    Speed game up and down
    frameskipsettings
    2 Posts 2 Posters 1.2k Views
    • Z
      ZemaDuvant
      I am trying to remember the setting to speed a game up an example would be if you were leveling in an RPG so you speed the game up to speed up the grinding.
      Can someone advise where I would be able to access this setting to setup a hotkey?
      On a side note I always thought it was called frame skip but when I searched that in the forums I was unable to find an answer.
      • retropieuser555R
        retropieuser555 @ZemaDuvant
        @ZemaDuvant fast forward is what you're looking for. It's in settings > input > hotkeys. Natively it's set to space on a keyboard. I usually get rid of reset as I don't use reset much and find select + B is better for fast forwarding RPGs or cutscenes
        Pi 5 4GB
