    Redream - Mouse does not cover entire screen / Aim Issue
    redreammouse coveragemouse
    4 Posts 2 Posters 1.4k Views
    • duglorD
      duglor
      Hi,
      Currently when I use Redream, the light gun games that I use a mouse for are trouble. The mouse I have does not cover the entire screen. Just the top left quadrant or left middle quadrant. This also happens if i try to use the mouse in the menu screen. It doesn't reach all areas of the menu such as exit. Is there a way to fix mouse coverage to the entire screen for this emulator?
      or if this happens in other emulators, not sure if it does, what is a common fix? -Doug P.S. In lightgun games, the aim from the cursor is way off as well.
      duglorD 1 Reply Last reply Reply Quote 0
      • duglorD
        duglor @duglor
        @duglor Just wondering. I have redream set at 720p. Could this cause the trouble? Should i reset it to 1080p to match the screen res? But the aim...
        • windgW
          windg
          I have the same issue, it's like there is an invisible barrier that don't let the mouse to move . I t looks that this is a issue with the emulator, someone else report this in gitlab for a different platorm :
          https://gitlab.com/inolen/redream/-/issues/1213
          • duglorD
            duglor @windg
            @windg Makes sense. I did fix the issue by making the resolution 640x480. It covered the entire screen. HOWEVER, it looked crappy and the aim was way off and it shot far to the side of the cursor in the light gun game.
