    Sound Settings / Audio Card Not Selecting ALSA default or sysdefault Hardware Device
    sound settingsalsahifiberry dacaudioaudio issue
    4 Posts 2 Posters 896 Views
    • H
      hooknc
      Good day,
      Here is my system information:
      Pi 4 (8 gig ram)
      CanaKit 3.5A USB-C Power Supply with Noise Filter
      Retropie Version 4.8.2 - Last Commit: 3 weeks ago (f271ce9d)
      Image downloaded from retropie website
      HiFiBerry DAC2 HD installed
      I have been just having a terrible time getting my HiFiBerry DAC to work properly.
      I have read numerous examples of how to properly setup ALSA.
      For now, I have settled on the following setup in my /etc/asound.conf file:
      # Works for hifiberry
      pcm.!default {
        type plug
        slave.pcm "dmix:sndrpihifiberry,0"
      # Works for hdmi, plug works with hw but not dmix
      pcm.!sysdefault {
        type plug
        slave.pcm "hw:b1,0"
      My goal is to be able to select using my hifi berry or hdmi via the sound settings in retropie.
      However, I am unable to get switching back and forth between the two devices/audio cards to work...
      Here is what I am expecting to work.
      When I go to Sound Settings -> Audio Card when I select default, the sound should come through the hifi berry (see the asound.conf above). This actually works and is expected behavior.
      However, I don't always want the sound to go through my receiver and speakers.
      So, I have hdmi setup as sysdefault in ALSA and when I go to Sound Settings -> Audio Card and select sysdefault, I would expect the sound to start coming though the hdmi (see the asound.conf above).
      However, the sound still comes though the receiver/speakers (the default device) and not the hdmi (sysdefault).
      What am I doing wrong and how can I achieve my goal of being able to select which device plays sound?
      Does Sound Settings -> Audio Device have to be set to a different specific value for this plan/idea to work?
      Any friendly advice would be greatly appreciated.
      BTW, I am able to play sounds through both the hdmi and hifiberry using omxplayer.
      Here are the two different commands:
      # Plays through the hifi berry -> receiver -> speakers
      $ omxplayer -o alsa:default -g --pos 00:00:15 "Banco De Gaia - Last Train To Lhasa (cd 1).mp3"
      # Plays though the hdmi -> tv
      $ omxplayer -o alsa:sysdefault -g --pos 00:00:15 "Banco De Gaia - Last Train To Lhasa (cd 1).mp3"
        Seems like a bug limitation of EmulationStation's audio manager, it's not using the audio card/mixer set through the settings.
        • H
          hooknc @mitu
          @mitu thank you for the reply.
          Should I open a bug report with the EmulationStation fork?
          https://github.com/RetroPie/EmulationStation/issues
            mitu Global Moderator @hooknc
            @hooknc Sure, let it be logged there.
