    Razor Raiju Bluetooth Controller (PS3) Bluetooth Issue
    retropie 4.7.1blueoothps3
    1 Posts 1 Posters 391 Views
    • N
      Norstein
      Hi, so I'm using a Razer Raiju Ultimate Controller, on Retropie 4.7.1, but it only works for a very short period of time during the registering process in the bluetooth setup.
      When I'm in Setup/Bluetooth -> register and connect do new device, I set the controller in pairing mode, and it connects almost instantly, I can already use the controller to select itself from the menu which device I want to register and connect.
      But once I leave the bluetooth menu, I get a message saying that the ps3controller driver was temporarily interrupted in order to allow compatibility with standard bluetooth peripherals, and that I should re-pair the controller.
      When I try to "connect to all registered devices", nothing happens.
      "show all registered and connected devices" shows only the Razer Raiju Ultimate controller as registered, but no active connections.
      I tried rebooting into Emulationstation, but then it won't find the controller, unless I switch it to USB mode and connect it via cable.
      Next I tried going into the setup again, removing the device and registering it again, but it got me the same result as before.
      Any ideas how I can fix this?
