    Please Help: IPAC2 and Hotkey
    ipac2hotkeysretropie
    9 Posts 2 Posters 715 Views
      djsim101
      Hi Retro fellow gamers, please (please) help me. I have searched for the answer .
      I have been following this excellent guide:
      https://retropie.org.uk/forum/topic/8987/guide-setting-up-a-retropie-controls-using-ipac2-controller-extensive-tutorial-preconfigured-files/2
      I am stuck configuring a hotkey manually editing retroarch.cfg.
      The guide keeps referencing hotkey + other key. I have tried every combo under the sun but I cannot get it working. Could some please how I should setup this line: ( I would like to setup key and another key to be used to exit the emulator)
      input_exit_emulator =
      Thank you.
        You should post your existing configuration (surround the config with code tags - three back-ticks ```) and specify how you want to configure the exit combo (which keys ?).
          djsim101 @mitu
          @mitu Thanks for reaching out to me, appreciate the help.
          The part of the config file I configured was:
          input_enable_hotkey = "5"
          input_exit_emulator = "v"
          I have also tried:
          ''' input_enable_hotkey = "v" + "5" input_enable_hotkey = "v" + 5 ''' and a few other combinations.
          Presently, when I select v, it is exiting the emulator, but I need the hotkey + 5 to exit.
          Hopefully I have tagged the code correctly , if not apologies :-)
            Please post the entire configuration section where you mapped the IPAC2, not just the 2 lines.
            Check if you haven't got an extra input_enable_hotkey in the same file or in another configuration file - the configuration lines you posted look fine. Are you sure your hotkey enable button on the IPAC2 is emitting 5 and not other character ?
            D 2 Replies Last reply Reply Quote 0
              djsim101 @mitu
              @mitu I will post the entire file when I get home. Nope, there is no other duplication in that file that particular line. I have also double and triple checked the IPAC2 mappings, that key is correct :-)
                djsim101
                cache_directory = "/tmp/retroarch"
                core_options_path = "/opt/retropie/configs/all/retroarch-core-options.cfg"
                system_directory = "~/RetroPie/BIOS"
                config_save_on_exit = "false"
                video_threaded = "true"
                video_smooth = "false"
                video_aspect_ratio_auto = "true"
                video_font_size = "12.000000"
                input_joypad_driver = "udev"
                input_autodetect_enable = "true"
                input_player1_a = "ctrl"
                input_player1_b = "alt"
                input_player1_y = "shift"
                input_player1_x = "z"
                input_player1_start = "1"
                input_player1_select = "5"
                input_player1_l = "space"
                input_player1_r = "x"
                input_player1_left = "left"
                input_player1_right = "right"
                input_player1_up = "up"
                input_player1_down = "down"
                menu_swap_ok_cancel_buttons = "true"
                input_state_slot_increase = "right"
                input_state_slot_decrease = "left"
                input_shader_next = "m"
                input_shader_prev = "n"
                input_rewind = "r"
                input_reset = "alt"
                input_menu_toggle = "space"
                all_users_control_menu = "true"
                menu_driver = "rgui"
                menu_show_online_updater = "true"
                menu_show_core_updater = "false"
                menu_unified_controls = "true"
                rewind_enable = "false"
                rewind_buffer_size = "10"
                rewind_granularity = "2"
                video_gpu_screenshot = "true"
                auto_remaps_enable = "true"
                xmb_show_add = "false"
                xmb_show_history = "false"
                xmb_show_images = "false"
                xmb_show_music = "false"
                xmb_shadows_enable = "false"
                core_updater_buildbot_assets_url = "http://buildbot.libretro.com/assets/"
                libretro_directory = "~/.config/retroarch/cores"
                libretro_info_path = "~/.config/retroarch/cores"
                content_database_path = "~/.config/retroarch/database/rdb"
                cheat_database_path = "~/.config/retroarch/cheats"
                content_history_path = "/opt/retropie/configs/all/content_history.lpl"
