    SDL window problem
    startup error
    18 Posts 3 Posters 3.0k Views
      Agent Blade
      Hardware Pi 3
      Power supply Steel series cable
      Version 4.7.1
      Building On raspbian
      Controller Power A Nintendo switch wired pro controller
      Error message In photograph
      Guide Raspbian guide on docs
      Files In photograph
      Config files ???
      I got the install done but the error (seen below) keeps popping up when I type In “emulationstation” I searched but nothing worked so it might be a newer problem any help is appreciated.
        Your screenshot hasn't been uploaded - you probably didn't wait till the upload was finished. Can you re-upload the image ?
          Try starting EmulationStation from the console and not from the desktop. As explained in the guide, RetroPie and the desktop environment are not compatible.
            Agent Blade @mitu
            @mitu I don’t remember the part about being not compatible but how can I launch it from the console?
              https://retropie.org.uk/docs/Debian/#configure-retropie
              A 2 Replies Last reply Reply Quote 0
                Agent Blade @mitu
                @mitu ?
                  Agent Blade @mitu
                  @mitu what am I supposed to do with this?
                    mitu Global Moderator @Agent Blade
                    @agent-blade Use the autostart settings to start EmulationStation on boot, outside of the desktop environment.
                      Agent Blade @mitu
                      @mitu I did this but it shows the same error
                        Agent Blade
                        @mitu nevemind it fixed when I typed in emulationstation
                          What Raspbian/RPI OS version do you have installed ? Did you allocate enough GPU memory in config.txt, as explained on the install page ? Can you post your config.txt here in the topic ?
                            davmel
                            Hello everyone,
                            I am new to this forum and may have the same problem.
                            When I write emulationstation in the console, the following error message arises.
                            What am I doing wrong?
                            Best regards,
                            David
                            Hardware Pi 3b+
                            Version 4.7.1
                            Error message:
                            Aug 29 20:34:48 lvl0: Error creating SDL window!
                            Could not get EGL display
                            Aug 29 20:34:48 lvl0: Renderer failed to initialize!
                            Aug 29 20:34:48 lvl0: Window failed to initialize!
                            Guide:
                            Config files:
                              mitu Global Moderator @davmel
                              @davmel The video you followed is wrong - running RetroPie from the desktop session is not supported. Please install using the image from retropie.org.uk/download or follow my advice from above.
                                davmel @mitu
                                @mitu thanks for the quick reply!
                                To be honest, I don’t understand your advise…
                                May you elaborate this approach?
                                BR,
                                David
                                  @davmel In the configuration for autostart, choose the 'boot to EmulationStation' option so that your system starts EmulationStation automatically, instead of the desktop environment - https://retropie.org.uk/docs/FAQ/#how-do-i-boot-to-the-desktop-or-kodi.
                                    davmel @mitu
                                    @mitu but then I’m not able to use the raspberry as a desktop computer anymore, right? Is there no way to have access to both?
                                      @davmel You can start the desktop from EmulationStation if you wish - https://retropie.org.uk/docs/FAQ/#where-did-the-desktop-go.
                                        davmel @mitu
                                        @mitu thank you, that works fine!
