Renaming Jpg or Rom files, etc. Help. How?
rename filerenamerename command
11 Posts 4 Posters 1.7k Views 4 Watching
  • D Offline
    duglor
    How do you simply rename a file in either the file manager of after hitting f4 and doing all that funky sudo linux commands :) I can move and delete files well, but cant' rename them unless i do it from the pc desktop and ftp into my pie.
    K 1 Reply Last reply 12 Oct 2022, 10:28 Reply Quote 0
    • K Offline
      kiro @duglor
      @duglor not sure what you mean exactly, if you need to rename from within the retropie command line, in Linux you do as if you where moving the file:
      mv oldname.txt newname.txt
      D 2 Replies Last reply 12 Oct 2022, 10:30 Reply Quote 0
      • D Offline
        duglor @kiro
        @kiro and if the old name was John Smith.jpg and or the new name also has a space in it, I have to put "John Smith.jpg" -quotes around the file names?
        K 1 Reply Last reply 12 Oct 2022, 10:39 Reply Quote 0
        • D Offline
          duglor @kiro
          @kiro Yes Linux or file manager. Thanks for the Linux!
          • K Offline
            kiro @duglor
            @duglor yes quotes around the names
            mv 'john smith.ext' 'john ex-smith.ext'
            D 1 Reply Last reply 12 Oct 2022, 10:46 Reply Quote 0
            • D Offline
              duglor @kiro
              @kiro " quotes " right? not ' these ' ? :D
              K 1 Reply Last reply 12 Oct 2022, 10:48 Reply Quote 0
              • K Offline
                kiro @duglor
                @duglor both options are ok, just a matter of taste 🙂
                D 1 Reply Last reply 12 Oct 2022, 10:49 Reply Quote 0
                • D Offline
                  duglor @kiro
                  @kiro lol. ok. thanks much. Anyone know about renaming something if I use FILE MANAGER?
                  A K 2 Replies Last reply 12 Oct 2022, 10:52 Reply Quote 0
                  • A Offline
                    Ashpool @duglor
                    @duglor And just for completeness, if it is just one or a few spaces, you can also enter (each of) those with a leading backslash ;)
                    mv john\ smith.ext john\ ex-smith.ext
                    • K Offline
                      kiro @duglor
                      @duglor what do you mean exactly by file manager? (Sorry for question)
                      S 1 Reply Last reply 12 Oct 2022, 13:01 Reply Quote 0
                      • S Offline
                        sirhenrythe5th @kiro
                        @kiro i guess he is talking about the "midnight commander", which is included in the retropie-image.
                        You can rename files there by marking a file and hitting "F6" for "move file / rename file".
                        If you want to rename the file you have to enter the whole path+new filename (which doesnt speed up the renaming very well ;) )
                        RetroRatio: 1.91
                        Started Games beaten: 2,40%
                        11 out of 11
                          This community forum collects and processes your personal information.
                          consent.not_received
