    MKDD Tint Issue RPI5
    lr-dolphinmkdddoubledashvulkandrivers
    175 Posts 11 Posters 65.9k Views
    • sugarfreeS
      sugarfree @sugarfree
      @sugarfree said in MKDD Tint Issue RPI5:
      I haven't tried it yet, but if I find a way to do it, I will post it in the retropie-extra repo of course.
      Sorry guys, I couldn't get a script working for this emulator.
        gvx64 @roslof
        @roslof I just wanted to let you know that I have pushed a new master that has .rvz support as per the changes in 5.0-12188 (build instructions same as above). This build should now be able to open and play .rvz files. I converted a few of my iso's to rvz's (Baten Kaitos Eternal Wings and Mario Golf) and there doesn't appear to be any noticeable loss in performance between the iso and rvz formats of these games. That being said, please let me know if you have different experiences running rvz files.
        @sugarfree Can you please give this install script a try. You should just have to make a file called "dolphin-rpi.sh" in /home/pi/RetroPie-Setup/scriptmodules/emulators and then paste the contents below into it. This isn't the prettiest implementation but make install was giving me all kinds of headaches and so I ended up just using the script to manually copy files into the proper location.
        #!/usr/bin/env bash
        # This file is part of The RetroPie Project
        # The RetroPie Project is the legal property of its developers, whose names are
        # too numerous to list here. Please refer to the COPYRIGHT.md file distributed with this source.
        # See the LICENSE.md file at the top-level directory of this distribution and
        # at https://raw.githubusercontent.com/RetroPie/RetroPie-Setup/master/LICENSE.md
        rp_module_id="dolphin-rpi"
        rp_module_desc="Gamecube/Wii Dolphin Modified from 5.0-4544 for Pi Users"
        rp_module_help="ROM Extensions: .elf .dol .gcm .iso .rvz .wbfs .ciso .gcz .wad .dff\n\nCopy your Gamecube roms to $romdir/gc and Wii roms to $romdir/wii"
        rp_module_licence="GPL2 https://github.com/gvx64/dolphin-rpi/blob/master/license.txt"
        rp_module_repo="git https://github.com/gvx64/dolphin-rpi.git master"
        rp_module_section="exp"
        rp_module_flags="aarch64 vulkan"
        function depends_dolphin-rpi() {
            local depends=(cmake gcc-11 g++-11 pkg-config libasound2-dev libopenal-dev libevdev-dev libgtk2.0-dev qtbase5-private-dev)
            isPlatform "kms" && depends+=(xorg matchbox-window-manager)
            getDepends "${depends[@]}"
        function sources_dolphin-rpi() {
            gitPullOrClone
        function build_dolphin-rpi() {
            mkdir build
            cd build
            # use the bundled 'speexdsp' libs, distro versions before 1.2.1 trigger a 'cmake' error
            cmake .. -DCMAKE_C_COMPILER=gcc-11 -DCMAKE_CXX_COMPILER=g++-11 -DBUNDLE_SPEEX=ON -DENABLE_AUTOUPDATE=OFF -DENABLE_ANALYTICS=OFF  -DUSE_DISCORD_PRESENCE=O>    make clean
            make
            md_ret_require="$md_build/build/Binaries/dolphin-emu"
        function install_dolphin-rpi() {
            #copy binaries to /opt/retropie/emulators/dolphin-rpi
            cd build/Binaries/
            mkdir /opt/retropie/emulators/dolphin-rpi/
            mkdir /opt/retropie/emulators/dolphin-rpi/bin/
            mv dolphin-emu /opt/retropie/emulators/dolphin-rpi/bin/
            mv dolphin-emu-nogui /opt/retropie/emulators/dolphin-rpi/bin/
            #use /home/pi/DolphinConfig5.0/ as the configuration/settings/save file directory
            cd ..