                content_favorites_path = "/opt/retropie/configs/all/content_favorites.lpl"
                content_music_history_path = "/opt/retropie/configs/all/content_music_history.lpl"
                content_video_history_path = "/opt/retropie/configs/all/content_video_history.lpl"
                content_image_history_path = "/opt/retropie/configs/all/content_image_history.lpl"
                cursor_directory = "~/.config/retroarch/database/cursors"
                screenshot_directory = "~/.config/retroarch/screenshots"
                input_remapping_directory = "~/.config/retroarch/config/remaps"
                video_shader_dir = "~/.config/retroarch/shaders"
                video_filter_dir = "default"
                core_assets_directory = "~/.config/retroarch/downloads"
                assets_directory = "~/.config/retroarch/assets"
                dynamic_wallpapers_directory = "default"
                thumbnails_directory = "~/.config/retroarch/thumbnails"
                playlist_directory = "~/.config/retroarch/playlists"
                joypad_autoconfig_dir = "~/.config/retroarch/autoconfig"
                audio_filter_dir = "default"
                savefile_directory = "default"
                savestate_directory = "default"
                rgui_browser_directory = "default"
                rgui_config_directory = "~/.config/retroarch/config"
                overlay_directory = "~/.config/retroarch/overlay"
                video_driver = "gl"
                record_driver = "null"
                camera_driver = "null"
                wifi_driver = "null"
                location_driver = "null"
                audio_driver = "alsathread"
                audio_resampler = "sinc"
                input_driver = "udev"
                video_aspect_ratio = "-1.000000"
                video_scale = "3.000000"
                video_refresh_rate = "59.940060"
                audio_rate_control_delta = "0.005000"
                audio_max_timing_skew = "0.050000"
                audio_volume = "0.000000"
                audio_mixer_volume = "0.000000"
                input_overlay_opacity = "0.700000"
                input_overlay_scale = "1.000000"
                menu_wallpaper_opacity = "0.300000"
                menu_framebuffer_opacity = "0.900000"
                menu_footer_opacity = "1.000000"
                menu_header_opacity = "1.000000"
                video_message_pos_x = "0.050000"
                video_message_pos_y = "0.050000"
                fastforward_ratio = "0.000000"
                slowmotion_ratio = "3.000000"
                input_axis_threshold = "0.500000"
                state_slot = "0"
                netplay_check_frames = "30"
                input_bind_timeout = "5"
                input_turbo_period = "6"
                input_duty_cycle = "3"
                input_max_users = "5"
                input_menu_toggle_gamepad_combo = "0"
                audio_latency = "64"
                audio_block_frames = "0"
                autosave_interval = "0"
                libretro_log_level = "1"
                keyboard_gamepad_mapping_type = "1"
                input_poll_type_behavior = "2"
                video_monitor_index = "0"
                video_fullscreen_x = "0"
                video_fullscreen_y = "0"
                video_window_x = "0"
                video_window_y = "0"
                network_cmd_port = "55355"
                network_remote_base_port = "55400"
                dpi_override_value = "200"
                menu_thumbnails = "3"
                xmb_alpha_factor = "75"
                xmb_scale_factor = "100"
                xmb_theme = "0"
                xmb_menu_color_theme = "4"
                materialui_menu_color_theme = "0"
                menu_shader_pipeline = "1"
                audio_out_rate = "48000"
                custom_viewport_width = "1440"
                custom_viewport_height = "1080"
                custom_viewport_x = "240"
                custom_viewport_y = "0"
                content_history_size = "100"
                video_hard_sync_frames = "0"
                video_frame_delay = "0"
                video_max_swapchain_images = "3"
                video_swap_interval = "1"
                video_rotation = "0"
                aspect_ratio_index = "21"
                netplay_ip_port = "55435"
                netplay_input_latency_frames_min = "0"
                netplay_input_latency_frames_range = "0"
                user_language = "0"
                bundle_assets_extract_version_current = "0"
