    need help Psx Emulation can load games ...!
    psxemulationerrorno gamehelp
    9 Posts 3 Posters 877 Views
      akumoo
      I have been trying to get the PlayStation emulator to work well for 3 days now, but even though I have downloaded the bios I cannot play half of the rooms, for example silent hill (english, spanish) or many others, any suggestions...
      Note. I am using an i5 PC, with 12 gigabytes of ram, 1 gigabyte graphics card and a 320 gigabyte hard drive.
      I hope to place the post in the correct link, thank you
        akumoo
        post data. I installed the retropie on the linux-lite-6.6-64bit distro, I followed the steps to install the page without any errors
        • abjA
          abj
          Run the a game with verbose logging enable and add here the log with the help of pastebin.com
          Instructions: https://retropie.org.uk/docs/Runcommand/
          `Please be patient, my English is not very good.`
          A 2 Replies Last reply Reply Quote 0
            akumoo @abj
            @abj Thanks for your answer, I'm going to follow those steps and upload the log to pastebin
            hare is... link text
            abjA mituM 2 Replies Last reply Reply Quote 0
            • abjA
              abj @akumoo
              @akumoo If you can, try the same game but find it from a different source. Just to rule out that it's not a rom issue. You can try and the lr-pcsx-rearmed emulator.
              Do you have the correct bios files? Beetle Psx needs : scph5500.bin scph5501.bin scph5502.bin
                mitu Global Moderator @akumoo
                @akumoo said in need help Psx Emulation can load games ...!:
                The Silent Hill.cue file seems to be wrong - either corrupted or malformed. Can you post its contents here ?
                  akumoo @abj
                  the retropie have only one emulator for playstation lookCaptura de pantalla_2024-02-10_16-04-49.png
                  can i install some others...
                    akumoo @mitu
                    @mitu ok i try this, not same error whit other iso of silent hill, i have 2 one PAL another NTSCCaptura de pantalla_2024-02-10_16-44-05.png
                      Please post the contents of the .cue file - you can open it as text, since it's just text. Did you also checked the BIOS files that @abj mentioned - are they present in the BIOS folder ?
