    Controller wont work for choosing emulators anymore, joy2key problem/issue not working...
    joy2keyretropiesetup
    12 Posts 3 Posters 1.2k Views
    • nestor1924N
      nestor1924
      I just updated to the lastest version and now my controller wont work on retropie menu or when changing emulators, it works fine for playing games but not for chabging roms, also joy2key work upgrade and comes as an error!
      Im using this:
      its a 3b+ and its version 4.7.19 last commit 10 days ago
      System rpi3 running raspbian GNU/Linux 9.11
      The errors i see when trying to upgrade joy2key from binary, its there but doesnt work
      https://ibb.co/G5ndN7B
      https://ibb.co/CB6QPRz
        mitu Global Moderator @nestor1924
        @nestor1924 said in Controller wont work for choosing emulators anymore, joy2key problem/issue not working...:
        Open the file referenced in the error message and post its contents, the actual error is shown there.
        nestor1924N 1 Reply Last reply Reply Quote 0
        • nestor1924N
          nestor1924 @mitu
          @mitu sorry im new to this things, how do i get to do that?
            Use the File Manager menu from the RetroPie system and navigate to the /home/pi/RetroPie-Setup/logs folder, then view the log file by pressing F3. Post the contents of that log file.
            • nestor1924N
              nestor1924 @mitu
              @mitu this is the latest one:
              https://ibb.co/QQH3JxC
                The error comes from using an old Raspbian version (based on Debian Stretch), which seems to have an old python3 interpreter - not compatible with joy2key_sdl.py.
                Didn't you get a message, after updating, that your system is no longer supported ?
                • nestor1924N
                  nestor1924 @mitu
                  @mitu yeah i did get a message about it, so what the only way to fix this? Upgrading will it fix the issue?
                    @nestor1924 Use a compatible OS and this issue will not be present. Get the latest RetroPie image and install it, then transfer your ROMS/BIOS/configs over from your existing installation.
                    • nestor1924N
                      nestor1924 @mitu
                      @mitu ok will do that, i got alot of customs images, intros. Themes, even music, even the thropies feature from retroachievements... will all of it transfer?
                      mituM S 2 Replies Last reply Reply Quote 0
                        @nestor1924 You'll have to transfer them from the \\retropie\config folder and place them into the same location on the new system. If you've got custom scripts/systems/etc, you'll have to re-do the customizations on the new image also. You should backup your existing image before upgrading to a new one.
                          sleve_mcdichael @nestor1924
                          Two days ago when you asked this on Reddit, I told you it would. Did you forget to check back there for replies, or did you just not believe me?
                          nestor1924N 1 Reply Last reply Reply Quote 1
                          • nestor1924N
                            nestor1924 @sleve_mcdichael
                            @sleve_mcdichael i did believe you i just wanted to know other opinions if anybody else could find another way of fixing it without having to start a new image, since theres no way other way around im giving up on this, thank you guys for the help!
