    MKDD Tint Issue RPI5
    lr-dolphinmkdddoubledashvulkandrivers
    175 Posts 11 Posters 63.8k Views
    • TPRT
      TPR @retropieuser555
      @retropieuser555 Any ideas what I might be doing wrong here?
        gvx64
        So I finally bought Double Dash because I wanted to try it out on my Pi4 using dolphin-rpi. At first the game speed was really poor (~60% fullspeed). That said, I found this hack that gets Double Dash playing at fullspeed by cutting the framerate from 60fps to 30 and activating the game's internal frameskipping:
        I added the following commands to the GM4.ini file in ~/DolphinConfig5.0/GameSettings:
        [Core]
        EnableCheats = True
        [ActionReplay_Enabled]
        $Force 30FPS
        [ActionReplay]
        $Force 30FPS
        0448C388 00000002
        (source: https://www.reddit.com/r/gpdxd/comments/flq57f/near_fullspeed_double_dash_with_30fps_code/)
        Note that my Pi4 is overclocked 2350MHz/940MHz. The games runs a bit choppy at around 23-28fps but the game speed seems to basically be fullspeed. It's very playable on the Pi4 with this hack.
        I am not sure how helpful this hack will be for Pi5 users at is sounds like Double Dash runs at fullspeed regardless and I am not sure if this hack will help with multiplayer. That said, I mainly wanted to share this for any Pi4 users out there. It definitely made a huge difference for me playing this game.
        • TPRT
          @retropieuser555 So I've been messing around with the automapping and controller detecting script, I've now been able to get it to work pretty successfully, and I've tested it with a number of different controllers and it is working fine, except for one..... the 8Bitdo Pro 2 controller.
          I think this is the issue. When emulationstation detects the controller it sees it as this:
          but it saves it as a file called:
          8BitDo Ultimate Wireless Pro 2 Wired Controller.ini
          and in that file the ID is this:
          [Profile]
          Device = evdev/0/8BitDo Ultimate Wireless / Pro 2 Wired Controller
          And it doesn't load or work. In fact, it gets confused and loads the profile for whatever the last controller I had.
          I think it doesn't like the slash "/" in the ID as it may be looking for it in the file name but the file name cannot have that character in it.
          I have noticed that the dolphin script needs to have the exact file name match the controller device ID for it to work.
          Do you have any idea what database file emulationstation is pulling those Device ID's from and maybe I can try changing the name from "8BitDo Ultimate Wireless / Pro 2 Wired Controller" to "8BitDo Ultimate Wireless Pro 2 Wired Controller" and I have a feeling that will work.
          Anyone have any thoughts? @DTEAM or @mitu
          • TPRT
            TPR
            @retropieuser555
            So a little update. I can confirm that the script works just fine with at least ten different controllers I just tried. The only trouble I'm having is with the above 8Bitdo controller that puts the "/' slash in the device name.
            Any ideas on how to remove that or work around that?
            Here's all the devices I have tried so far:
            • retropieuser555R
              retropieuser555 @TPR
              @TPR you might have a problem there as forward slash is reversed by Linux in file names. When using jstest the device has a forward slash in it? Also and the 3 other modes as I know my Pro 2 has 4 modes, so I assume the wired controller is the same
              Pi 5 4GB
              TPRT 1 Reply Last reply Reply Quote 0
              • TPRT
                @retropieuser555 said in MKDD Tint Issue RPI5:
                Yep. That appears to be the name the Pi sees. And I have tried all four settings on my Pro 2 paired with the 8Bitdo Black Retro Receiver and I get the same results:
                Is there a work around for this?
                • TPRT
                  TPR
                  @retropieuser555 Ok so I think I found my own work around. Here's what I had to do...
                  1. Instead of using the 8Bitdo Retro Receiver I paired it via bluetooth using the X option on the back of the controller. At that point, emulationstation saw the controller as this:
                  1. Dolphin didn't like that and I got this error:
                  2. What was interesting is that in my GCPad config folder, I did have a file created called Xbox One S Controller.ini but dolphin seemed to think it was looking for 8BitDo Pro 2.ini
                  3. I renamed the file to 8BitDo Pro 2.ini and it loaded up without getting that error. But the controls still didn't work. I opened up the .ini file and saw this:
                  And noticed that, even though emulationstation displayed one device name, the script was still using the other. So I opened up Dolphin to see what it was seeing.
