    SSH WIFI ISSUE
    wificonnect
    44 Posts 5 Posters 5.0k Views
      I cannot update my Retropie Setup Script. I always get the message that the current Raspian stretch is no longer supported.
      Yes, this warning has been in place for more than 1 year, though it doesn't strictly forbids you to update - it just tells you that your OS is no longer supported. What version of RetroPie do you have installed currently ?
      Only problem is even if i did that, i would not know how to reinstall or even find the latest or correct Retropie software
      But how did you install in the first place ? Didn't you go through this - installation - step when you first installed your system ?
      The docs explain how to get the latest RetroPie release and install it.
      Everyone just assumes that "its so easy" yet there are no instructions on how to do this
      Upgrading is not enough documented and we should remedy that, but the installation is clearly outlined in the documentation.
      Any specific links/tutorials would be great, so i dont waste more of your time.
      For an upgrade, you can back-up your ROMs/BIOS/configs and flash a new image, then restore the backed-up content on the new image. See the update doc page.
      90sgamer9 1 Reply Last reply Reply Quote 0
      • 90sgamer9
        90sgamer @mitu
        @mitu It's very frustrating to me because to update you must connect to wifi, and to connect to wifi you must update. I can do neither. so I'm stuck.
        • 90sgamer9
          90sgamer @90sgamer
          @90sgamer I know how to update. I installed it the first time back in 2018. I'm just afraid TO update, as I will lose all my data, files, roms, etc.
            sleve_mcdichael @90sgamer
            @90sgamer back up your image. Flash the new OS. Use 7zip to extract the BIOS, ROMS, and CONFIG folders from your backed-up image. Copy them to the new OS.
            • 90sgamer9
              90sgamer @sleve_mcdichael
              @sleve_mcdichael Yes, I understand, I know what I need to do which is make a back up. I understand how to back up an sd card. What I don't understand is how do I then implement the backup on the new OS without completely wiping out everything. If I don't understand how the entire process works, I'm not going to even start or risk destroying my card.
                @90sgamer
                Use 7zip to extract the BIOS, ROMS, and CONFIGS folders from your backed-up image, and copy them over to the new OS.
                (Edit: sorry, configS with an S.)
                You can always write the backup back to the card and pick up right where you left off...
                90sgamer9 1 Reply Last reply Reply Quote 1
                • 90sgamer9
                  @sleve_mcdichael To my knowledge, the only way to access the BIOS, ROMS, and CONFIG folders is to access them via SSH using wifi (which was the initial issue and reason for this thread). Are you saying that this can be done (access and backup the BIOS, ROMS, and CONFIG folders ) by inserting the sd card directly into the computer? Because I've tried that and all I see are a bunch of folders I don't get the neat and clean BIOS ROMS CONFIGS SPLASHSCREENS, that i see everywhere on other tutorials.
                    @90sgamer said in SSH WIFI ISSUE:
                    Okay so you've backed up the SD card and the .img file of the SD card is saved somewhere on your PC. Download and install 7zip to your PC. Use 7zip to open and view the contents of the .img file.
                    Extract the /home/pi/RetroPie/roms folder and save it somewhere (you can just drag it out of the 7zip window and alt-tab into whatever file folder on the PC you want to drop it into.)
                    Extract /home/pi/RetroPie/BIOS.
                    Extract /opt/retropie/configs.
                    Wipe your card (this is safe, since it's backed up.) Write the new OS to the card in the same manner you did the first time. Set up your locale settings and keyboard layout.
                    Set up your WiFi. As soon as it's on your WiFi, you can get on the network share and drop the extracted folders right there where it says "roms," "configs," and "bios."
                    90sgamer9 2 Replies Last reply Reply Quote 1
                    • 90sgamer9
                      90sgamer @90sgamer
                      @90sgamer what i see is this...
                      • 90sgamer9
                        @sleve_mcdichael Oh thats a great idea, didnt think of that. I'll try it!