                bundle_assets_extract_last_version = "0"
                input_overlay_show_physical_inputs_port = "0"
                input_device_p1 = "0"
                input_player1_joypad_index = "0"
                input_libretro_device_p1 = "1"
                input_player1_analog_dpad_mode = "1"
                input_player1_mouse_index = "0"
                input_device_p2 = "0"
                input_player2_joypad_index = "1"
                input_libretro_device_p2 = "1"
                input_player2_analog_dpad_mode = "1"
                input_player2_mouse_index = "0"
                input_device_p3 = "0"
                input_player3_joypad_index = "2"
                input_libretro_device_p3 = "1"
                input_player3_analog_dpad_mode = "1"
                input_player3_mouse_index = "0"
                input_device_p4 = "0"
                input_player4_joypad_index = "3"
                input_libretro_device_p4 = "1"
                input_player4_analog_dpad_mode = "1"
                input_player4_mouse_index = "0"
                input_device_p5 = "0"
                input_player5_joypad_index = "4"
                input_libretro_device_p5 = "1"
                input_player5_analog_dpad_mode = "0"
                input_player5_mouse_index = "0"
                input_device_p6 = "0"
                input_player6_joypad_index = "5"
                input_libretro_device_p6 = "1"
                input_player6_analog_dpad_mode = "0"
                input_player6_mouse_index = "0"
                input_device_p7 = "0"
                input_player7_joypad_index = "6"
                input_libretro_device_p7 = "1"
                input_player7_analog_dpad_mode = "0"
                input_player7_mouse_index = "0"
                input_device_p8 = "0"
                input_player8_joypad_index = "7"
                input_libretro_device_p8 = "1"
                input_player8_analog_dpad_mode = "0"
                input_player8_mouse_index = "0"
                input_device_p9 = "0"
                input_player9_joypad_index = "8"
                input_libretro_device_p9 = "1"
                input_player9_analog_dpad_mode = "0"
                input_player9_mouse_index = "0"
                input_device_p10 = "0"
                input_player10_joypad_index = "9"
                input_libretro_device_p10 = "1"
                input_player10_analog_dpad_mode = "0"
                input_player10_mouse_index = "0"
                input_device_p11 = "0"
                input_player11_joypad_index = "10"
                input_libretro_device_p11 = "1"
                input_player11_analog_dpad_mode = "0"
                input_player11_mouse_index = "0"
                input_device_p12 = "0"
                input_player12_joypad_index = "11"
                input_libretro_device_p12 = "1"
                input_player12_analog_dpad_mode = "0"
                input_player12_mouse_index = "0"
                input_device_p13 = "0"
                input_player13_joypad_index = "12"
                input_libretro_device_p13 = "1"
                input_player13_analog_dpad_mode = "0"
                input_player13_mouse_index = "0"
                input_device_p14 = "0"
                input_player14_joypad_index = "13"
                input_libretro_device_p14 = "1"
                input_player14_analog_dpad_mode = "0"
                input_player14_mouse_index = "0"
                input_device_p15 = "0"
                input_player15_joypad_index = "14"
                input_libretro_device_p15 = "1"
                input_player15_analog_dpad_mode = "0"
                input_player15_mouse_index = "0"
                input_device_p16 = "0"
                input_player16_joypad_index = "15"
                input_libretro_device_p16 = "1"
                input_player16_analog_dpad_mode = "0"
                input_player16_mouse_index = "0"
                ui_companion_start_on_boot = "true"
                ui_companion_enable = "false"
                video_gpu_record = "false"
                input_remap_binds_enable = "true"
                netplay_public_announce = "true"
                netplay_start_as_spectator = "false"
                netplay_allow_slaves = "true"
                netplay_require_slaves = "false"
                netplay_stateless_mode = "false"
                netplay_client_swap_input = "true"
                netplay_use_mitm_server = "false"
                input_descriptor_label_show = "true"
                input_descriptor_hide_unbound = "false"