                  1. So in Dolphin, the controller was seen as this:
                  2. So I went into the .ini file and changed the device name to match that:
                  3. And that worked! Most of the controllers seemed to be okay, but the exit hotkey didn't work, so I had to go into the .ini files and edit both of them to make sure the hotkeys matched up and the buttons were assigned correctly.
                  4. Here is what my two .ini files look like now:
                  And everything seems to work!
                  I'll still keep messing around with this, but other than the one controller profile where the script seemed to not like the "/" being in the device name, every other controller I've tried seems to work just fine.
                  • TPRT
                    TPR @TPR
                    @retropieuser555 Had another minor issue with the Logitech F310 Gamepad.
                    I configured the controller through emulatationstation and then loaded up Dolphin and everything seemed to be fine except for the D-Pad wasn't working.
                    So then I went into Dolphin, loaded the Logitech Gamepad F310.ini file that your script had made and then saved it out.
                    D-Pad now works...
                    But exiting the game doesn't!
                    Apparently when I edited the Logitech Gamepad F310.ini file in Dolphin in removed the Hotkey setting when it re-saved it, so I went back in and edited the file manually to add back in Hotkey setting and now that works:
                    Also, the Logitech F310 has two settings on the controller. On the other setting, it made a file called "Logitech Dual Action.ini" which gave me an error. Dolphin was looking for a file called "Logitech Logitech Dual Action.ini" so I renamed the file to that, followed the same steps I did above for the other controller setting, and now that works!
                    So at the moment, I have the following four controllers I appear to be able to swap without any issues now that I've made the edits that I did:
                    1. XBOX 360 Controller (seemed to work without needing any edits)
                    2. Playstation 3 Controller (worked without edits)
                    3. Logitech F310 Controller (needed file name edits, re-mapping D-Pad and adding back the Hotkey)
                    4. 8Bitdo Pro 2 (Did not work with Retro Receiver due to device name having the slash "/" in it. Worked via bluetooth but needed to rename the files and the devices, and also edit the controller settings to add back to the Hotkey)
                    • TPRT
                      TPR @TPR
                      @retropieuser555 So another little update...
                      When using the USB Retro Receiver 2 with the Pro 2 controller, PS5 controller, Switch Pro Controller, or an XBOX One X controller, they all identify as "8BitDo Ultimate Wireless / Pro 2 Wired Controller" as a "device." Is there any work around at all for this? Where is emulationstation pulled that device name from and maybe I can change it in that database somewhere?
                      • retropieuser555R
                        @TPR not really no. Emulationstation's names are SDL which aren't necessarily the same device names you'd get from evdev. 8bitdo might use the same names as a manufacturer but trouble I've found is SDL doesn't seem to have universal names. So SDL names are different on dolphin compared to emulationstation. Otherwise the script would've been miles easier and could just make a dolphin config for SDL mode when mapping a controller in ES. So I ended up using evdev as that is at least consistent between dolphin and Linux itself.
                        The names come from /proc/bus/input/devices which you can see for anything connected to the machine using
                        cat /proc/bus/input/devices
                        If I have time I'm tempted to use the I: identifier to check the connected devices against the ini files. That way it'd avoid any possibility of a controllers special characters on the names screwing things up. I've got a tribute 64 controller that has a comma in the name so I can test with that
                        Pi 5 4GB
                        TPRT 2 Replies Last reply Reply Quote 0
                        • TPRT
                          Weird... my Tribute 64 identifies as an "XBOX 360 Controller." This one right?
                          I really do hope there is a fix for this. It's crazy to me that Dolphin doesn't auto detect the connected controller like every other emulator core seems to do!
