    TI99 Scraping problem
    emulationstatonretropie 4.7.1
    10 Posts 3 Posters 1.1k Views
      Drdave79
      On a new build that I'm working with, I get the "Some of your systems do not have a platform set...." error when scraping my TI99 system in emulation station on my R4. I have a platform defined in the es_systems.cfg file (see below) located in /configs/all/emulationstation. I've tried renaming the platform TI99 and texasinstruments and neither changes the result. Am I doing something wrong? I figured since the <platform> line is populated, I DO have a platform set!
      • Lister of SmegL
        Lister of Smeg
        i'm not sure if there is a better way of doing this, but I just use Skraper running from Windows to get round the issue
        btw Ti-99 should be supported with the internal scraper - my config is slightly different from what you have tho
        <platform>ti99</platform>
          Drdave79 @Lister of Smeg
          @lister-of-smeg I'm running it on a R4, not windows and I did try both combinations. Neither seemed to work.
          Lister of SmegL 1 Reply Last reply Reply Quote 0
            Which scraping source are you using ? TheGamesDB might not support the TI99.
            • Lister of SmegL
              Lister of Smeg @Drdave79
              @drdave79
              Skraper runs from Windows but scrapes your Pi over network. It uses ScreenScraper as it's source (it's what I used to scrape Ti-99)
              As Mitu suggests, changing your source from TheGamesDB to SCREENSCRAPER in the retropie scraper could be a quick fix for you
                @lister-of-smeg said in TI99 Scraping problem:
                @drdave79
                Yes, I've tried both sources. Same result.
                • Lister of SmegL
                  @drdave79
                  just tried on a fresh image and got the same results as you
                  what does work using only a Pi is going to RetroPie Setup and installing Lars Muldjord's Skyscraper
                  instructions for usage found at https://retropie.org.uk/docs/Scraper/ (about half way down the page)
                  I still recommend using Skraper from a windows environment over your network - Just enable SSH from raspi-config then follow the wizard on Skraper
                    It looks like ti99 is not a supported platform for the EmulationStation's scraper. It needs to be added in order for the scraping to work - so for now you can use Skyscraper or another external scraper for the TI99.
                      @drdave79
                      That worked perfectly! Thank you very much!
                        Drdave79 @mitu
                        @mitu said in TI99 Scraping problem:
                        Thank you very much. This worked perfectly.
