    Overclocked pi 4 does not seem to be using the power available
    overclock
    11 Posts 3 Posters 1.2k Views
    • E
      evileyecheese
      I'm having some serious trouble trying to get the pi4 and retropie Dreamcast emulators to run full speed like others have reported I've overclocked the arm to 2100 and the GPU to 750 confirmed that the clock speed has increased but it's not translating into better performance in retropie
      Any help greatly appreciated
      sirhenrythe5thS dankcushionsD 2 Replies Last reply Reply Quote 0
      • sirhenrythe5thS
        sirhenrythe5th @evileyecheese
        @evileyecheese more information about your setup would be also greatly appreciated as mentioned here: https://retropie.org.uk/forum/topic/3/read-this-first
        In general: DC (as well as most NAOMI/AtomisWave-) games run great on PI4, even without overclocking.
        RetroRatio: 1.88
        Started Games beaten: 2,47%
        Site Rank: 4382/93743 ranked users (TOP 4.76%)
        Last seen in [The Legend of Zelda: Lost in Time (HACK) [N64], exploring Hyrule at Night]
        • E
          evileyecheese @sirhenrythe5th
          @sirhenrythe5th sorry, I'm a total noob at this, I'm running a pi4b with 2 gig of ram I've edited config.txt via notepad ++ upped the voltage to 6 and confirmed the clock speed has increased.
          • sirhenrythe5thS
            @evileyecheese to help you seriously we still need some more information, that you are using a Pi is clear, the ammount of ram is not important at all.
            More important are things like: which emulator, which versin of retropie, what kind of modifications,....
            Did you open the link i posted you?
            There you would have seen the following inportant questions:
            Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..)
            Power Supply used: (If using a Pi)
            RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest):
            Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used)
            USB Devices connected:
            Controller used:
            Error messages received:
            Verbose log (if relevant):
            How to replicate the problem:
            RetroRatio: 1.88
            • E
              @sirhenrythe5th sorry again I'll provide the info when I've finished work
                dankcushions Global Moderator @evileyecheese
                @evileyecheese anyone telling you that dreamcast will run fullspeed on pi4 in all scenarios after an overclock, is not in full possession of the facts. overclocking may provide a small benefit in certain scenarios, but nothing major, and it won't help if there's a fundamental config issue happening, which we could diagnose with a verbose log etc.
                • E
                  evileyecheese @dankcushions
                  @dankcushions
                  its mainly marvel vs capcom 2 which seems to be a demanding title also ikaruga on naomi
                  i was using redream but got slightly better results in flycast in terms of speed and the snk fighting games on atomiswave are increadibly choppy
                  im running version 4.7.1 official download
                  i have literally no idea what im doing
                  im using official psu
                  config.txt as follows
                  For more options and information see
                  http://rpf.io/configtxt
                  Some settings may impact device functionality. See link above for details
                  uncomment if you get no picture on HDMI for a default "safe" mode
                  #hdmi_safe=1
                  uncomment this if your display has a black border of unused pixels visible
                  and your display can output without overscan
                  disable_overscan=1
                  uncomment the following to adjust overscan. Use positive numbers if console
                  goes off screen, and negative if there is too much border
                  #overscan_left=16
                  #overscan_right=16
                  #overscan_top=16
                  #overscan_bottom=16
                  uncomment to force a console size. By default it will be display's size minus
                  overscan.
                  #framebuffer_width=1280
                  #framebuffer_height=720
                  uncomment if hdmi display is not detected and composite is being output
                  hdmi_force_hotplug=1
                  uncomment to force a specific HDMI mode (this will force VGA)
                  hdmi_group=2
                  hdmi_mode=85
                  uncomment to force a HDMI mode rather than DVI. This can make audio work in
                  DMT (computer monitor) modes
                  hdmi_drive=2
                  uncomment to increase signal to HDMI, if you have interference, blanking, or
                  no display
                  #config_hdmi_boost=4
                  uncomment for composite PAL
                  #sdtv_mode=2
                  uncomment to overclock the arm. 700 MHz is the default.