                load_dummy_on_core_shutdown = "true"
                check_firmware_before_loading = "false"
                builtin_mediaplayer_enable = "false"
                builtin_imageviewer_enable = "true"
                fps_show = "false"
                ui_menubar_enable = "true"
                suspend_screensaver_enable = "true"
                audio_sync = "true"
                video_shader_enable = "true"
                video_allow_rotate = "true"
                video_windowed_fullscreen = "true"
                video_crop_overscan = "true"
                video_scale_integer = "false"
                video_force_aspect = "true"
                video_shared_context = "false"
                auto_screenshot_filename = "true"
                video_force_srgb_disable = "false"
                video_fullscreen = "false"
                bundle_assets_extract_enable = "false"
                video_vsync = "true"
                video_hard_sync = "false"
                video_black_frame_insertion = "false"
                video_disable_composition = "false"
                pause_nonactive = "true"
                video_post_filter_record = "false"
                keyboard_gamepad_enable = "true"
                core_set_supports_no_game_enable = "true"
                audio_enable = "true"
                audio_mute_enable = "false"
                audio_mixer_mute_enable = "false"
                location_allow = "false"
                video_font_enable = "true"
                core_updater_auto_extract_archive = "true"
                camera_allow = "false"
                threaded_data_runloop_enable = "true"
                menu_throttle_framerate = "true"
                menu_linear_filter = "true"
                menu_horizontal_animation = "true"
                dpi_override_enable = "true"
                menu_pause_libretro = "true"
                menu_mouse_enable = "true"
                menu_pointer_enable = "false"
                menu_timedate_enable = "true"
                menu_battery_level_enable = "true"
                menu_core_enable = "true"
                menu_dynamic_wallpaper_enable = "false"
                materialui_icons_enable = "true"
                xmb_show_settings = "true"
                xmb_show_favorites = "true"
                xmb_show_netplay = "true"
                filter_by_current_core = "false"
                rgui_show_start_screen = "false"
                menu_navigation_wraparound_enable = "true"
                menu_navigation_browser_filter_supported_extensions_enable = "true"
                menu_show_advanced_settings = "false"
                cheevos_enable = "false"
                cheevos_test_unofficial = "false"
                cheevos_hardcore_mode_enable = "false"
                cheevos_verbose_enable = "false"
                # input_overlay_enable = ""
                input_overlay_enable_autopreferred = "true"
                input_overlay_show_physical_inputs = "false"
                input_overlay_hide_in_menu = "true"
                network_cmd_enable = "false"
                stdin_cmd_enable = "false"
                network_remote_enable = "false"
                netplay_nat_traversal = "true"
                block_sram_overwrite = "false"
                savestate_auto_index = "false"
                savestate_auto_save = "false"
                savestate_auto_load = "false"
                savestate_thumbnail_enable = "true"
                history_list_enable = "true"
                playlist_entry_remove = "true"
                game_specific_options = "true"
                auto_overrides_enable = "true"
                auto_shaders_enable = "true"
                sort_savefiles_enable = "false"
                sort_savestates_enable = "false"
                show_hidden_files = "false"
                audio_rate_control = "true"
                savestates_in_content_dir = "false"
                savefiles_in_content_dir = "false"
                systemfiles_in_content_dir = "false"
                screenshots_in_content_dir = "false"
                custom_bgm_enable = "false"
                network_remote_enable_user_p1 = "false"
                network_remote_enable_user_p2 = "false"
                network_remote_enable_user_p3 = "false"
                network_remote_enable_user_p4 = "false"
                network_remote_enable_user_p5 = "false"
                network_remote_enable_user_p6 = "false"
                network_remote_enable_user_p7 = "false"
                network_remote_enable_user_p8 = "false"