                        • 90sgamer9
                          @sleve_mcdichael ok now I have a fresh clean slate of the latest version of buster on my retropie with everything backed up. I setup the country, and enabled SSH. Tried to connect to SSH to transfer files and ... nothing :( Just says device doesnt exist or timed out. I should be very easily able to connect a retropie out of the box?? Not sure what the dealio is.
                          S GreyAreaUKG 2 Replies Last reply Reply Quote 0
                            @90sgamer you've set up WiFi on the Pi?
                            • GreyAreaUKG
                              GreyAreaUK @90sgamer
                              @90sgamer as I understand it, your Pi is supposedly on your WiFi network but you can't connect to it?
                              Let's go back to basics:
                              How is your Pi obtaining an IP address (I'm assuming normal DHCP)
                              Can you plug a keyboard into the Pi and get to a shell. From there, can you ping FROM the Pi to any other device (your router for example)?
                              Can you execute 'sudo ifconfig -a' and post the results for the 'wlan0' section? For example,. here is mine:
                              wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
                              inet 10.1.1.8 netmask 255.255.255.0 broadcast 10.1.1.255
                              inet6 fe80::5256:e6e5:714e:108f prefixlen 64 scopeid 0x20<link>
                              ether dc:a6:32:8b:d4:fe txqueuelen 1000 (Ethernet)
                              RX packets 900 bytes 225393 (220.1 KiB)
                              RX errors 0 dropped 0 overruns 0 frame 0
                              TX packets 127 bytes 21111 (20.6 KiB)
                              TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
                              None of the above will solve anything but it may point to a potential issue. Many thanks.
                              • 90sgamer9
                                90sgamer @GreyAreaUK
                                @greyareauk yes I have a keyboard, not sure what dhcp is or how to check for it, but probably yes.
                                This is my result...
                                  theotherdan @90sgamer
                                  @90sgamer
                                  I didn't see the question asked, but did you enable SSH under interface options from the CLI? If you have a keyboard connected, you can press F4 to the CLI, then run 'sudo raspi-config'. In the configuration utility, access 'interface options' and enable SSH.
                                  You seem to have the Pi on the network and getting an address, could just need to have SSH enabled.
                                  • 90sgamer9
                                    90sgamer @theotherdan
                                    @theotherdan Yes, did that first, SSH is enabled.
                                      @90sgamer
                                      What SSH client are you using?
                                      Also, need more framing...
                                      1. What is the client you are using?
                                      2. What is the protocol you are using?
                                      3. What are you trying to do?
                                      WinSCP is an FTP client, you will need to ensure you can reach port 21. WinSCP likes to use SFTP by default, so make sure you set it to FTP(21).
                                      SSH on the other hand is port 22 and a CLI option to the PI. There is no real default beside port 22, even for apps like PuTTY.
                                      • 90sgamer9
                                        @theotherdan
                                        1.Using WinSCP client.
                                        2. I was using SFTP with port 22 to connect with SSH. (I tried FTP too, just because you mentioned it, didnt work either.)
                                        3. Trying to transfer my backed up roms and config files.
                                          Have you tried the Samba-shares? Just type \\retropie in your PC's search bar.
                                          https://retropie.org.uk/docs/Transferring-Roms/#samba-shares
                                            @mitu Correct, it's always worked and now it isn't. Not trying to be a difficult case. Perhaps the wifi chip in the retropie is fried? I've looked at this from several different angles and I don't think its router related. If I could get my pi to transfer files i would be so happy. There are not many tutorials on transfering roms without wifi. I appreciate your help. Ive been stuck on this for a few months, any other ideas would be greatly appreciated, maybe something outside the box or easily overlooked?
                                            • I would say this is the biggest sticking point
                                            • If you have a wifi adapter showing up in the OS, I don't think your chip is fried
                                            • High level, possible your router and or a switch is not passing traffic from the pi (TCPdump would show that or not)
                                            • It could be due a stale table, per say, as you are using DHCP
                                            • You could look at rebooting your router and any switches you are using if you have not
                                            • As far as using something besides Wifi, just take the Pi and plug it straight into the router
                                            Let me know if you want to look at a packet trace and I can help you with the syntax