                  #arm_freq=800
                  Uncomment some or all of these to enable the optional hardware interfaces
                  #dtparam=i2c_arm=on
                  #dtparam=i2s=on
                  #dtparam=spi=on
                  Uncomment this to enable infrared communication.
                  Additional overlays and parameters are documented /boot/overlays/README
                  Enable audio (loads snd_bcm2835)
                  dtparam=audio=on
                  [pi4]
                  Enable DRM VC4 V3D driver on top of the dispmanx display stack
                  dtoverlay=vc4-fkms-v3d
                  max_framebuffers=2
                  [all]
                  #overscan_scale=1
                  #Add these 2 lines for CPU Overclock
                  over_voltage=6
                  arm_freq=2100
                  #add these 2 lines for GPU Overclock
                  gpu_freq=750
                  over_voltage=6
                    verbose log please: https://retropie.org.uk/docs/Runcommand/#launch-with-verbose-logging
                    • E
                      evileyecheese
                      this is all i got
                      Parameters:
                      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-flycast/flycast_libretro.so </dev/null --config /opt/retropie/configs/dreamcast/retroarch.cfg "/home/pi/RetroPie/roms/dreamcast/ikaruga.zip" --verbose --appendconfig /dev/shm/retroarch.cfg
                      [INFO] RetroArch 1.9.7 (Git 8373ac6)
                      [INFO] Capabilities: NEON VFPv3 VFPv4
                      [INFO] Built: Sep 8 2021
                      [INFO] Version: 1.9.7
                      [INFO] Git: 8373ac6
                      [INFO] [Input]: Found input driver: "x".
                      [INFO] [Core]: Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-flycast/flycast_libretro.so"
                      [INFO] [Overrides]: No core-specific overrides found at "/home/pi/.config/retroarch/config/Flycast/Flycast.cfg".
                      [INFO] [Overrides]: No content-dir-specific overrides found at "/home/pi/.config/retroarch/config/Flycast/dreamcast.cfg".
                      [INFO] [Overrides]: Game-specific overrides found at "/home/pi/.config/retroarch/config/Flycast/ikaruga.cfg".
                      [INFO] [Config]: Appending config "/home/pi/.config/retroarch/config/Flycast/ikaruga.cfg".
                        @evileyecheese the log is in incomplete. you should show the whole file, and also the override it refers to:
                        • E
                          evileyecheese
                          cant find this in winscp
                          full verbose log for marvel vs capcom 2
                          Parameters:
                          Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-flycast/flycast_libretro.so </dev/null --config /opt/retropie/configs/dreamcast/retroarch.cfg "/home/pi/RetroPie/roms/dreamcast/Marvel vs. Capcom 2.chd" --verbose --appendconfig /dev/shm/retroarch.cfg
                          [INFO] Git: 8373ac6
                          [INFO] [Overrides]: No game-specific overrides found at "/home/pi/.config/retroarch/config/Flycast/Marvel vs. Capcom 2.cfg".
                          [INFO] [Environ]: GET_CORE_OPTIONS_VERSION.
                          [INFO] [Environ]: GET_LANGUAGE: "0".
                          [INFO] [Environ]: RETRO_ENVIRONMENT_SET_CORE_OPTIONS_INTL.
                          [INFO] [Environ]: SET_CONTROLLER_INFO.
                          [INFO] [Remaps]: Remap directory: "/opt/retropie/configs/dreamcast/".
                          [INFO] [Remaps]: Core-specific remap found at "/opt/retropie/configs/dreamcast/Flycast/Flycast.rmp".
                          [INFO] [Overrides]: Redirecting save file to "/home/pi/RetroPie/roms/dreamcast/Marvel vs. Capcom 2.srm".
                          [INFO] [Overrides]: Redirecting save state to "/home/pi/RetroPie/roms/dreamcast/Marvel vs. Capcom 2.state".
                          [INFO] [Environ]: GET_LOG_INTERFACE.
                          [INFO] [Environ]: GET_PERF_INTERFACE.
                          [INFO] [Environ]: SET_PIXEL_FORMAT: XRGB8888.
                          [INFO] [Environ]: SET_KEYBOARD_CALLBACK.