                network_remote_enable_user_p9 = "false"
                network_remote_enable_user_p10 = "false"
                network_remote_enable_user_p11 = "false"
                network_remote_enable_user_p12 = "false"
                network_remote_enable_user_p13 = "false"
                network_remote_enable_user_p14 = "false"
                network_remote_enable_user_p15 = "false"
                network_remote_enable_user_p16 = "false"
                log_verbosity = "false"
                perfcnt_enable = "false"
                video_message_color = "ffff00"
                menu_entry_normal_color = "ffffffff"
                menu_entry_hover_color = "ff64ff64"
                menu_title_color = "ff64ff64"
                gamma_correction = "false"
                flicker_filter_enable = "false"
                soft_filter_enable = "false"
                soft_filter_index = "0"
                current_resolution_id = "0"
                flicker_filter_index = "0"
                input_player1_b_btn = "nul"
                input_player1_b_axis = "nul"
                input_player1_y_btn = "nul"
                input_player1_y_axis = "nul"
                input_player1_select_btn = "nul"
                input_player1_select_axis = "nul"
                input_player1_start_btn = "nul"
                input_player1_start_axis = "nul"
                input_player1_up_btn = "nul"
                input_player1_up_axis = "nul"
                input_player1_down_btn = "nul"
                input_player1_down_axis = "nul"
                input_player1_left_btn = "nul"
                input_player1_left_axis = "nul"
                input_player1_right_btn = "nul"
                input_player1_right_axis = "nul"
                input_player1_a_btn = "nul"
                input_player1_a_axis = "nul"
                input_player1_x_btn = "nul"
                input_player1_x_axis = "nul"
                input_player1_l_btn = "nul"
                input_player1_l_axis = "nul"
                input_player1_r_btn = "nul"
                input_player1_r_axis = "nul"
                input_player1_l2 = "p"
                input_player1_l2_btn = "nul"
                input_player1_l2_axis = "nul"
                input_player1_r2 = "o"
                input_player1_r2_btn = "nul"
                input_player1_r2_axis = "nul"
                input_player1_l3 = "i"
                input_player1_l3_btn = "nul"
                input_player1_l3_axis = "nul"
                input_player1_r3 = "u"
                input_player1_r3_btn = "nul"
                input_player1_r3_axis = "nul"
                input_player1_l_x_plus = "nul"
                input_player1_l_x_plus_btn = "nul"
                input_player1_l_x_plus_axis = "nul"
                input_player1_l_x_minus = "nul"
                input_player1_l_x_minus_btn = "nul"
                input_player1_l_x_minus_axis = "nul"
                input_player1_l_y_plus = "nul"
                input_player1_l_y_plus_btn = "nul"
                input_player1_l_y_plus_axis = "nul"
                input_player1_l_y_minus = "nul"
                input_player1_l_y_minus_btn = "nul"
                input_player1_l_y_minus_axis = "nul"
                input_player1_r_x_plus = "nul"
                input_player1_r_x_plus_btn = "nul"
                input_player1_r_x_plus_axis = "nul"
                input_player1_r_x_minus = "nul"
                input_player1_r_x_minus_btn = "nul"
                input_player1_r_x_minus_axis = "nul"
                input_player1_r_y_plus = "nul"
                input_player1_r_y_plus_btn = "nul"
                input_player1_r_y_plus_axis = "nul"
                input_player1_r_y_minus = "nul"
                input_player1_r_y_minus_btn = "nul"
                input_player1_r_y_minus_axis = "nul"
                input_player1_turbo = "nul"
                input_player1_turbo_btn = "nul"
                input_player1_turbo_axis = "nul"
                input_toggle_fast_forward = "space"
                input_toggle_fast_forward_btn = "nul"
                input_toggle_fast_forward_axis = "nul"
                input_hold_fast_forward = "l"
                input_hold_fast_forward_btn = "nul"
                input_hold_fast_forward_axis = "nul"
                input_load_state = "f4"
                input_load_state_btn = "nul"
                input_load_state_axis = "nul"
                input_save_state = "f2"
                input_save_state_btn = "nul"
                input_save_state_axis = "nul"
                input_toggle_fullscreen = "f"
