mupen64plus not using controller configuration
I'm using an N64 replica controller made by a company named Cirka. While the Raspberry Pi recognizes the controller, I can't get it to remember my controller settings. Even when I edit the
/opt/retropie/configs/n64/InputAutoCfg.ini
file, mupen64plus won't use my controller settings. Specifically, the L-shoulder button is switched for the A button, and the Z button is switched for the B button. I've also tried editing the/opt/retropie/configs/n64/mupen64plus.cfg
file. But that didn't work. All of the other buttons work, though.Other information:
- Raspberry Pi 3
- Using binary release
- Version of RetroPie: 4.0-rc1
- Pastebin for InputAutoCfg.ini (controller entry at the very bottom)
- Pastebin for mupen64plus.cfg (The entry for my controller is marked "Generic USB Joystick ")
- RetroPie is configured for XBox 360 userspace drivers, but 360 controllers are not used, nor hooked up.
- Output from lsusb:
Bus 001 Device 005: ID 0079:0002 DragonRise Inc.
- Btw, I have seen an entry in the "InputAutoCfg.ini" for a "DragonRise Inc." controller. But editing that doesn't change the problem.
