    Final Burn Alpha ROMs won't appear after importing.
    fba
    4 Posts 4 Posters 1.7k Views
      kslweini
      I have the FBA 2012 set, along with the Bios Neogeo.zip in the folder, along with the FBA cores. But nothing is showing up in the menu. This is the only system I'm having an issue with. Any help would be appreciated.
      https://applinked.me/
      dankcushionsD lostlessL B 3 Replies Last reply Reply Quote 0
      • mituM mitu moved this topic from General Discussion and Gaming on
        dankcushions Global Moderator @kslweini
        @kslweini
        please fill out https://retropie.org.uk/forum/topic/3/read-this-first
        in particular, give an example of the full file path (including file name and extension) of a game you think should be showing up.
        • lostlessL
          lostless @kslweini
          @kslweini
          First, Did your rename the rom files? You can’t rename arcade game file names.
          Second, did you restart emulation station to make the roms show up?
            barbudreadmon @kslweini
            @kslweini On a sidenote, i'm not sure there are still much use cases for fbalpha2012. At some point that old fork was used on pi3 for cps3 emulation because newer FBAlpha/FBNeo was a bit too much for those 6 games, but as far as i know it was the only reasonable use case and i solved that performance regression some time ago.
