    Issue with 8bit Do SN30 Pro Bluetooth gamepad
    8bit do8bit do sn30gamepadbluetoothtriggers
    27 Posts 3 Posters 4.8k Views
    • I
      IGA @IGA
      expletive deleted.
      As i've predict, after updating retropie setup script to 4.8.5 i've got new trouble with component video output in progressive mode :(((
      Somebody know how to get back to previous 4.7.19 ???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
      mituM 1 Reply Last reply Reply Quote -1
        mitu Global Moderator @IGA
        @IGA you got a temp ban for language. Please keep it civil.
        From a working backup - https://retropie.org.uk/docs/Updating-RetroPie/#making-a-backup.
        I 2 Replies Last reply Reply Quote 0
        • I
          IGA @mitu
          @mitu said in Issue with 8bit Do SN30 Pro Bluetooth gamepad:
          if I had done it before this update.... :((
          • I
            IGA @IGA
            Hi!
            Once again problem with another 8bitdo controller))
            At this time i've got NEO GEO gamepad
            And all works fine, but now with system menu button (hotkey) has issue! When i press it in game - it's work like quit (maybe it registries already as start+hotkey button to exit).
            At retropie's home menu this button menu it's work normal - system menu has appeared. But in retroarch, in game - exit.
            Even if bind hotkey in any another button such as L1 for example, it still work as still same system button not L1 at gamepad in game....
            Also I just noticed, that buttons C and D are work in turbo mode as default. I've supposed that my controller is broken or corrupt, but when i've plugged it to PC this buttons wok correctly (no turbo). Unfortunately, i can't test system buttons on PC (star and heart), cause they don't work at Windows
            Please tell ,e how could solve this problem, if it possible at all.
            • I
              IGA @IGA
              solved with neogeo gamepad: the solution of the problem was throw away 2.4 dongle and connect gamepad through standard pi Bluetooth - work fine
              • I
                IGA @IGA
                but if somebody told me how to make vibration and all buttons work at SN30 at last, i was very very glad...))
                • I
                  IGA @mitu
                  I want to bring up this topic again!
                  As I have noticed from experience, at SWITCH mode sn30pro + retropie could has much delay! And it's awful :(
                  So, in 2024 year, could someone tell how to get work sn30 at XINPUT mode? ( with both working Triggers and "hotkey" buttons)
