    lr-genesis-plus-gx master system sound garbled after restoring save states - all games affected
    save statesgenesis plus gxsound problemmaster system
    30 Posts 4 Posters 8.7k Views
    • U
      uncledisgusting
      If I play master system games using lr-genesis-plus-gx sound and music are perfect except for when restoring save states when it becomes completely garbled and unlistenable. This is the same for every game.
      Can anyone advise how to rectify this please?
      • U
        uncledisgusting
        The sound is perfect but every single save state once loaded has corrupted sound - can anyone advise please?
          Please don't bump your posts. You've added no info about which version of RetroPie/system you're using - please add some context, as requested in https://retropie.org.uk/forum/topic/3/read-this-first.
          • U
            uncledisgusting @mitu
            @mitu Apologies. I am running 4.7.1 on a Rasperry Pi 4
              Please fill out the rest of the info.
              You've said all games are affected, but I have tested genesis-plus-gx and cannot reproduce your issue. I'm using the latest version and I have updated from source. I have tried both MD/Genesis and SMS games, I don't see any issue after loading a save state.
              • U
                @mitu I'm also using the latest version and have updated from source.
                I must add that I am running the games using the 'Nuked' sound option for Master System as opposed to MAME - Nuked is much better sounding in my opinion.
                The sound is perfect for all games yet when I restore a saved state for all games the sound is then very quiet and garbled.
                Thank you for your help with this.
                  I don't think it's the FM implementation choice makes a difference - I've changed that while testing and didn't make a difference.
                  You can reset the options to default just to see if it affects the save states (but create a new save state afterwards). Open the options file and remove any lines starting with genesis_plus_gx.
                  You can also get a verbose log file and post it on pastebin.com to see if anything shows up in the log that might help diagnose this.
                  • U
                    @mitu Removing the lines in the options file didn't change the results
                    I must add that in order to reproduce the sound issue with save states you need to save the state then exit the game and reload the save state. Saving and reloading the save state in the current game doesn't cause any sound issues however one needs to be able to restore a save state after playing a different game, playing another day etc.
                      In my tests I've reloaded the saves after changing the options and restarting the game/going back to EmulationStation. I can't see any issues with the saves.
                      Can you upload one of your problematic saves somewhere to see if it loads differently here ? Add a verbose log, as requested previously.
                      • U
                        @mitu I deleted the lines starting with genesis_plus_gx from the options file but the strange thing is all the settings I had before remain. Is there a duplicate somewhere else that needs editing too please?
                          mitu Global Moderator @uncledisgusting
                          @uncledisgusting said in lr-genesis-plus-gx master system sound garbled after restoring save states - all games affected:
                          If you saved options for the folder/game, these are saved in a separate file and take precedence over the global options. That's why I asked for a verbose log. Note that your issue might not be related to the core's options, but it's something to try just to see if a non-default configuration is responsible.
                          • U
                            uncledisgusting
                            @mitu my controller won't allow me to select the option run game with verbose log - it works fine for the game and for the front end just not when i get to that blue screen. please can you advise? I cant just plug a new controller in as the pi is in a custom case that it would be very hard to open up
                              Add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first to the topic.
                              • U
                                @mitu said in lr-genesis-plus-gx master system sound garbled after restoring save states - all games affected:
                                I'm afraid I cant supply the verbose log because my controller will not respond when it goes to the blue screen with the select verbose log option - the controller works fine in retroarch and with all games. Is there a way I can reproduce the verbose log via SSH? Thank you.
                                  @uncledisgusting Yes, I understood that and it's why I asked for the system info - even without a log.
                                  • U
                                    Pi Model or other hardware: 4
                                    Power Supply used: PWR+
                                    RetroPie Version Used : 4.7.1
                                    USB Devices connected:
                                    Controller used: 2 original master system controllers connected via 2 atari to usb adapters sold by retrousb.com
                                    File: all master system snapshots using NUKED sound
                                    Emulator: lr-genesis-plus-gx
                                    Attachment of config files: how do I attach this please?
                                    How to replicate the problem: Load a master system game using NUKED sound, save a snapshot, restart retropie and when the snapshot is loaded the sound will be totally garbled.
                                    Thank you
                                      Still can't reproduce this - with or without using NUKED option for the Master System's FM core.
                                      You can only attach image files (drag and drop to the textarea or use the image link on top of the post area), if you want to add your config files, post it on pastebin.com and provide the url of the post.
                                      • U
                                        This is my config file - https://pastebin.com/A3pmpZdJ
                                          dankcushions Global Moderator @uncledisgusting
                                          @uncledisgusting this is a non default config. it can be reset if you tell us it’s location? did you change it? delete it
                                          eg the following settings are overriding retropie’s defaults and are bad news
                                          audio_driver = "alsa"
                                          config_save_on_exit = "true"
                                          (probably more - the file is massive)
                                          • U
                                            uncledisgusting @dankcushions
                                            @dankcushions said in lr-genesis-plus-gx master system sound garbled after restoring save states - all games affected:
                                            Thank you for the reply.
                                            At no point did I change the audio driver - what should it be to set to please?
                                            I did put it to config_save_on_exit but why would that affect save states please?
                                            the location of the file is
                                            /opt/retropie/configs/all/retroarch/config/
                                            Thank you for trying to help
