    [SOLVED] Help With 2.2" ILI9341 Display Not Working
    gpioscreentft
    15 Posts 2 Posters 9.2k Views
      I don't want to hijack @moosepr's post with me trying to figure out this display, but can someone get me some tips on what to check for on why my display isn't working?
      I tried to use this blog post to wire it up. The pins aren't labeled exactly the same as the Adafruit display, but I think I have them connected properly.
      This is a photo of the display's pins.
      This is how I think they translated to the chart on the aforementioned blog post.
      I connected it up to my T-board to what I think are the right pins.
      I tried running the commands from here
      if i remember right, you need to go into the raspiconfig, and enable spi, disable overscan, and enable device tree, then you should be able to run the command "sudo modprobe fbtft_device pitft22" to actually get the screen active (the backlight should light). You can test it with the command "con2fbmap 1 1" which should pop your terminal session onto the tft screen (run "con2fbmap 1 0" to get it back)
      And I'm getting an error
      pi@retropie:~ $ sudo modprobe fbtft_device pitft22
      modprobe: ERROR: could not insert 'fbtft_device': Invalid argument
      The display does nothing. On the good side nothing sizzled, popped, created a weird smell, or lit on fire.
      I've tried Googling that error and I've not found anything helpful, so if anyone has any insight or can point me to somewhere with some good troubleshooting I'd really appreciate it. I may have it hooked up wrong (very possible) or I have to run a command/install something (very possible) or my display is a dud (I have no way to know).
        This article from Adafruit seems helpful, but can anyone confirm my pinout translation? I think I have something hooked up wrong.
        mooseprM 2 Replies Last reply Reply Quote 0
        • mooseprM
          moosepr @obsidianspider
          @obsidianspider the only thing to check is your green cable. It looks to be into gnd rather than pin 25 on the pi side.
          Have you enabled the SPI in the raspiconfig?
          want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
          • mooseprM
            @obsidianspider also I may have got the command wrong! My memory is failing me
            Try this
            Sudo modprobe fbtft_device name=adafruit22
              obsidianspider @moosepr
              @moosepr Thanks for the tips. The green wire is hooked up to Pin 25. I'm going to have to check into the SPI configuration. I thought I enabled it, but I've been away for work for the past few days and haven't had a chance to fool with it. Once I get everything working I'll be sure to write it up so future people don't struggle like I am.
                After installing the dependencies from the Adafruit article and running
                sudo python image.py
                I got the screen to light up! But there was no cat image. I tried re-running the command and now I get
                pi@retropie:~/Adafruit_Python_ILI9341/examples $ sudo python image.py
                Traceback (most recent call last):
                  File "image.py", line 41, in <module>
                    disp = TFT.ILI9341(DC, rst=RST, spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE, max_speed_hz=64000000))
                  File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/SPI.py", line 42, in __init__
                IOError: [Errno 2] No such file or directory
                It lit up once, so that's a good sign. Now I just need to figure out why that error is showing up and why the cat image didn't display intitially.
                Baby steps…
                mooseprM 1 Reply Last reply Reply Quote 0
                • mooseprM
                  @obsidianspider that adafruit bit you found is using python to talk to the screen (which is fine) but im not sure how that would cope with being able to load different images at different times (maybe you could pass the path to the image when calling the python?)
                  did you try the other command i sent?
                  this should make the backlight fire up, then you can type
                  con2fbmap 1 1
                  to get your terminal onto the little tft
                    pi@retropie:~ $ sudo modprobe fbtft_device name=adafruit22
                    doesn't seem to do anything
                    But I think I may be on to part of the problem
                    When I do
                    ls /dev/*spi*
                    when I'm first booting I get
                    /dev/spidev0.0  /dev/spidev0.1
                    Which is what Adafruit and some other articles say that I should see if SPI is working
                    but later (once EmulationStation is fully loaded) I get
                    pi@retropie:~ $ ls /dev/*spi*
                    /dev/spidev0.1
                      I got it to work… kind of.
                      The first thing I did was update to RetroPie 4.0.2
                      But I still think there's something wrong with how I have it connected.
                      When I boot up the pi, both SPI ports are showing.
                      but when I try to fire up the command from @moosepr the screen doesn't fire up and that first SPI port is gone, and I can't get it back until I reboot
                      /dev/spidev0.1
                      After a reboot I have mixed success with the Adafruit Python script.
                      They have DC=18 and RST=23 and when I run the image.py file like that, the display turns on, but nothing displays at all, or it's garbled.
                      If I change the script to have DC=24 and RST=25 to match how I have things wired up, I get the image to display properly.
                      BUT
                      When I reboot the Pi, if I run the script with the "right" pins selected, the display will never start up in the first place. I have to start it with 18 and 23 and then run it again with 24 and 25. I'm missing something, but at least the darn thing turns on and I can display something
                      Onward…
                        I got a little script working to display game art based on the game you're playing, failing over to an image for the system if no game art is found, and showing a default image while in EmulationStation, but I still can't get this thing to turn on properly. Here's a video of it working. @moosepr would you be able to tell me what pins on your display you have connected to which pins on your Pi? I'd like to compare with how mine is set up.
                          I wired the backlight pin to 3.3V and now the display lights up properly when the Pi is powered on, and things seem to work with DC on pin 24 and RST on pin 25. It seems like having the backlight on all the time is how these displays are designed to work.
                            It looks like by using the pin 18 initially with the default adafruit script that was sending power to the backlight. I wrote a script to turn on the backlight (and another one to turn it off)
                            backlighton.py
                            import RPi.GPIO as GPIO
                            # Turn on Backlight
                            GPIO.setmode(GPIO.BCM)
                            GPIO.setwarnings(False)
                            GPIO.setup(18,GPIO.OUT)
                            GPIO.output(18,GPIO.HIGH)
                            backlightoff.py
                            # Turn off Backlight
                            GPIO.output(18,GPIO.LOW)
                              Huzzah!
                              I wrote a script to load an image and then turn on the backlight when the Pi Boots up. (I realize that for some of you this is trivial, but right now I feel like some kind of secret ninja wizard. )
                              I still can't get that whole "modprobe" thing working, at all, but I'm happy with my progress and for what I want this display to do, I don't know that I need it.
                              • mooseprM
                                moosepr
                                looking good man!!! the python will be sending the commands direct to the screen, negating the need for the modprobe and a such annoyances
                                I cant get to my lil device at the moment, its in the loft somewhere buried under a big old pile of stuff, but here is the second best thing
                                screen end
                                pi end
                                other side of pi
                                hope this helps
                                  @moosepr That does help! Thanks! This has been quite an educational experience.
