    PPSSPP installation error "Could not successfully build lr-ppsspp .... ppsspp_libretro.so not found)
    retropiehelperrorupdateretropie-setup
    1 Posts 1 Posters 797 Views
      goob
      Re: PPSSPP installation error "Could not successfully build lr-ppsspp .... ppsspp_libretro.so not found)
      I found this thread with no solution.
      I had a similar error:
      "Could not successfully build lr-ppsspp - PlayStation Portable emu - PPSSPP port for libretro (/home/pi/Retropie-Setup/tmp/build/lr-ppsspp/libretro/ppsspp_libretro.so not found)"
      I'm running the pre-made image for Raspberry Pi 4 (4.7.1)
      This was caused by an update that was interrupted and the fix was to delete the tmp directory:
      sudo rm -r RetroPie-Setup/tmp/build/lr-ppsspp/
      Ran update again and it completed successfully.