                input_toggle_fullscreen_btn = "nul"
                input_toggle_fullscreen_axis = "nul"
                input_exit_emulator_btn = "nul"
                input_exit_emulator_axis = "nul"
                input_state_slot_increase_btn = "nul"
                input_state_slot_increase_axis = "nul"
                input_state_slot_decrease_btn = "nul"
                input_state_slot_decrease_axis = "nul"
                input_rewind_btn = "nul"
                input_rewind_axis = "nul"
                input_movie_record_toggle = "o"
                input_movie_record_toggle_btn = "nul"
                input_movie_record_toggle_axis = "nul"
                input_pause_toggle = "p"
                input_pause_toggle_btn = "nul"
                input_pause_toggle_axis = "nul"
                input_frame_advance = "k"
                input_frame_advance_btn = "nul"
                input_frame_advance_axis = "nul"
                input_reset_btn = "nul"
                input_reset_axis = "nul"
                input_shader_next_btn = "nul"
                input_shader_next_axis = "nul"
                input_shader_prev_btn = "nul"
                input_shader_prev_axis = "nul"
                input_cheat_index_plus = "y"
                input_cheat_index_plus_btn = "nul"
                input_cheat_index_plus_axis = "nul"
                input_cheat_index_minus = "t"
                input_cheat_index_minus_btn = "nul"
                input_cheat_index_minus_axis = "nul"
                input_cheat_toggle = "u"
                input_cheat_toggle_btn = "nul"
                input_cheat_toggle_axis = "nul"
                input_screenshot = "f8"
                input_screenshot_btn = "nul"
                input_screenshot_axis = "nul"
                input_audio_mute = "f9"
                input_audio_mute_btn = "nul"
                input_audio_mute_axis = "nul"
                input_osk_toggle = "f12"
                input_osk_toggle_btn = "nul"
                input_osk_toggle_axis = "nul"
                input_netplay_flip_players_1_2 = "nul"
                input_netplay_flip_players_1_2_btn = "nul"
                input_netplay_flip_players_1_2_axis = "nul"
                input_netplay_game_watch = "i"
                input_netplay_game_watch_btn = "nul"
                input_netplay_game_watch_axis = "nul"
                input_slowmotion = "e"
                input_slowmotion_btn = "nul"
                input_slowmotion_axis = "nul"
                input_enable_hotkey_btn = "nul"
                input_enable_hotkey_axis = "nul"
                input_volume_up = "add"
                input_volume_up_btn = "nul"
                input_volume_up_axis = "nul"
                input_volume_down = "subtract"
                input_volume_down_btn = "nul"
                input_volume_down_axis = "nul"
                input_overlay_next = "nul"
                input_overlay_next_btn = "nul"
                input_overlay_next_axis = "nul"
                input_disk_eject_toggle = "nul"
                input_disk_eject_toggle_btn = "nul"
                input_disk_eject_toggle_axis = "nul"
                input_disk_next = "nul"
                input_disk_next_btn = "nul"
                input_disk_next_axis = "nul"
                input_disk_prev = "nul"
                input_disk_prev_btn = "nul"
                input_disk_prev_axis = "nul"
                input_grab_mouse_toggle = "f11"
                input_grab_mouse_toggle_btn = "nul"
                input_grab_mouse_toggle_axis = "nul"
                input_game_focus_toggle = "scroll_lock"
                input_game_focus_toggle_btn = "nul"
                input_game_focus_toggle_axis = "nul"
                input_menu_toggle_btn = "nul"
                input_menu_toggle_axis = "nul"
                input_player2_b = "s"
                input_player2_b_btn = "nul"
                input_player2_b_axis = "nul"
                input_player2_y = "w"
                input_player2_y_btn = "nul"
                input_player2_y_axis = "nul"
                input_player2_select = "6"
                input_player2_select_btn = "nul"
                input_player2_select_axis = "nul"
                input_player2_start = "2"
                input_player2_start_btn = "nul"
                input_player2_start_axis = "nul"
                input_player2_up = "r"
                input_player2_up_btn = "nul"
                input_player2_up_axis = "nul"
                input_player2_down = "f"
                input_player2_down_btn = "nul"
