    Issues with update to 4.7.20
    reropie-setup
    20 Posts 9 Posters 2.4k Views
    • windgW
      windg
      Happy New Year!!
      Pi Model or other hardware: Pi4 and Pi3B+
      Power Supply used: Official
      RetroPie Version Used: 4.7.1 install with Pi-Imager
      I try to update the system from 4.7.19 to 4.7.20 but some things wasn't normal i believe. During the update process emulationstation starts to builds from source, scummvm emulator also. Another problem that i face was with lr-flycast, all games return to rtropie menu when im trying to play them.
      To be sure, i download again the 4.7.1 and choose to update and it's building many things from source. When it will finish i will try to post some logs. Does someone else have the same behavior ? Thanks
        dankcushions Global Moderator @windg
        @windg
        verbose log please
        windgW 1 Reply Last reply Reply Quote 0
        • windgW
          windg @dankcushions
          @dankcushions said in Issues with update to 4.7.20:
          @windg
          verbose log please
          https://pastebin.com/U24WC7wW
          Genos98G C 2 Replies Last reply Reply Quote 0
          • Genos98G
            Genos98 @windg
            @windg can confirm the latest version of lr-flycast broke some games, mostly the naomi ones. Marvel vs capcom 2, capcom vs snk, heavy metal geo now crashes when starting.
              BuZz administrators
              I'm looking into the binaries issue.
                BuZz administrators
                The rpi4 binaries folder on the server had the wrong permissions. I'm not sure how this happened. Possibly an issue on the build system which was duplicated to the server with rsync.
                I have corrected it. You will need to switch any packages that have been installed as source to binary from within manage packages.
                Apologies for the inconvenience.
                windgW 1 Reply Last reply Reply Quote 3
                  Cesarpuig @windg
                  @windg Same for me https://github.com/flyinghead/flycast/issues/476
                  • DigrizD
                    Digriz
                    Updated to 4.7.20 and on testing I now get audio dropouts with the latest lr-flycast (updated from source, and also tried deleting then re-installed from binary). I also get major problems with Ikaruga where the audio really cuts out and the video actually seems to desync and the controllers become unresponsive during cut scenes and remain that way with the ship being immune to enemy bullets.
                    Raspberry Pi 4 o/c to 2MHz
                    Pizen Case & Ice Tower
                    Samsung T5 External SSD (500GB)
                    Official Pi4 Power Supply
                    RetroPie 4.7.1 image built with Raspberry Pi Imager on 512Gb SanDisk Extreme Pro microSDXC card
                    2x DragonRise Controllers
                    2x 8BitDo SN30Pro+
                    • windgW
                      windg @BuZz
                      @buzz said in Issues with update to 4.7.20:
                      I think the issue affect and the EmulationStation for Pi3B+, because during the update is building it from source.
                      DjDiabolikD BuZzB 2 Replies Last reply Reply Quote 0
                      • DjDiabolikD
                        DjDiabolik @windg
                        @BuZz
                        I can made a question.... it's the update procedure has been fixed right now ?
                        I see the discussion it's migrated from update issue to a core usage trouble.....
                        • windgW
                          windg @DjDiabolik
                          @djdiabolik said in Issues with update to 4.7.20:
                          @BuZz
                          I just update a Pi4 from 4.7.1 to .20 without problems, the issue was fixed. The problem with lr-flycast is something different, i create confusion with my first post sorry for that.
                          sirhenrythe5thS DjDiabolikD 2 Replies Last reply Reply Quote 0
                          • sirhenrythe5thS
                            sirhenrythe5th @windg
                            Has anyone tested WinCE-Games yet?
                            I just run "SEGA Rally 2" yesterday.
                            It boots indeed, but i had a total freeze in the main menu and had to power off the pi to start again.
                            I did not test other WinCE-powered games after that to avoid more hard crashs.
                            Concerning NAOMI: at least "Crazy Taxi" seems to have issues too, does fall back to ES as well.
                            RetroRatio: 1.91
                            Started Games beaten: 2,40%
                            • windgW
                              windg @sirhenrythe5th
                              @windg II try Sega Rally 2 and its working but doesn't have perfect performance. By the way the games that didn't work yesterday they are running fine now , i did a update before maybe a new version of emulator released.
                              Just to add some extra information, Dreamcast games that i try (Resident Evil Veronica, Sega Rally II) they are working fine with the new lr-flycast on RPi4 ,but the are crashing back to RetroPie on the RPi3 B+. I didn't test NAOMI games yet.
                              sirhenrythe5thS 1 Reply Last reply Reply Quote 1
                              • sirhenrythe5thS
                                @windg thank you for your answer, i will update in the evening too and have another look :D
                                RetroRatio: 1.91
                                  BuZz administrators @windg
                                  @windg Sorry - yes the rpi2/3 supplementary folder also had the wrong permissions. They all should have the correct permissions now. Sorry for missing this.
                                  The issue came from the build server, so I will make sure I double check the permissions before syncing.
                                  • DjDiabolikD
                                    DjDiabolik @windg
                                    @windg said in Issues with update to 4.7.20:
                                    @BuZz
                                    No problems man..... i have read the trouble about the update procedure using, in some case, the source and not the binary package from some components and yeah i'm also i can confirm the update procedure it's be fixed.
                                    I have successfully update also my pi4 setup from 4.7.19 to 4.7.20 :)
                                    Little OT.
                                    Read your signature... also my English it's very Bad... i'm a reeallly fan of google translator after retropie :)
                                    • sirhenrythe5thS
                                      sirhenrythe5th @DjDiabolik
                                      strange....did two updates yesterday, first: binary, second: from source - NAOMI still does not run anymore.
                                      I will have a look at the verbose-log today and continue to find out what is wrong.
                                      Tinkering with Retropie never does get boring: one problem solved - two others created :D :D
                                      RetroRatio: 1.91
                                      mituM DjDiabolikD 2 Replies Last reply Reply Quote 0
                                        mitu Global Moderator @sirhenrythe5th
                                        @sirhenrythe5th said in Issues with update to 4.7.20:
                                        Yes, it's a bug in the RetroPie build of the new Flycast core (see the linked issue above) and at the moment it's crashing with Naomi ROMs. I'm testing some things for a fix.
                                        It's only the most obvious 2 that you noticed :)
                                        mituM 1 Reply Last reply Reply Quote 2
                                        • DjDiabolikD
                                          DjDiabolik @sirhenrythe5th
                                          mmmm... strange because i have update and and my pi4 and the "binary" it's be used in all.
                                          Were you able to determine which cores are being updated via source instead using binary ?
                                          It's only Flycast ? if yes... i understood why i didn't have the same problem :) Simply because on my pi4 i don't use Flycast :)
                                            mitu Global Moderator @mitu
                                            @mitu said in Issues with update to 4.7.20:
                                            Unfortunately I've been unable to find a solution so far. In order to restore the functionality of the core, we've rolled back the changes - the core is again build from the libretro project's version of Flycast.