                          [INFO] [Environ]: GET_DISK_CONTROL_INTERFACE_VERSION.
                          [INFO] [Environ]: SET_DISK_CONTROL_EXT_INTERFACE.
                          [INFO] [CONTENT LOAD]: Content loading skipped. Implementation will load it on its own.
                          [INFO] [Environ]: GET_RUMBLE_INTERFACE.
                          [INFO] [Environ]: SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS".
                          [INFO] [Environ]: GET_SAVE_DIRECTORY.
                          [INFO] [Environ]: SET_SAVE_STATE_IN_BACKGROUND: yes.
                          [libretro INFO] File extension is: .chd
                          [INFO] [Environ]: GET_PREFERRED_HW_RENDER, video driver name: xvideo.
                          [INFO] [Environ]: GET_PREFERRED_HW_RENDER - Context callback set to RETRO_HW_CONTEXT_NONE.
                          [INFO] [Environ]: SET_HW_RENDER, context type: gl.
                          [INFO] Requesting OpenGLES2 context.
                          [INFO] Reached end of SET_HW_RENDER.
                          [libretro INFO] hw/mem/_vmem.cpp:482 N[VMEM]: Info: nvmem is enabled, with addr space of size 512MB
                          [libretro INFO] nullDC.cpp:145 N[BOOT]: [LUT]: Product number: T1212N .
                          [libretro INFO] hw/maple/maple_devs.cpp:603 N[MAPLE]: Loaded VMU from file "/home/pi/RetroPie/roms/dreamcast//Marvel vs. Capcom 2.A1.bin"
                          [libretro INFO] hw/maple/maple_devs.cpp:603 N[MAPLE]: Loaded VMU from file "/home/pi/RetroPie/BIOS/dc/vmu_save_A2.bin"
                          [libretro INFO] hw/maple/maple_devs.cpp:603 N[MAPLE]: Loaded VMU from file "/home/pi/RetroPie/BIOS/dc/vmu_save_B1.bin"
                          [libretro INFO] hw/maple/maple_devs.cpp:603 N[MAPLE]: Loaded VMU from file "/home/pi/RetroPie/BIOS/dc/vmu_save_B2.bin"
                          [libretro INFO] hw/maple/maple_devs.cpp:603 N[MAPLE]: Loaded VMU from file "/home/pi/RetroPie/BIOS/dc/vmu_save_C1.bin"
                          [libretro INFO] hw/maple/maple_devs.cpp:603 N[MAPLE]: Loaded VMU from file "/home/pi/RetroPie/BIOS/dc/vmu_save_C2.bin"
                          [libretro INFO] hw/maple/maple_devs.cpp:603 N[MAPLE]: Loaded VMU from file "/home/pi/RetroPie/BIOS/dc/vmu_save_D1.bin"
                          [libretro INFO] hw/maple/maple_devs.cpp:603 N[MAPLE]: Loaded VMU from file "/home/pi/RetroPie/BIOS/dc/vmu_save_D2.bin"
                          [INFO] [Environ]: SET_ROTATION: 0
                          [INFO] [SRAM]: Skipping SRAM load..
                          [INFO] Version of libretro API: 1
                          [INFO] Compiled against API: 1
                          [INFO] [Audio]: Set audio input rate to: 44100.00 Hz.
                          [INFO] [Video]: Video @ 1280x720
                          [INFO] [Video]: Using HW render, OpenGL driver forced.
                          [INFO] [Video]: "xvideo" saved as cached driver.
                          [INFO] [DRM]: Found 1 connectors.
                          [INFO] [DRM]: Connector 0 connected: yes
                          [INFO] [DRM]: Connector 0 has 6 modes.
                          [INFO] [DRM]: Connector 0 assigned to monitor index: #1.