            mkdir /home/pi/DolphinConfig5.0/
            mkdir /home/pi/DolphinConfig5.0/Config/
            mv ../Data/Sys/GameSettings/ /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/GC/ /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/Wii/ /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/Maps/ /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/Resources/ /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/Shaders/ /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/Themes/ /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/codehandler.bin /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/totaldb.dsy /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-de.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-en.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-es.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-fr.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-it.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-ja.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-ko.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-nl.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-pt.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-ru.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-zh_CN.txt /home/pi/DolphinConfig5.0/
            mv ../Data/Sys/wiitdb-zh_TW.txt /home/pi/DolphinConfig5.0/
        function remove_dolphin-rpi() {
            rm -r /home/pi/DolphinConfig5.0/GameSettings/
            rm -r /home/pi/DolphinConfig5.0/Maps/
            rm -r /home/pi/DolphinConfig5.0/Resources/
            rm -r /home/pi/DolphinConfig5.0/Shaders/
            rm -r /home/pi/DolphinConfig5.0/Themes/
            rm -r /home/pi/DolphinConfig5.0/Config/
            rm /home/pi/DolphinConfig5.0/codehandler.bin
            rm /home/pi/DolphinConfig5.0/totaldb.dsy
            rm /home/pi/DolphinConfig5.0/wiitdb-de.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-en.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-es.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-fr.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-it.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-ja.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-ko.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-nl.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-pt.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-ru.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-zh_CN.txt
            rm /home/pi/DolphinConfig5.0/wiitdb-zh_TW.txt
        #   Do not delete GC or Wii save file directories upon emulator uninstall
        #    rm -r /home/pi/DolphinConfig5.0/GC/
        #    rm -r /home/pi/DolphinConfig5.0/Wii/
        function configure_dolphin-rpi() {
            mkRomDir "gc"
            mkRomDir "wii"
            local launch_prefix
            isPlatform "kms" && launch_prefix="XINIT-WM:"
            addEmulator 0 "$md_id" "gc" "$launch_prefix$md_inst/bin/dolphin-emu-nogui -e %ROM% -u /home/pi/DolphinConfig5.0/"
            addEmulator 1 "$md_id-gui" "gc" "$launch_prefix$md_inst/bin/dolphin-emu -b -e %ROM% -u /home/pi/DolphinConfig5.0/"
            addEmulator 2 "$md_id-configure" "gc" "$launch_prefix$md_inst/bin/dolphin-emu -u /home/pi/DolphinConfig5.0/"
            addEmulator 3 "$md_id-configure-hotkeys" "gc" "$launch_prefix$md_inst/bin/dolphin-emu-qt2 -u /home/pi/DolphinConfig5.0/"
            addEmulator 0 "$md_id" "wii" "$launch_prefix$md_inst/bin/dolphin-emu-nogui -e %ROM% -u /home/pi/DolphinConfig5.0/"
            addEmulator 1 "$md_id-gui" "wii" "$launch_prefix$md_inst/bin/dolphin-emu -b -e %ROM% -u /home/pi/DolphinConfig5.0/"
            addEmulator 2 "$md_id-configure" "wii" "$launch_prefix$md_inst/bin/dolphin-emu -u /home/pi/DolphinConfig5.0/"
            addEmulator 3 "$md_id-configure-hotkeys" "wii" "$launch_prefix$md_inst/bin/dolphin-emu-qt2 -u /home/pi/DolphinConfig5.0/"
            addSystem "gc"
            addSystem "wii"
            [[ "$md_mode" == "remove" ]] && return
            # preset options used for Raspberry Pi 4 (Bookworm) - modify for your build as desired
           cat >"$home/DolphinConfig5.0/Config/Dolphin.ini" <<_EOF_
        [Core]
        OverclockEnable = False
        EnableCheats = False
        GFXBackend = Vulkan
        CPUCore = 4
        Fastmem = True
        CPUThread = True
        SyncOnSkipIdle = True
        FPRF = False
        AccurateNaNs = False
        AudioLatency = 20
        AutoDiscChange = True
        [Display]
        FullscreenDisplayRes = Auto
        Fullscreen = True
        RenderToMain = True
        KeepWindowOnTop = True
        [Interface]
        ConfirmStop = False
        [General]
        ISOPath0 = "$home/RetroPie/roms/gc"
        ISOPath1 = "$home/RetroPie/roms/wii"
        ISOPaths = 2
        WiiSDCardPath = /home/pi/DolphinConfig5.0/Wii/sd.raw
        _EOF_
           chown -R $user:$user "$home/DolphinConfig5.0/Config"
        roslofR TPRT 3 Replies Last reply Reply Quote 2
        • roslofR
          roslof @gvx64
          @gvx64 said in MKDD Tint Issue RPI5:
          This sounds terrific! Thank you for this. I'll check it out as soon as I find a few cycles. Cheers!
          • sugarfreeS
            sugarfree
            @gvx64
            Many thanks for everything you are doing! I tried the script, and the installation was completed without errors.
