    es_systems.cfg systems file extensions and rom filenames
    emulationstatiov2.11.2rpcapitalupper-caseessystems.cfg
    34 Posts 3 Posters 4.6k Views
      mitu Global Moderator @2Play
      @2Play said in es_systems.cfg systems file extensions and rom filenames:
      Should I recompile? Shouldnt with xml the file with capitals .EXE to be omitted from being displayed with the bug fix?
      No, and I'm confused why you'd think it would.
      2Play2 1 Reply Last reply Reply Quote 0
      • 2Play2
        2Play @mitu
        My understanding was that what the bug fix would do.
        "Gamelist bugfix: don't show un-registered extensions"
        I thought that on the dev binary it would do this. Or the fix expects to see both in the xml and then exclude what is not in es_systems.cfg
        For Reference
        In the past, on pi3,4 if you wanted to hide a rom file from showing in the ES gamelist, you just removed the extension and these were not displayed any more
        Its a practice many used the past years by changing the extension to CAPITAL letters and then remove from the es_systems.cfg
        I ll try to dig up an older binary for pi4 that I used in same way and provide you the version
        Your friend,
        2Play!
          It does that, but - as I explained later on - extension search is case-insensitive so if you add .exe, then .EXE is also matched even if not listed.
          Sure, let me know the version and I'll check.
          • 2Play2
            2Play @mitu
            @mitu found it!
            2.9.3RP has this feature. Seems changed from 2.10 onwards?
            NOTE: 2.9.6rp had the bug with the video screensaver not starting a rom any more which I see it got fixed in current version
            To our discussion:
            I have in ags, exactly as I wrote in https://retropie.org.uk/forum/post/291385 2h ago
            • es_systems only .exe extension
            • ags/subfolder game/.exe .EXE the files
            if i rename both to .exe they both show. once I rename the unwanted winsetup with .EXE it hides
            (no gamelist.xml whatsoever used)
            Your friend,
            2Play!
              Seems to have been introduced with this change in 2.10.0 indeed.
              EDIT: I'll prepare a patch for -dev, will let you know when it's ready.
              2Play2 1 Reply Last reply Reply Quote 1
              • 2Play2
                2Play @mitu
                @mitu much appreciated.
                Will give you feedback when ready.
                Your friend,
                2Play!
                  Ok, a patch has been added to the ES repo, it should be available if you install from source the emulationstation-dev package.
                  2Play2 2 Replies Last reply Reply Quote 1
                  • 2Play2
                    2Play @mitu
                    @mitu reverting
                    Your friend,
                    2Play!
                    • 2Play2
                      2Play @mitu
                      @mitu First of all thank you for taking the time to check and make a patch.
                      Glad i managed to point you to the right info
                      I want to confirm that your patch on latest dev (2.12.0RP-DEV) is working as supposed to and did in the past.
                      I ve tested 2 systems, the AGS and PC98 for similar setup (upper case extensions and deleted from es_systems.cfg)
                      Both show ONLY what is in lower case extension and hides the upper case ones (deletd from cfg)
                      My kind regards and thank you again!
                      Your friend,
                      2Play!
                      • 2Play2
                        2Play @2Play
                        @mitu hello friend again
                        If you see the last couple mgs in this thread you will notice you applied a fix for the change took place after 2.10.0 in regards to upper case extensions showing even if not present in the es_systems of ES
                        I have been testing on Pi5 installation of RetroPie
                        I have the RetroPie script
                        Emulationstation Version 2.11.2rp, built Feb 20 2025
                        I was testing the MSX with lr-bluemsx and m3u files:
                        I will post about the m3u problems in the https://retropie.org.uk/forum/topic/16124/multidisk-msx-games-and-m3u-files?_=1742312978738
                        as game loads but needs manually to swap to other disks
                        But as per this post, I tested the m3u by making the multidisk file extensions in upper case example .DSK and removed the .DSK from ES es_systems.cfg for msx
                        Both dsk and DSK show in the system even if DSK removed.
                        In my understanding is that ES 2.11.2rp does not have your patch/fix yet, correct?
                        Is there a reason that the team doesnt include the fix on the stable ES release (being also a feature up to 2.9.3rp?
                        Examples:
                        Rom folder
                        Emulationstation Version 2.12.0rp
                        Your friend,
                        2Play!
                          No it doesn't, the fix was added after that version.
                          There hasn't been any new version released since the fix, that's the only reason. As said before, you can use emulationstation-dev and you'll get the fix.
                          • 2Play2
                            2Play @mitu
                            @mitu is there another stable version after the 2.11.2rp?
                            Your friend,
                            2Play!
                              I just told you that there isn't ...
                              • 2Play2
                                2Play @mitu
                                @mitu thank you i compiled it from master
                                Your friend,
                                2Play!