                          [INFO] [DRM]: Mode 0: (1280x720) 1280 x 720, 59.974029 Hz
                          [INFO] [DRM]: Mode 1: (1024x768) 1024 x 768, 60.003837 Hz
                          [INFO] [DRM]: Mode 2: (800x600) 800 x 600, 60.316539 Hz
                          [INFO] [DRM]: Mode 3: (800x600) 800 x 600, 56.250000 Hz
                          [INFO] [DRM]: Mode 4: (848x480) 848 x 480, 60.000423 Hz
                          [INFO] [DRM]: Mode 5: (640x480) 640 x 480, 59.940475 Hz
                          [INFO] [GLCore]: Found GL context: kms
                          [INFO] [GLCore]: Detecting screen resolution 1280x720.
                          [WARN] [KMS]: Swap intervals > 1 currently not supported. Will use swap interval of 1.
                          [INFO] [EGL] Found EGL client version >= 1.5, trying eglGetPlatformDisplay
                          [INFO] [EGL]: EGL version: 1.4
                          [INFO] [EGL]: Created shared context: 0xea16a8.
                          [INFO] [EGL]: Current context: 0xe7f528.
                          [INFO] [KMS]: New FB: 1280x720 (stride: 5120).
                          [INFO] [GLCore]: Initializing HW render (1024 x 1024).
                          [INFO] [GLCore]: Max texture size: 4096 px, renderbuffer size: 4096 px.
                          [INFO] [GLCore]: Vendor: Broadcom, Renderer: V3D 4.2.
                          [INFO] [GLCore]: Version: OpenGL ES 3.1 Mesa 19.3.2.
                          [INFO] [GLCore]: Using resolution 1280x720
                          [INFO] [udev]: Added Device Keyboard#0 SAGE SAGE AirMouse Keyboard (/dev/input/event0) .
                          [INFO] [udev]: Added Device mouse#0 SAGE SAGE AirMouse (/dev/input/event1) .
                          [INFO] [udev]: Pad #0 (/dev/input/event4) supports 0 force feedback effects.
                          [INFO] [Shaders]: Configuration file shader set to .
                          [INFO] [GLCore]: Loading stock shader.
                          [INFO] [slang]: Building pass #0 (N/A)
                          [INFO] [GLCore]: Not using frame history.
                          [INFO] [GLCore]: Not using framebuffer feedback.
                          [INFO] [Font]: Using font rendering backend: stb-unicode.
                          [INFO] [Video]: Found display server: null
                          [INFO] ALSA: Using floating point format.
                          [INFO] ALSA: Period size: 480 frames
                          [INFO] ALSA: Buffer size: 1536 frames
                          [INFO] [Display]: Found display driver: "glcore".
                          [INFO] [Playlist]: Loading history file: [/opt/retropie/configs/dreamcast/content_history.lpl].
                          [INFO] [Playlist]: Loading history file: [/opt/retropie/configs/dreamcast/content_music_history.lpl].
                          [INFO] [Playlist]: Loading history file: [/opt/retropie/configs/dreamcast/content_video_history.lpl].
                          [INFO] [Playlist]: Loading history file: [/opt/retropie/configs/dreamcast/content_image_history.lpl].
                          [INFO] [Playlist]: Loading favorites file: [/opt/retropie/configs/dreamcast/content_favorites.lpl].
                          [INFO] [Playlist]: Written to playlist file: /opt/retropie/configs/dreamcast/content_history.lpl
                          [INFO] [Environ]: SET_INPUT_DESCRIPTORS:
                          [libretro INFO] hw/pvr/Renderer_if.cpp:104 N[PVR]: Creating Open GL per-triangle/strip renderer
                          [libretro INFO] rend/gles/gles.cpp:413 N[RENDERER]: OpenGL version: OpenGL ES 3.1 Mesa 19.3.2
                          [INFO] [Video]: Restored video driver to "xvideo".
                          [INFO] [Config]: Saved new config to "/opt/retropie/configs/dreamcast/retroarch.cfg".
                          [INFO] [Core]: Content ran for a total of: 00 hours, 05 minutes, 02 seconds.
                          [INFO] [Core]: Unloading game..
                          [INFO] [Core]: Unloading core..
                          [INFO] [Core]: Unloading core symbols..
                          [INFO] [Core Options]: Saved core options file to "/opt/retropie/configs/all/retroarch-core-options.cfg