            I haven't figured out how to launch the games so I can test it further. It looks like the script doesn't create the shortcuts that Dolphin creates (runcommand), games aren't visible to ES. Also, after the installation, I saw an error when I was running RetroPie-Setup:
            /home/pi/RetroPie-Setup/scriptmodules/emulators/dolphin-rpi.sh: Line 56 : syntax error near unexpected near unexpected token'
            /home/pi/RetroPie-Setup/scriptmodules/emulators/dolphin-rpi.sh: Line 56 : '}'
            G 2 Replies Last reply Reply Quote 1
              gvx64 @sugarfree
              @sugarfree Yeah, sorry I have been working on it on-and-off today after I posted it and discovered that there were issues. I am getting very close to having it working I will let you know once it is ready to go and I will update the previous post with the final script.
                gvx64 @sugarfree
                @sugarfree Can you please give the above script another try?
                It's a conceptually tough decision about what to do when somebody uninstalls this emulator. Dolphin has a shared configuration and save file directory. I agree that uninstalling should remove all config files but I am very uncomfortable about deleting save files. As a result, I am leaving the GC and Wii subfolders in the DolphinConfig5.0 directory when somebody uninstalls. You can change this by removing the comments from the lines in the remove_dolphin-rpi() function if you would prefer.
                I hopes that this script works better. Please let me know if you see any other errors or areas for improvement.
                sugarfreeS 1 Reply Last reply Reply Quote 0
                • sugarfreeS
                  sugarfree @gvx64
                  @gvx64 Emulator is working and it's running the Resident Evil 4 very well (fully playable)!!
                  I Encountered an issue when attempting to launch dolphin-rpi-gui from runcommand menu. It failed to start correctly, displaying two error messages. Additionally, I was unable to configure the controller or modify other emulator settings. However, the keyboard functioned normally within the games.
                  Error:Trying to access Windows-1252 fonts but they are not loaded. Games may not show fonts correctley, or crash.
                  Failed to load image from file "use/local/share/dolphin-emu/sys/Resources/dolphin_logo@2x.png"
                    gvx64 @sugarfree
                    @sugarfree Thank you for the feedback.
                    Regarding the controller configuration, you will need to configure your gamepad manually by exiting emulationstation and in the console typing:
                    sudo xinit /opt/retropie/emulators/dolphin-rpi/bin/dolphin-emu -u /home/pi/DolphinConfig5.0/
                    At this point you should see the dolphin emulator user interface pop up. You can then click on the "Controllers" icon (you will need a mouse and possibly a keyboard to do this). You can then configure your gamepad the normal way within dolphin and it should save a settings file in the Config folder within DolphinConfig5.0 which will carry over to emulationstation. You should also be able to specify your hotkeys in Options -> Hotkey Settings. This is also where you can customize other settings like the CPU Overrride and various graphical settings (although it is probably better to specify these settings on a per game basis in your game specific ini files in /home/pi/DolphinConfig5.0/GameSettings/). Exiting this session can be done with "CTRL + ALT + F1" followed by "CTRL + C" which will bring you back to the console.
                    EDIT: I just noticed that the hotkey menu in the interface does not appear to load with this build of dolphin. I will have to look into this.
                    Thanks for reminding me about the "failed to load image" error. This is a nuisance error. I will update the install script when I have some time so that it copies the Resources folder to the /usr/local/share directory. This error message shouldn't be a problem with the nogui version of dolphin since errors just get logged to the console and don't produce popups. Note that I think the nogui version runs a bit faster on the Pi anyways.
                    I am unfamiliar with the Windows-1252 error that you mentioned. I will have to look into it more to understand why it is getting generated. If it's just a popup and you are not noticing gameplay issues, I would recommend using the nogui version in emulationstation for the time being.
                    sugarfreeS 1 Reply Last reply Reply Quote 1
                    • roslofR
                      roslof @gvx64
                      I converted Mario Kart Double Dash to .rvz format. Everything play-tested great! Nice integration, man. With this change, was able to free up at least a couple of GB for the games that require your 5.0. version.
                      Cheers!
                      • sugarfreeS
                        sugarfree @gvx64
                        @gvx64
                        Thank you again! I was able to configure the controller. I added the following line:
                        dolphin-rpi-editor = "XINIT-WM:/opt/retropie/emulators/dolphin-rpi/bin/dolphin-emu -u /home/pi/DolphinConfig5.0/"
                        to the /opt/retropie/configs/gc/emulator.cfg file, and now it is possible to open the GUI from runcommand. We are doing the same with the new version of Dolphin.
                        The Windows-1252 error seems to appear only with the GUI version.
                        • TPRT
                          TPR @gvx64
                          I did this and it does not appear to be showing up in the list of experimental scriptmodules I have available in RetroPie Setup.