                input_player2_down_axis = "nul"
                input_player2_left = "d"
                input_player2_left_btn = "nul"
                input_player2_left_axis = "nul"
                input_player2_right = "g"
                input_player2_right_btn = "nul"
                input_player2_right_axis = "nul"
                input_player2_a = "a"
                input_player2_a_btn = "nul"
                input_player2_a_axis = "nul"
                input_player2_x = "i"
                input_player2_x_btn = "nul"
                input_player2_x_axis = "nul"
                input_player2_l = "q"
                input_player2_l_btn = "nul"
                input_player2_l_axis = "nul"
                input_player2_r = "k"
                input_player2_r_btn = "nul"
                input_player2_r_axis = "nul"
                input_player2_l2 = "nul"
                input_player2_l2_btn = "nul"
                input_player2_l2_axis = "nul"
                input_player2_r2 = "nul"
                input_player2_r2_btn = "nul"
                input_player2_r2_axis = "nul"
                input_player2_l3 = "nul"
                input_player2_l3_btn = "nul"
                input_player2_l3_axis = "nul"
                input_player2_r3 = "nul"
                input_player2_r3_btn = "nul"
                input_player2_r3_axis = "nul"
                input_player2_l_x_plus = "nul"
                input_player2_l_x_plus_btn = "nul"
                input_player2_l_x_plus_axis = "nul"
                input_player2_l_x_minus = "nul"
                input_player2_l_x_minus_btn = "nul"
                input_player2_l_x_minus_axis = "nul"
                input_player2_l_y_plus = "nul"
                input_player2_l_y_plus_btn = "nul"
                input_player2_l_y_plus_axis = "nul"
                input_player2_l_y_minus = "nul"
                input_player2_l_y_minus_btn = "nul"
                input_player2_l_y_minus_axis = "nul"
                input_player2_r_x_plus = "nul"
                input_player2_r_x_plus_btn = "nul"
                input_player2_r_x_plus_axis = "nul"
                input_player2_r_x_minus = "nul"
                input_player2_r_x_minus_btn = "nul"
                input_player2_r_x_minus_axis = "nul"
                input_player2_r_y_plus = "nul"
                input_player2_r_y_plus_btn = "nul"
                input_player2_r_y_plus_axis = "nul"
                input_player2_r_y_minus = "nul"
                input_player2_r_y_minus_btn = "nul"
                input_player2_r_y_minus_axis = "nul"
                input_player2_turbo = "nul"
                input_player2_turbo_btn = "nul"
                input_player2_turbo_axis = "nul"
                xmb_font = ""
                netplay_nickname = ""
                video_filter = ""
                audio_dsp_plugin = ""
                core_updater_buildbot_url = ""
                netplay_ip_address = ""
                netplay_password = ""
                netplay_spectate_password = ""
                video_shader = ""
                menu_wallpaper = ""
                input_overlay = ""
                video_font_path = ""
                content_history_dir = ""
                resampler_directory = ""
                recording_output_directory = ""
                recording_config_directory = ""
                xmb_font = ""
                playlist_names = ""
                playlist_cores = ""
                audio_device = ""
                camera_device = ""
                cheevos_username = ""
                cheevos_password = ""
                video_context_driver = ""
                input_keyboard_layout = ""
                bundle_assets_src_path = ""
                bundle_assets_dst_path = ""
                bundle_assets_dst_path_subdir = ""
                  djsim101 @mitu
                  @mitu hey, just uploaded the entire contents of that file.
                  Could it be that I have the button 5 configured elsewhere?
                  I had 5 selected also as the hotey
                    That's ok, the 'hotkey enable' key can be used for other functions.
                    Try this replacing the 5 with num5 and see if it works.
                    input_player1_select = "num5"
                    input_enable_hotkey = "num5"
                    Also, when pasting a large text file, use pastebin.com, not the topic - it's very difficult to search and look for clues in the topic.
                      djsim101 @mitu
                      @mitu You sir are a gent. That did the trick. Thanks for all your help.