                          On the plus side, at least connecting it via bluetooth does seem to help. And I've got a Mayflash USB Receiver on the way so I'm curious to see if the 8Bitdo is assigned a different device ID with that one.
                          I've managed to get something like 20 different controllers to work with it now swapping them in and out so the script works great for everything but that one Retro Receiver. I'd had to go in and re-configure the D-Pad on some controllers and add back the hotkey but it all works once I re-save the profile!
                          • TPRT
                            I did just come across one with a comma in it that didn't work. Even though the file name and the ID name are the same, it still didn't load the profile:
                            • TPRT
                              TPR @gvx64
                              @gvx64 said in MKDD Tint Issue RPI5:
                              @sugarfree m3u (multi-disc) support was added to dolphin in 5.0-9343 (https://dolphin-emu.org/download/dev/1d3e3de44b177eb7bdd07a02afefb83ac9ba5812/ - committed on January 15, 2019). That was about 1.5 years after the commit date for 5.0-4544. So no, dolphin-rpi does not support m3u files at this time.
                              A couple of questions for you now that I'm coming back to figuring out GC...
                              1. So RE4 is playable, you just have to manually swap discs in the backend, correct?
                              2. Where does rpi pull the game configs from? Is it the same /opt/retropie/configs/gc/local/GameSettings folder as the normal dolphin core?
                              3. I've noticed that RVZ files do run, but they don't appear in my listing of games. Is that normal?
                              • TPRT
                                TPR
                                @retropieuser555 Something else I just noticed about the script. If you have two controllers connected, they both work, but only controller 2 has the ability to exit out of a game with the hotkey. Controller 1 no longer does this.
                                • TPRT
                                  TPR
                                  @retropieuser555 The script does not seem to work with .m3u files. Neither Metal Gear Solid or Medal of Honor Rising Sun worked with the controller.
                                  EDIT: Nevermind. Got the M3U file to work. Seems like the discs have to be visible in the same directory as the m3u to work correctly.
                                  I had my disc files as .Metal Gear Solid - The Twin Snakes (USA) (Disc 1).rvz so they wouldn't appear in the listing and then I also tried putting them in a different folder and neither worked.
                                  But if the .rvz file is visible in the same folder as the m3u, it seems to work.
                                    gvx64 @TPR
                                    @TPR
                                    1. Yes, my experience with multidisc iso's in dolphin (Baten Kaitos) is that when you reach the end of disc 1 the save file should get updated, then you can close the emulator and reopen with disc 2. RE4 should be fully playable on a Pi5 using dolphin-rpi.
                                    2. /home/pi/DolphinConfig5.0/GameSettings/ (if you installed using the script or using the instructions in post #42 of this thread).
                                    3. Thanks for letting me know, is this the game-list inside the main dolphin gui window? I will look into it.
                                    Adding m3u support to dolphin-rpi is still on my to-do list.
                                    TPRT 4 Replies Last reply Reply Quote 0
                                    • TPRT
                                      TPR @gvx64
                                      @TPR
                                      1. Perfect, thank you!
                                      2. Found it!
                                      3. Yes, the main game-list. Only my iso or ciso files appear.
                                      Also do you think @retropieuser555's controller detection script will work with your version?
                                      https://retropie.org.uk/forum/post/301107
                                      • TPRT
                                        TPR @gvx64
                                        Oh man that would be incredible!
                                        • TPRT
                                          TPR @TPR
                                          @TPR said in MKDD Tint Issue RPI5:
                                          @retropieuser555
                                          Nope, I was right the first time. .m3u files don't work. I was fooled into thinking it did because I had loaded Metal Gear Solid - The Twin Snakes (USA) (Disc 1).rvz on its own so it saved my XBOX 360 profile to the config, and then it kept loading that up every time I would load that game again, but then on other games, the .m3u file didn't work.
                                          I went back to Metal Gear and tried another controller and it poped up with XBOX 360 even with a different controller connected.
                                          So the .m3u files don't currently work correctly.
                                          • TPRT
                                            TPR @gvx64
                                            @TPR
                                            Does this work from launching a game through emulationstation or just through Dolphin?
