            @seannyboy08 said in Longterm Problem with my Arcade Tabletop Config:
            It's shown at the top when you start the RetroPie-Setup menu.
            We don't support 3rd party images - use the image from retropie.org.uk/download and we can help.
            • Seannyboy08S
              Seannyboy08 @mitu
              Scratch that last its - retropie 4.4.2
                As I said - use the official image and we can provide support.
                Seannyboy08S 1 Reply Last reply Reply Quote 0
                • Seannyboy08S
                  Seannyboy08 @mitu
                  I will do this, i have my own set of roms but if the problems persists is it something else possible ?
                  Sean
                    @seannyboy08 Can't know without finding the cause of the issue.