                          • sugarfreeS
                            sugarfree @TPR
                            @TPR
                            Try the following:
                            from terminal window type:
                            cd /home/pi/RetroPie-Setup/scriptmodules/emulators
                            then
                            nano
                            and last copy/paste into the window that have open the content of the script and save it with name dolphin-rpi.sh with ctrl+o and ctrl+x to exit
                            TPRT 2 Replies Last reply Reply Quote 0
                            • TPRT
                              TPR @sugarfree
                              @TPR
                              Try the following:
                              then
                              nano
                              That worked. Now it's showing up.
                              So question, why is it that pasting it into a .txt file and FTPing it to the build didn't work? Just curious so for my own knowledge.
                              G DTEAMD 2 Replies Last reply Reply Quote 0
                              • TPRT
                                TPR @sugarfree
                                @gvx64
                                Up and running! Mario Kart seems to be working great. A couple of questions...
                                1. I was able to configure my controller using your editor line added to emulators.cfg but....
                                2. I don't seem to be able to configure a way to exit a game from the controller, and I am able to do this with the normal version of Dolphin.
                                3. The ESC key on the keyboard only seems to pause the game and no longer exists out.
                                Any idea how I can exit out of a game without having to shut off the Pi which is what I'm doing now..
                                Also, I noticed I'm not getting any mouse pointer in the editor which is extremely annoying as I'm just having to guess where the mouse pointer is all the time.
                                  gvx64 @TPR
                                  @roslof Thanks a lot for letting me know. I am glad that it is working.
                                  @sugarfree Thanks for letting me know, that is a good way to configure and avoid having to exit emulationstation.
                                  @TPR Yeah, exiting dolphin is a bit of a pain on the Pi. Unfortunately, the hotkey customization window in this current build of dolphin doesn't seem to load (at least for me). I am going to look into this and see if I can get the hotkey window working with another commit. I am not sure if dolphin hotkeys will map to a gamepad, but at least you should be able to configure a simple button press on your keyboard like ESC to exit.
                                  Right now, the easiest way I know of to exit dolphin (without hotkey customization) is to use the following keystrokes on your keyboard: "CTRL + ALT + F1" - this I believe will kill the x-session. Next, you may have to then keystroke "CTRL + C" to kill the residual dolphin process but I am unsure if this additional step always needs to be done within emulationstation. I know, this is a lot of buttons to press (and remember).
                                  Myself, I use a custom GPIO gamepad driver written in C and so I was able to map the "sudo killall -9 dolphin-emu-nogui" bash command, at the driver level, whenever I push the L and START buttons on my N64 Controller which lets me exit dolphin very easily. This is also a good option if you ever have lr-emulators that freeze and become unresponsive to allow you to get back to emulationstation without having to hard restart your Pi or login remotely and kill the hanging processes since you can attach a whole bunch of different kill commands to this button combo.
                                  If you know a bit about Linux you can probably do something similar using a shell script fairly easily that gets launched on startup on your Pi and checks button states every few seconds or so but the exact implementation will depend on your gamepad. I am not sure if there is interest in me trying to create such a script, but let me know if there is.
                                  TPRT 1 Reply Last reply Reply Quote 0
                                    gvx64 @TPR
                                    @TPR said in MKDD Tint Issue RPI5:
                                    @TPR
                                    Try the following:
                                    then
                                    nano
                                    I have had this problem before on Linux with shell scripts. A windows-saved txt file has different line-ending characters than one saved on a Linux machine that will cause conflicts if you try to run it with bash. It's best to just paste your text file into a program like nano on your Linux machine and then save it, as per @sugarfree 's recommendations.
                                    • TPRT
                                      TPR @gvx64
                                      And that worked perfectly fine, so thanks for the suggestion.
                                      • TPRT
                                        TPR @gvx64
                                        Gotcha. Yeah on normal dolphin I'm able to map SELECT + START to exit the emulator as well as the ESC key. Hoping you're able to get that working because this does work fantastic! Thank you!
                                        • retropieuser555R
                                          retropieuser555
                                          For anyone searching for a solution; this version of dolphin also fixes
                                          Bomberman Generations' black menu problems, so that's playable with this
                                          Sonic Adventure DX. This loads and plays ok, not perfect as the audio is a little muffled, which I don't remember the original being like that
                                          Virtua Striker 2002 loads but it still has choppy FPS so it's not that playable
                                          Pi 5 4GB
                                          TPRT 1 Reply Last reply Reply Quote 2
                                          • TPRT
                                            TPR @retropieuser555
                                            @retropieuser555 has anyone figured out yet how to get better button mapping with this version so it's easier to map a controller and exit out of a game without needing a keyboard attached?
